cs_combustion_gas_model_t Struct Reference
#include <cs_combustion_gas.h>
+ Collaboration diagram for cs_combustion_gas_model_t:
Public Attributes
int n_gas_el_comp
int n_gas_species
int n_atomic_species
int n_reactions
int n_tab_points
double pcigas
double xco2
double xh2o
double wmole [CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS]
double wmolat [CS_COMBUSTION_GAS_MAX_ATOMIC_SPECIES]
double oxyn2 [CS_COMBUSTION_GAS_MAX_OXYDANTS]
double oxyh2o [CS_COMBUSTION_GAS_MAX_OXYDANTS]
double oxyco2 [CS_COMBUSTION_GAS_MAX_OXYDANTS]
double th [CS_COMBUSTION_GAS_MAX_TABULATION_POINTS]
cs_combustion_gas_model_type_t type
char * data_file_name
char * radiation_data_file_name
bool use_janaf
int iic
int iico2
int iio2
int isoot
int ientgf
int ientgb
double hinfue
double tinfue
double tinoxy
double hinoxy
double xsoot
double rosoot
double lsp_fuel
double frmel
double tgf
double cebu
double wmolg [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
double coefeg [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES][CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS]
double compog [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES][CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS]
double fs [CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS]
double cp_gas_g [CS_COMBUSTION_GAS_MAX_TABULATION_POINTS][CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
double eh_gas_g [CS_COMBUSTION_GAS_MAX_TABULATION_POINTS][CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
double ckabsg [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
cs_field_t * fm
cs_field_t * fp2m
cs_field_t * fsqm
cs_field_t * pvm
cs_field_t * ygfm
cs_field_t * yfm
cs_field_t * yfp2m
cs_field_t * coyfp
cs_field_t * npm
cs_field_t * fsm
cs_field_t * xr
cs_field_t * hrr
cs_field_t * omgc
cs_field_t * totki
cs_field_t * recvr
cs_field_t * ym [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
cs_field_t * bym [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
cs_field_t * t2m
cs_field_t * t3m
cs_field_t * t4m
cs_field_t * ckabs
double srrom
double hstoea
double hh [9]
double ff [9]
double tfh [9][9]
double coeff_therm [7][2][5]
cs_libby_williams_params_t lw
int n_gas_fl
int nki
int nxr
int nzm
int nzvar
int nlibvar
int ikimid
int mode_fp2m
char flamelet_species_name [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES][13]
cs_real_t * flamelet_library
cs_real_t * rho_library
cs_real_t * radiation_library
int flamelet_zm
int flamelet_zvar
int flamelet_xr
int flamelet_ki
int flamelet_temp
int flamelet_rho
int flamelet_vis
int flamelet_dt
int flamelet_temp2
int flamelet_hrr
int flamelet_c
int flamelet_omg_c
int flamelet_species [CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
Gas combustion model parameters structure
Member Data Documentation
◆ bym
◆ cebu
double cebu
Eddy-break-up constant (EBU)
◆ ckabs
cs_field_t* ckabs
◆ ckabsg
absorption coefficient of global species
◆ coefeg
mass fraction conversion coefficients from global species to elementary species
◆ coeff_therm
double coeff_therm[7][2][5]
Burke-Schumann parameters
◆ compog
mole fraction conversion coefficients from global species to elementary species
◆ coyfp
cs_field_t* coyfp
◆ cp_gas_g
cpgasg[j][i] is the massic calorific capacity (J/kg/K) of the i-th global species at temperature
◆ data_file_name
char* data_file_name
Name of thermochemistry data file
◆ eh_gas_g
massic enthalpy (J/kg) of the i-th global secies at temperature th(j)
◆ ff
double ff[9]
◆ flamelet_c
int flamelet_c
◆ flamelet_dt
int flamelet_dt
◆ flamelet_hrr
int flamelet_hrr
◆ flamelet_ki
int flamelet_ki
◆ flamelet_library
cs_real_t* flamelet_library
pointer to flamelet library
◆ flamelet_omg_c
int flamelet_omg_c
◆ flamelet_rho
