Setting porosity values: basic example
Local definitions and initialization
Mesh quantities
It may be useful to access some mesh adjacencies and quantities, in which case local pointers allow for more readable code:
cs_mesh_t *m = domain->mesh;
cs_mesh_quantities_t *mq = domain->mesh_quantities;
const cs_lnum_2_t *i_face_cells = m->i_face_cells;
const cs_real_3_t *restrict i_face_cog = mq_g->i_face_cog;
const cs_real_3_t *restrict b_face_cog = mq_g->b_face_cog;
const cs_real_3_t *restrict cell_cen = mq_g->cell_cen;
const cs_real_3_t *restrict i_face_normal
= (const cs_real_3_t *)mq_g->i_face_normal;
cs_real_3_t *restrict i_f_face_normal
const cs_real_3_t *restrict b_face_normal
= (const cs_real_3_t *)mq_g->b_face_normal;
cs_real_3_t *restrict b_f_face_normal
const cs_real_t *i_f_face_surf = mq->i_face_surf;
const cs_real_t *i_face_surf = mq_g->i_face_surf;
#define restrict
Definition: cs_defs.h:148
Definition: cs_defs.h:332
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:342
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
cs_mesh_quantities_t * cs_glob_mesh_quantities_g
Definition: cs_mesh_quantities.h:88
cs_real_3_t * b_face_cog
Definition: cs_mesh_quantities.h:102
cs_real_t * i_face_surf
Definition: cs_mesh_quantities.h:107
cs_real_3_t * cell_cen
Definition: cs_mesh_quantities.h:90
cs_real_3_t * i_face_cog
Definition: cs_mesh_quantities.h:101
cs_real_t * b_face_normal
Definition: cs_mesh_quantities.h:97
cs_real_t * i_face_normal
Definition: cs_mesh_quantities.h:95
Definition: cs_mesh.h:85
cs_lnum_2_t * i_face_cells
Definition: cs_mesh.h:111
Associated properties
Accessing cell porosity property values is required so values may be set:
auto cpro_porosi = cs_field("porosity")->get_val_s();
cs_span< cs_real_t > get_val_s(const int time_id=0) const
Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked.
Definition: cs_field.cpp:5080
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
Example: define porosity by geometric zones
Individual cell porosity values can be assigned to each cell, so they may be based on groups, geometric criteria, or any other time-independent functions:
for (cs_lnum_t cell_id = 0; cell_id < m->n_cells; cell_id++) {
cs_real_t x = cell_cen[cell_id][0];
if (x < 20.)
cpro_porosi[cell_id] = 1.;
else
cpro_porosi[cell_id] = 0.5;
/* synchronize for use in fluid face factor calculation below */
halo_type);
Definition: cs_defs.h:325
void cs_field_synchronize(cs_field_t *f, cs_halo_type_t halo_type)
Synchronize current parallel and periodic field values.
Definition: cs_field_operator.cpp:1448
cs_halo_type_t
Definition: cs_halo.h:53
@ CS_HALO_STANDARD
Definition: cs_halo.h:55
cs_lnum_t n_cells
Definition: cs_mesh.h:97
When using the integral porosity model (cs_glob_porous_model == 3), the matching face equivalent surfaces can also be assigned in a corresponding manner, for interior faces:
for (cs_lnum_t face_id = 0; face_id < m->n_i_faces; face_id++) {
cs_real_t x = i_face_cog[face_id][0];
cs_real_t face_porosity = 1.;
if (x > 19.9999)
face_porosity = 0.5;
for (int i = 0; i < 3; i++)
i_f_face_normal[face_id][i] = face_porosity * i_face_normal[face_id][i];
mq->i_face_surf[face_id] = cs_math_3_norm(i_f_face_normal[face_id]);
CS_F_HOST_DEVICE T cs_math_3_norm(const T v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:240
cs_lnum_t n_i_faces
Definition: cs_mesh.h:98
and for boundary faces:
for (cs_lnum_t face_id = 0; face_id < m->n_b_faces; face_id++) {
cs_real_t x = b_face_cog[face_id][0];
if (x > 19.9999)
b_f_face_normal[face_id][i] = face_porosity * b_face_normal[face_id][i];
mq->b_face_surf[face_id] = cs_math_3_norm(b_f_face_normal[face_id]);
cs_real_t * b_face_surf
Definition: cs_mesh_quantities.h:108
cs_lnum_t n_b_faces
Definition: cs_mesh.h:99
When not defined in this way, face porosities will match the lowest adjacent cell porosity.
