cs_cdo_system.cpp File Reference
#include <cassert>
#include "base/cs_mem.h"
#include "bft/bft_error.h"
#include "alge/cs_matrix_priv.h"
#include "base/cs_array.h"
#include "cdo/cs_flag.h"
#include "cdo/cs_param_cdo.h"
#include "cdo/cs_cdo_system.h"
+ Include dependency graph for cs_cdo_system.cpp:
void cs_cdo_system_init_sharing (cs_mesh_t *mesh, cs_cdo_connect_t *connect)
 Allocate and initialize matrix-related structures according to the type of discretization used for this simulation. More...
cs_cdo_system_helper_t * cs_cdo_system_helper_create (cs_cdo_system_type_t type, int n_col_blocks, const cs_lnum_t *col_block_sizes, int n_blocks)
 Create a system_helper structure from its set of metadata. n_col_blocks and n_blocks may differ according to the settings. For instance, for a saddle-point system, n_col_blocks >= n_blocks. More...
void cs_cdo_system_helper_free (cs_cdo_system_helper_t **p_helper)
 Free a cs_cdo_system_helper_t structure. More...
cs_cdo_system_block_t * cs_cdo_system_add_dblock (cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced, bool unrolled)
 Add a default block definition at position "block_id" in the helper structure Only metadata are set at this stage. More...
cs_cdo_system_block_t * cs_cdo_system_add_nblock (cs_cdo_system_helper_t *sh, int block_id, cs_cdo_system_matrix_class_t matclass, cs_flag_t location, cs_lnum_t n_elements, int stride)
 Add a split block definition at position "block_id" in the helper structure. Only metadata are set at this stage. More...
cs_cdo_system_block_t * cs_cdo_system_add_ublock (cs_cdo_system_helper_t *sh, int block_id, const cs_adjacency_t *adjacency, cs_flag_t location, cs_lnum_t n_elements, int stride, bool interlaced)
 Add an unassembled block definition at position "block_id" in the helper structure Only metadata are set at this stage. More...
cs_cdo_system_block_t * cs_cdo_system_add_xblock (cs_cdo_system_helper_t *sh, int block_id, cs_lnum_t n_dofs)
 Add an external block definition at position "block_id" in the helper structure. Only metadata are set at this stage. More...
cs_range_set_t * cs_cdo_system_get_range_set (const cs_cdo_system_helper_t *sh, int block_id)
 Retrieve the range set structure associated to the given block_id. More...
cs_matrix_t * cs_cdo_system_get_matrix (const cs_cdo_system_helper_t *sh, int block_id)
 Retrieve the matrix associated to the given block_id. If the type of block is either CS_CDO_SYSTEM_BLOCK_DEFAULT or CS_CDO_SYSTEM_BLOCK_EXTERN. In other cases, a null pointer is returned. The unassembled block has no matrix and to get a matrix of a split block, one should use cs_cdo_system_get_sub_matrix(sh, block_id, sub_id) More...
cs_matrix_t * cs_cdo_system_get_sub_matrix (cs_cdo_system_helper_t *sh, int block_id, int sub_id)
 Retrieve the (sub-)matrix associated to a split block with id equal to block_id. sub_id is the id in the list of matrices of size equal to stride*stride. If the type of the block is not CS_CDO_SYSTEM_BLOCK_NESTED, then a null pointer is returned. More...
void cs_cdo_system_build_block (cs_cdo_system_helper_t *sh, int block_id)
 Build the associated structures for the given system_helper structure If a member is already allocated, one keeps the member as it is. More...
void cs_cdo_system_helper_init_system (cs_cdo_system_helper_t *sh, cs_real_t **p_rhs)
 Allocate and initialize the matrix, rhs and the matrix assembler values. If p_rhs is null then one allocates the rhs inside this function. The ownership is transfered to this structure in that case. More...
void cs_cdo_system_helper_finalize_assembly (cs_cdo_system_helper_t *sh)
 Finalize the assembly after the cellwise building and assembly. More...
void cs_cdo_system_helper_reset (cs_cdo_system_helper_t *sh)
 Free matrix and rhs after the solve step. More...
void cs_cdo_system_allocate_assembly (void)
 Initialize shared assembly structures from the existing helper structures. More...
void cs_cdo_system_destroy_all (void)
 Free all members associated to system helpers. More...
