cs_equation_builder.cpp File Reference
#include <cassert>
#include <cstring>
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "cdo/cs_equation_builder.h"
+ Include dependency graph for cs_equation_builder.cpp:
void cs_equation_builder_update_default_flags (cs_eflag_t msh_flag, cs_eflag_t bdy_flag, cs_eflag_t src_flag)
 Update the default flags used to know which quantities have to be built by each cs_cell_mesh_t structure before building the linear system. More...
cs_equation_builder_t * cs_equation_builder_create (const cs_equation_param_t *eqp, const cs_mesh_t *mesh)
 Allocate a new structure to handle the building of algebraic system related to a cs_equation_t structure. More...
const cs_matrix_t * cs_equation_builder_get_matrix (const cs_equation_builder_t *builder, int block_id)
 Retrieve the matrix structure associated to the given block_id When there is only one block, this is simply 0. One relies on the cs_cdo_system_helper_t structure to retrieve this matrix. So, the block_id must be consistent with the way to store the blocks in this structure. More...
const cs_range_set_t * cs_equation_builder_get_range_set (const cs_equation_builder_t *builder, int block_id)
 Retrieve the range set structure associated to a builder structure for the block defined in block_id in the system helper structure. More...
void cs_equation_builder_free (cs_equation_builder_t **p_builder)
 Free a cs_equation_builder_t structure. More...
void cs_equation_builder_reset (cs_equation_builder_t *eqb)
 Free some members of a cs_equation_builder_t structure. More...
void cs_equation_builder_apply_default_flags (cs_equation_builder_t *eqb)
 Update the flags with the default flags. These flags are used to know which quantities have to be built by each cs_cell_mesh_t structure before building the linear system. More...
void cs_equation_builder_log_performance (int n_time_steps, cs_gnum_t n_g_dofs, const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb)
 Print a message in the performance output file related to the monitoring of equation. More...
bool cs_equation_builder_set_reaction_pty_cw (const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_cell_mesh_t *cm, cs_cell_builder_t *cb)
 Initialize all reaction properties. This function is shared across all CDO schemes. The cs_cell_builder_t structure stores the computed property values. If the property is uniform, a first call to the function cs_equation_builder_init_properties has to be done before the loop on cells. More...
void cs_equation_builder_init_properties (const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, cs_hodge_t *diff_hodge, cs_cell_builder_t *cb)
 Initialize all properties potentially useful to build the algebraic system. This function is shared across all CDO schemes. The cs_cell_builder_t structure stores property values related to the reaction term, unsteady term and grad-div term. More...
void cs_equation_builder_enforce_dofs (const cs_equation_builder_t *eqb, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account the enforcement of internal DoFs. Apply an algebraic manipulation. Update members of the cs_cell_sys_t structure related to the internal enforcement. More...
void cs_equation_builder_enforce_block_dofs (const cs_equation_builder_t *eqb, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account the enforcement of internal DoFs. Case of matrices defined by blocks. Apply an algebraic manipulation. Update members of the cs_cell_sys_t structure related to the internal enforcement. More...
◆ cs_equation_builder_apply_default_flags()
void cs_equation_builder_apply_default_flags ( cs_equation_builder_t *  eqb)
[in]eqbpointer to an equation builer
◆ cs_equation_builder_create()
cs_equation_builder_t * cs_equation_builder_create ( const cs_equation_param_t *  eqp,
const cs_mesh_t *  mesh
a pointer to a new allocated cs_equation_builder_t structure
◆ cs_equation_builder_enforce_block_dofs()
void cs_equation_builder_enforce_block_dofs ( const cs_equation_builder_t *  eqb,
cs_cell_builder_t *  cb,
cs_cell_sys_t *  csys
| | | | | | | | | | | Aii | Aie | | Aii | 0 | |bi| |bi -Aid.x_enf| |---------—| --> |---------—| and |–| --> |----------—| | | | | | | | | | | | Aei | Aee | | 0 | Id | |be| | x_enf |
where x_enf is the value of the enforcement for the selected internal DoFs
[in]eqbpointer to a cs_equation_builder_t structure
[in,out]csysstructure storing the cell-wise system
◆ cs_equation_builder_enforce_dofs()
void cs_equation_builder_enforce_dofs ( const cs_equation_builder_t *  eqb,
◆ cs_equation_builder_free()
void cs_equation_builder_free ( cs_equation_builder_t **  p_builder)
[in,out]p_builderpointer of pointer to the cs_equation_builder_t structure to free
◆ cs_equation_builder_get_matrix()
const cs_matrix_t * cs_equation_builder_get_matrix ( const cs_equation_builder_t *  builder,
int  block_id
[in,out]builderpointer to a cs_equation_builder_t
[in]block_idid of the block to consider
a pointer to a cs_matrix_t structure
◆ cs_equation_builder_get_range_set()
const cs_range_set_t * cs_equation_builder_get_range_set ( const cs_equation_builder_t *  builder,
int  block_id
a pointer to a cs_range_set structure
◆ cs_equation_builder_init_properties()
void cs_equation_builder_init_properties ( const cs_equation_param_t *  eqp,
cs_hodge_t *  diff_hodge,
[in,out]diff_hodgepointer to the diffusion hodge structure
◆ cs_equation_builder_log_performance()
void cs_equation_builder_log_performance ( int  n_time_steps,
cs_gnum_t  n_g_dofs,
[in]n_time_stepsnumber of time steps computed
[in]n_dofsnumber of DoFs
[in]eqppointer to a set of equation parameters
[in]eqbpointer to an equation builder structure
◆ cs_equation_builder_reset()
void cs_equation_builder_reset ( cs_equation_builder_t *  eqb)
[in,out]eqbpointer to the cs_equation_builder_t structure
◆ cs_equation_builder_set_reaction_pty_cw()
bool cs_equation_builder_set_reaction_pty_cw ( const cs_equation_param_t *  eqp,
const cs_cell_mesh_t *  cm,
true if the reaction property is not equal to zero
◆ cs_equation_builder_update_default_flags()
void cs_equation_builder_update_default_flags ( cs_eflag_t  msh_flag,
cs_eflag_t  src_flag
[in]msh_flagflag for all cells
[in]bdy_flagflag for all boundary cells
[in]src_flagflag for cells with source terms