int flamelet_rho
◆ flamelet_species
int flamelet_species[CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES]
◆ flamelet_species_name
char flamelet_species_name[CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES][13]
flamelet species names
◆ flamelet_temp
int flamelet_temp
◆ flamelet_temp2
int flamelet_temp2
◆ flamelet_vis
int flamelet_vis
◆ flamelet_xr
int flamelet_xr
◆ flamelet_zm
int flamelet_zm
◆ flamelet_zvar
int flamelet_zvar
◆ fm
◆ fp2m
cs_field_t* fp2m
◆ frmel
double frmel
constant mixture fraction (EBU only)
◆ fs
mixing rate at the stoichiometry
◆ fsm
cs_field_t* fsm
◆ fsqm
cs_field_t* fsqm
◆ hh
double hh[9]
◆ hinfue
double hinfue
input mass enthalpy for fuel
◆ hinoxy
double hinoxy
input mass enthalpy for the oxidant
◆ hrr
cs_field_t* hrr
◆ hstoea
double hstoea
Infinitely fast 3-point chemistry model parameters
◆ ientgb
int ientgb
burned gas indicator (EBU and LW only)
◆ ientgf
int ientgf
fresh gas indicator (EBU and LW only)
◆ iic
int iic
rank of C in gas composition (base 1)
◆ iico2
int iico2
rank of CO2 in gas composition (base 1)
◆ iio2
int iio2
rank of O2 in gas composition (base 1)
◆ ikimid
int ikimid
Index (1-based) for flamelet on middle branch
◆ isoot
int isoot
soot production modeling flag
◆ lsp_fuel
double lsp_fuel
laminar smoke point length
◆ lw
Libby Williams parameters
◆ mode_fp2m
int mode_fp2m
Mixture fraction variance computation mode:
  • 0: variance transport equation (VTE)
  • 1: 2nd moment of mixture fraction transport equation (STE)
◆ n_atomic_species
number of atomic species
◆ n_gas_el_comp
int n_gas_el_comp
number of elementary gas components
◆ n_gas_fl
int n_gas_fl
Steady flamelet model parameters number of species in flamelet library YFUE YOXY YCO2 YH2O YCO YH2
◆ n_gas_species
int n_gas_species
number of global species
◆ n_reactions
int n_reactions
number of global reactions in gas phase
◆ n_tab_points
int n_tab_points
number of tabulation points
◆ nki
int nki
number of flamelets (strain rate)
◆ nlibvar
int nlibvar
number of variables in library
◆ npm
cs_field_t* npm
◆ nxr
int nxr
discretization of enthalpy defect
◆ nzm
int nzm
discretization of mixture fraction
◆ nzvar
int nzvar
discretization of variance
◆ omgc
cs_field_t* omgc
◆ oxyco2
composition of CO2 oxidants
◆ oxyh2o
composition of H2O oxidants
◆ oxyn2
composition of N2 oxidants
◆ pcigas
double pcigas
combustible reaction enthalpy (Lower Calorific Value)
◆ pvm
cs_field_t* pvm
◆ radiation_data_file_name
char* radiation_data_file_name
Name of radiation data file in case of SLFM
◆ radiation_library
cs_real_t* radiation_library
pointer to radiation library
◆ recvr
cs_field_t* recvr
◆ rho_library
cs_real_t* rho_library
pointer to density library, which is a subset of flamelet_library
◆ rosoot
double rosoot
soot density
◆ srrom
double srrom
sub-relaxation coefficient for the density: $\rho^{n+1}$\,=\,srrom\,$\rho^n$+(1-srrom)\,$\rho^{n+1}$ (hence, with a zero value, there is no sub-relaxation)
◆ t2m
cs_field_t* t2m
◆ t3m
cs_field_t* t3m
◆ t4m
cs_field_t* t4m
◆ tfh
double tfh[9][9]
◆ tgf
double tgf
fresh gas temperature (EBU and LW only)
◆ th
temperature in K
◆ tinfue
double tinfue
input temperature for fuel en K
◆ tinoxy
double tinoxy
input temperature for oxydant
◆ totki
cs_field_t* totki
◆ type
combustion model type
◆ use_janaf
bool use_janaf
use NIST-JANAF tables for enthalpy/temperature conversion
◆ wmolat
molar mass of atomic species
◆ wmole
molar mass of an elementary gas component
◆ wmolg
molar mass of global species
◆ xco2
double xco2
molar coefficient of CO2
◆ xh2o
double xh2o
molar coefficient of H2O
◆ xr
◆ xsoot
double xsoot
soot fraction production (isoot = 0)
◆ yfm
cs_field_t* yfm
◆ yfp2m
cs_field_t* yfp2m
◆ ygfm
cs_field_t* ygfm
◆ ym
