1#ifndef CS_EQUATION_SYSTEM_PARAM_H
2#define CS_EQUATION_SYSTEM_PARAM_H
#define restrict
Definition: cs_defs.h:148
cs_equation_system_param_t * cs_equation_system_param_free(cs_equation_system_param_t *sysp)
Free a cs_equation_system_param_t structure.
Definition: cs_equation_system_param.cpp:176
cs_equation_system_key_t
List of available keys for setting the parameters of a system of equations.
Definition: cs_equation_system_param.h:156
@ CS_SYSKEY_INCR_SOLVE
Definition: cs_equation_system_param.h:158
@ CS_SYSKEY_LINEAR_SOLVER_ATOL
Definition: cs_equation_system_param.h:159
@ CS_SYSKEY_N_KEYS
Definition: cs_equation_system_param.h:166
@ CS_SYSKEY_LINEAR_SOLVER_DTOL
Definition: cs_equation_system_param.h:160
@ CS_SYSKEY_LINEAR_SOLVER_RTOL
Definition: cs_equation_system_param.h:161
@ CS_SYSKEY_SLES_STRATEGY
Definition: cs_equation_system_param.h:163
@ CS_SYSKEY_LINEAR_SOLVER_MAX_ITER
Definition: cs_equation_system_param.h:162
@ CS_SYSKEY_VERBOSITY
Definition: cs_equation_system_param.h:164
cs_equation_system_sles_strategy_t
High-level information about the way of solving the system of equations.
Definition: cs_equation_system_param.h:56
@ CS_EQUATION_SYSTEM_N_SLES_TYPES
Definition: cs_equation_system_param.h:60
@ CS_EQUATION_SYSTEM_SLES_MUMPS
Definition: cs_equation_system_param.h:58
void cs_equation_system_param_set(cs_equation_system_param_t *sysp, cs_equation_system_key_t key, const char *keyval)
Set a parameter related to a keyname in a cs_equation_system_param_t structure.
Definition: cs_equation_system_param.cpp:244
cs_equation_system_param_t * cs_equation_system_param_create(const char *name, int block_var_dim)
Create and initialize a new cs_equation_system_param_t structure.
Definition: cs_equation_system_param.cpp:85
void cs_equation_system_param_log(const cs_equation_system_param_t *sysp)
Log the setup gathered in the structure cs_equation_system_param_t.
Definition: cs_equation_system_param.cpp:199
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
cs_param_space_scheme_t
Definition: cs_param_types.h:215
Main structure storing the parameter settings.
Definition: cs_equation_system_param.h:68
cs_param_sles_t * sles_param
Definition: cs_equation_system_param.h:118
int block_var_dim
Definition: cs_equation_system_param.h:100
cs_equation_system_sles_strategy_t sles_strategy
Definition: cs_equation_system_param.h:117
cs_property_t * relax_pty
Definition: cs_equation_system_param.h:103
int verbosity
Definition: cs_equation_system_param.h:98
char *restrict name
Definition: cs_equation_system_param.h:96
cs_param_space_scheme_t space_scheme
Definition: cs_equation_system_param.h:99
bool incremental_solve
Definition: cs_equation_system_param.h:101
Definition: cs_param_sles.h:63
