cs_blas_hip.cpp File Reference
#include <algorithm>
#include <hip/hip_runtime.h>
#include <hip/hip_runtime_api.h>
#include "bft/bft_error.h"
#include "base/cs_base.h"
#include "base/cs_mem.h"
#include "base/cs_base_accel.h"
#include "base/cs_base_hip.h"
#include "base/cs_dispatch.h"
#include "alge/cs_blas_hip.h"
+ Include dependency graph for cs_blas_hip.cpp:
Macros
#define BLOCKSIZE   256
template<size_t blockSize, typename T >
static __global__ void _asum_stage_1_of_2 (cs_lnum_t n, const T *x, double *b_res)
 Compute the absolute sum of vector values, summing result over all threads of a block. More...
static __global__ void _dot_xy_stage_1_of_2 (cs_lnum_t n, const T *x, const T *y, double *b_res)
 Compute dot product x.y, summing result over all threads of a block. More...
static __global__ void _dot_xx_stage_1_of_2 (cs_lnum_t n, const T *x, double *b_res)
 Compute dot product x.x, summing result over all threads of a block. More...
static __global__ void _scal (cs_lnum_t n, const cs_real_t *alpha, cs_real_t *restrict x)
unsigned int _grid_size (cs_lnum_t n, unsigned int block_size)
 Compute grid size for given array and block sizes. More...
void cs_blas_hip_finalize (void)
 Finalize HIP BLAS API. More...
static double * _r_reduce = nullptr
static double * _r_grid = nullptr
static unsigned int _r_grid_size = 0
static unsigned int _r_tuple_size = 0
◆ BLOCKSIZE
◆ _asum_stage_1_of_2()
static __global__ void _asum_stage_1_of_2 ( cs_lnum_t  n,
const T *  x,
double *  b_res
static
blockSize must be a power of 2.
[in]narray size
[in]xx vector
[out]b_resresult of s = x.x
◆ _dot_xx_stage_1_of_2()
static __global__ void _dot_xx_stage_1_of_2 ( cs_lnum_t  n,
const T *  x,
double *  b_res
static
[in]narray size
[in]xx vector
[in]yy vector
◆ _dot_xy_stage_1_of_2()
static __global__ void _dot_xy_stage_1_of_2 ( cs_lnum_t  n,
const T *  x,
const T *  y,
double *  b_res
static
[in]narray size
[in]xx vector
[in]yy vector
◆ _grid_size()
unsigned int _grid_size ( cs_lnum_t  n,
Also check initialization of work arrays.
[in]nsize of arrays
[in]block_sizeblock size for kernels
grid size for kernels
◆ _scal()
static __global__ void _scal ( cs_lnum_t  n,
const cs_real_t *  alpha,
static
◆ cs_blas_hip_finalize()
void cs_blas_hip_finalize ( void  )
This frees resources such as the hipBLAS handle, if used.
◆ _r_grid
double* _r_grid = nullptr
static
◆ _r_grid_size
static
◆ _r_reduce
double* _r_reduce = nullptr
static
◆ _r_tuple_size
static
