cs_matrix_spmv_hip.cpp File Reference
Sparse Matrix SpMV operations with HIP. More...
#include <stdarg.h>
#include <mpi.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_base_hip.h"
#include "base/cs_halo.h"
#include "base/cs_halo_perio.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "base/cs_timer.h"
#include "alge/cs_matrix.h"
#include "alge/cs_matrix_priv.h"
#include "alge/cs_matrix_spmv.h"
+ Include dependency graph for cs_matrix_spmv_hip.cpp:
void cs_matrix_spmv_hip_finalize (void)
 Finalize ROC matrix API. More...
void cs_matrix_spmv_hip_set_stream (hipStream_t stream)
 Assign ROC stream for next ROC-based SpMV operations. More...
hipStream_t cs_matrix_spmv_hip_get_stream (void)
 Return stream used for ROC-based SpMV operations. More...
void cs_matrix_spmv_hip_native (const cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
 Matrix.vector product y = A.x with MSR matrix, scalar ROC version. More...
void cs_matrix_spmv_hip_csr (cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
 Matrix.vector product y = A.x with CSR matrix, scalar ROC version. More...
void cs_matrix_spmv_hip_msr (cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
void cs_matrix_spmv_hip_msr_b (cs_matrix_t *matrix, bool exclude_diag, bool sync, cs_real_t d_x[], cs_real_t d_y[])
 Matrix.vector product y = A.x with MSR matrix, block diagonal ROC version. More...
◆ cs_matrix_spmv_hip_csr()
void cs_matrix_spmv_hip_csr ( cs_matrix_t *  matrix,
bool  exclude_diag,
bool  sync,
cs_real_t  d_x[],
cs_real_t  d_y[]
Matrix.vector product y = A.x with CSR matrix, scalar HIP version.
[in]matrixpointer to matrix structure
[in]exclude_diagexclude diagonal if true,
[in]syncsynchronize ghost cells if true
[in]d_xmultipliying vector values (on device)
[out]d_yresulting vector (on device)
◆ cs_matrix_spmv_hip_finalize()
void cs_matrix_spmv_hip_finalize ( void  )
Finalize HIP matrix API.
This frees resources such as the rocSPARSE handle, if used.
◆ cs_matrix_spmv_hip_get_stream()
hipStream_t cs_matrix_spmv_hip_get_stream ( void  )
This function is callable only from ROC code.
◆ cs_matrix_spmv_hip_msr()
void cs_matrix_spmv_hip_msr ( cs_matrix_t *  matrix,
bool  exclude_diag,
bool  sync,
cs_real_t  d_x[],
cs_real_t  d_y[]
Matrix.vector product y = A.x with MSR matrix, scalar HIP version.
◆ cs_matrix_spmv_hip_msr_b()
void cs_matrix_spmv_hip_msr_b ( cs_matrix_t *  matrix,
bool  exclude_diag,
bool  sync,
cs_real_t  d_x[],
cs_real_t  d_y[]
Matrix.vector product y = A.x with MSR matrix, block diagonal HIP version.
◆ cs_matrix_spmv_hip_native()
void cs_matrix_spmv_hip_native ( const cs_matrix_t *  matrix,
bool  exclude_diag,
bool  sync,
cs_real_t  d_x[],
cs_real_t  d_y[]
◆ cs_matrix_spmv_hip_set_stream()
void cs_matrix_spmv_hip_set_stream ( hipStream_t  stream)
If a stream other than the default stream (0) is used, it will not be synchronized automatically after sparse matrix-vector products (so as to avoid the corresponding overhead), so the caller will need to manage stream syncronization manually.
