69 for (
short int i = 0; i < csys->
n_dofs; i++) {
73 " %s: Invalid value for a homogeneous Dirichlet condition",
Definition: bft_error.cpp:187
void cs_dbg_dump_msr_system(const char *eqname, cs_lnum_t size, int verbosity, const cs_real_t x[], const cs_real_t b[], const cs_lnum_t row_index[], const cs_lnum_t col_id[], const cs_real_t xval[], const cs_real_t dval[])
In debug mode, dump a linear system stored in a MSR format into the listing file (should be a small s...
Definition: cs_dbg.cpp:387
void cs_dbg_dump_local_scalar_msr_matrix(const char *name, const cs_matrix_t *matrix)
In debug mode, dump a linear system. Case of scalar-valued entries.
Definition: cs_dbg.cpp:305
static void cs_dbg_check_hmg_dirichlet_cw(const char *fname, const cs_cell_sys_t *csys)
Check if there is no invalid setting for a homogeneous Dirichlet.
Definition: cs_dbg.h:66
void cs_dbg_array_fprintf(FILE *fp, const char *fname, cs_real_t thd, cs_lnum_t n_elts, const cs_real_t array[], int n_cols)
Print an array. Print into the file f if given otherwise open a new file named fname if given otherwi...
Definition: cs_dbg.cpp:138
void cs_dbg_print_local_scalar_msr_matrix(const char *name, const cs_matrix_t *matrix)
Print a linear system. Case of scalar-valued entries.
Definition: cs_dbg.cpp:342
void cs_dbg_iarray_to_listing(const char *header, const cs_lnum_t size, const cs_lnum_t array[], int n_cols)
In debug mode, dump an array of integer into the log.
Definition: cs_dbg.cpp:271
void cs_dbg_darray_to_listing(const char *header, const cs_lnum_t size, const cs_real_t array[], int n_cols)
In debug mode, dump an array of double into the log.
Definition: cs_dbg.cpp:235
bool cs_dbg_cw_test(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys)
Function used to select which element deserves a dump or specific treatment during a debugging stage.
Definition: cs_dbg.cpp:76
void cs_dbg_fprintf_system(const char *eqname, int id, int level, const cs_real_t *sol, const cs_real_t *rhs, cs_lnum_t size)
In debug mode, print into a file the solution and its right-hand side.
Definition: cs_dbg.cpp:200
void cs_dbg_binary_dump_system(const char *basename, const cs_matrix_t *matrix, const cs_real_t *rhs, const cs_real_t *sol)
Binary dump (matrix, rhs and solution) of a matrix, its right-hand side and the solution array.
Definition: cs_dbg.cpp:484
Definition: cs_defs.h:332
Definition: cs_defs.h:325
static constexpr double cs_dbl_min
Definition: cs_math.h:96
Definition: cs_matrix.h:108
#define CS_CDO_BC_HMG_DIRICHLET
Definition: cs_cdo_bc.h:73
CS_F_HOST_DEVICE T abs(const T a)
Definition: cs_defs.h:690
Definition: cs_cdo_local.h:242
Definition: cs_cdo_local.h:163
double * dir_values
Definition: cs_cdo_local.h:188
cs_flag_t * dof_flag
Definition: cs_cdo_local.h:169
int n_dofs
Definition: cs_cdo_local.h:167