◆ cs_cdo_system_add_dblock()
cs_cdo_system_block_t * cs_cdo_system_add_dblock ( cs_cdo_system_helper_t *  sh,
int  block_id,
cs_flag_t  location,
int  stride,
bool  interlaced,
bool  unrolled
[in,out]shpointer to the system helper to update
[in]block_idid in blocks array in a system helper
[in]matclassclass of the matrix to handle
[in]locationwhere DoFs are defined
[in]n_elementsnumber of elements (support entities for DoFs)
[in]stridenumber of DoFs by element
[in]interlaceduseful if stride > 1; way to store components
[in]unrolleduseful if stride > 1; true=as scalar-valued
a pointer to the newly allocated structure
◆ cs_cdo_system_add_nblock()
cs_cdo_system_block_t * cs_cdo_system_add_nblock ( cs_cdo_system_helper_t *  sh,
int  block_id,
cs_flag_t  location,
int  stride
Add a nested block definition at position "block_id" in the helper structure. Only metadata are set at this stage.
◆ cs_cdo_system_add_ublock()
cs_cdo_system_block_t * cs_cdo_system_add_ublock ( cs_cdo_system_helper_t *  sh,
int  block_id,
const cs_adjacency_t *  adjacency,
cs_flag_t  location,
int  stride,
bool  interlaced
[in]adjacencyshared adjacency structure
◆ cs_cdo_system_add_xblock()
cs_cdo_system_block_t * cs_cdo_system_add_xblock ( cs_cdo_system_helper_t *  sh,
int  block_id,
cs_lnum_t  n_dofs
[in]n_dofsnumber of degrees of freedom
◆ cs_cdo_system_allocate_assembly()
void cs_cdo_system_allocate_assembly ( void  )
◆ cs_cdo_system_build_block()
void cs_cdo_system_build_block ( cs_cdo_system_helper_t *  sh,
int  block_id
[in,out]shpointer to the system_helper structure to update
[in]block_idspecific block to handle or -1 for all blocks
◆ cs_cdo_system_destroy_all()
void cs_cdo_system_destroy_all ( void  )
◆ cs_cdo_system_get_matrix()
cs_matrix_t * cs_cdo_system_get_matrix ( const cs_cdo_system_helper_t *  sh,
int  block_id
[in]shpointer to the system_helper structure to update
[in]block_idid of the block to consider
a pointer to a cs_matrix_t structure or nullptr
◆ cs_cdo_system_get_range_set()
cs_range_set_t * cs_cdo_system_get_range_set ( const cs_cdo_system_helper_t *  sh,
int  block_id
a pointer to a range set structure or nullptr
◆ cs_cdo_system_get_sub_matrix()
cs_matrix_t * cs_cdo_system_get_sub_matrix ( cs_cdo_system_helper_t *  sh,
int  block_id,
int  sub_id
[in]sub_idid in the slip block
◆ cs_cdo_system_helper_create()
cs_cdo_system_helper_t * cs_cdo_system_helper_create ( cs_cdo_system_type_t  type,
int  n_col_blocks,
const cs_lnum_t *  col_block_sizes,
int  n_blocks
[in]typetype of system to handle
[in]n_col_blocksnumber of blocks in a row
[in]col_block_sizesnumber of DoFs in each block of the row
[in]n_blocksnumber of blocks associated to this system
the pointer to the new allocated structure
◆ cs_cdo_system_helper_finalize_assembly()
void cs_cdo_system_helper_finalize_assembly ( cs_cdo_system_helper_t *  sh)
[in,out]shpointer to a system helper structure
◆ cs_cdo_system_helper_free()
void cs_cdo_system_helper_free ( cs_cdo_system_helper_t **  p_helper)
[in,out]p_helperdouble pointer to the structure to free
◆ cs_cdo_system_helper_init_system()
void cs_cdo_system_helper_init_system ( cs_cdo_system_helper_t *  sh,
cs_real_t **  p_rhs
[in,out]p_rhsdouble pointer to the RHS array to initialize
◆ cs_cdo_system_helper_reset()
void cs_cdo_system_helper_reset ( cs_cdo_system_helper_t *  sh)
◆ cs_cdo_system_init_sharing()
void cs_cdo_system_init_sharing ( cs_mesh_t *  mesh,
cs_cdo_connect_t *  connect
