cs_dispatch_queue Class Reference
#include <cs_dispatch_queue.h>
+ Collaboration diagram for cs_dispatch_queue:
Public Member Functions
template<class F , class... Args>
cs_task parallel_for (cs_lnum_t n, F &&f, Args &&...args)
cs_task parallel_for (cs_lnum_t n, std::initializer_list< cs_event_ref > const &sync_events, F &&f, Args &&...args)
template<class M , class F , class... Args>
cs_task parallel_for_i_faces (const M *m, F &&f, Args &&...args)
cs_task parallel_for_i_faces (const M *m, std::initializer_list< cs_event_ref > const &sync_events, F &&f, Args &&...args)
cs_task parallel_for_b_faces (const M *m, F &&f, Args &&...args)
cs_task parallel_for_b_faces (const M *m, std::initializer_list< cs_event_ref > const &sync_events, F &&f, Args &&...args)
template<class T , class F , class... Args>
cs_task parallel_for_reduce_sum (cs_lnum_t n, T &sum, F &&f, Args &&...args)
cs_task parallel_for_reduce_sum (cs_lnum_t n, std::initializer_list< cs_event_ref > const &sync_events, T &sum, F &&f, Args &&...args)
template<class T , class R , class F , class... Args>
cs_task parallel_for_reduce (cs_lnum_t n, T &r, R &reducer, F &&f, Args &&...args)
cs_task parallel_for_reduce (cs_lnum_t n, std::initializer_list< cs_event_ref > const &sync_events, T &r, R &reducer, F &&f, Args &&...args)
template<class FunctionType , class... Args>
cs_host_task< FunctionType, std::remove_reference_t< Args >... > single_task (std::initializer_list< cs_event_ref > const &sync_events, FunctionType &&host_function, Args &&...args)
cs_host_task< FunctionType, std::remove_reference_t< Args >... > single_task (FunctionType &&host_function, Args &&...args)
 Initiates a single thread task that runs on the host. More...
Public Attributes
cs_dispatch_context initializer_context
 Context used to initialize tasks. More...
Use the execution model from base/cs_dispatch.h to create SYCL-like tasks that can be synchronized together.
Member Function Documentation
◆ parallel_for() [1/2]
cs_task parallel_for ( cs_lnum_t  n,
F &&  f,
Args &&...  args
inline
◆ parallel_for() [2/2]
std::initializer_list< cs_event_ref > const &  sync_events,
F &&  f,
Args &&...  args
inline
◆ parallel_for_b_faces() [1/2]
cs_task parallel_for_b_faces ( const M *  m,
F &&  f,
Args &&...  args
inline
◆ parallel_for_b_faces() [2/2]
F &&  f,
Args &&...  args
inline
◆ parallel_for_i_faces() [1/2]
cs_task parallel_for_i_faces ( const M *  m,
F &&  f,
Args &&...  args
inline
◆ parallel_for_i_faces() [2/2]
F &&  f,
Args &&...  args
inline
◆ parallel_for_reduce() [1/2]
cs_task parallel_for_reduce ( cs_lnum_t  n,
T &  r,
R &  reducer,
F &&  f,
Args &&...  args
inline
◆ parallel_for_reduce() [2/2]
T &  r,
R &  reducer,
F &&  f,
Args &&...  args
inline
◆ parallel_for_reduce_sum() [1/2]
cs_task parallel_for_reduce_sum ( cs_lnum_t  n,
T &  sum,
F &&  f,
Args &&...  args
inline
◆ parallel_for_reduce_sum() [2/2]
T &  sum,
F &&  f,
Args &&...  args
inline
◆ single_task() [1/2]
cs_host_task< FunctionType, std::remove_reference_t< Args >... > single_task ( FunctionType &&  host_function,
Args &&...  args
inline
◆ single_task() [2/2]
cs_host_task< FunctionType, std::remove_reference_t< Args >... > single_task ( std::initializer_list< cs_event_ref > const &  sync_events,
Args &&...  args
inline
Initiates a single thread task that runs on the host. This variant accepts sync_events to synchronize with other tasks.
Member Data Documentation
◆ initializer_context
The documentation for this class was generated from the following file:
