cs_combustion_gas.h File Reference
#include "base/cs_field.h"
+ Include dependency graph for cs_combustion_gas.h:
Classes
struct  cs_libby_williams_params_t
struct  cs_combustion_gas_model_t
Macros
#define CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES   25
#define CS_COMBUSTION_GAS_MAX_ATOMIC_SPECIES   5
#define CS_COMBUSTION_GAS_MAX_OXYDANTS   3
#define CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS   20
#define CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS   1
#define CS_COMBUSTION_GAS_MAX_TABULATION_POINTS   50
#define CS_COMBUSTION_GAS_MAX_DIRAC   5
Enumerations
enum  cs_combustion_gas_model_type_t {
  CS_COMBUSTION_GAS_NONE = -1 , CS_COMBUSTION_3PT_ADIABATIC = CS_COMBUSTION_3PT*100 , CS_COMBUSTION_3PT_PERMEATIC = CS_COMBUSTION_3PT*100 + 1 , CS_COMBUSTION_BSH_ADIABATIC = CS_COMBUSTION_3PT*100 + 2 ,
  CS_COMBUSTION_BSH_PERMEATIC = CS_COMBUSTION_3PT*100 + 3 , CS_COMBUSTION_SLFM_STEADY_ADIABATIC = CS_COMBUSTION_SLFM*100 , CS_COMBUSTION_SLFM_STEADY_PERMEATIC = CS_COMBUSTION_SLFM*100 + 1 , CS_COMBUSTION_SLFM_PROGRESS_ADIABATIC = CS_COMBUSTION_SLFM*100 + 2 ,
  CS_COMBUSTION_SLFM_PROGRESS_PERMEATIC = CS_COMBUSTION_SLFM*100 + 3 , CS_COMBUSTION_EBU_CONSTANT_ADIABATIC = CS_COMBUSTION_EBU*100 , CS_COMBUSTION_EBU_CONSTANT_PERMEATIC = CS_COMBUSTION_EBU*100 + 1 , CS_COMBUSTION_EBU_VARIABLE_ADIABATIC = CS_COMBUSTION_EBU*100 + 2 ,
  CS_COMBUSTION_EBU_VARIABLE_PERMEATIC = CS_COMBUSTION_EBU*100 + 3 , CS_COMBUSTION_LW_2PEAK_ADIABATIC = CS_COMBUSTION_LW*100 , CS_COMBUSTION_LW_2PEAK_PERMEATIC = CS_COMBUSTION_LW*100 + 1 , CS_COMBUSTION_LW_3PEAK_ADIABATIC = CS_COMBUSTION_LW*100 + 2 ,
  CS_COMBUSTION_LW_3PEAK_PERMEATIC = CS_COMBUSTION_LW*100 + 3 , CS_COMBUSTION_LW_4PEAK_ADIABATIC = CS_COMBUSTION_LW*100 + 4 , CS_COMBUSTION_LW_4PEAK_PERMEATIC = CS_COMBUSTION_LW*100 + 5
cs_combustion_gas_model_t * cs_combustion_gas_set_model (cs_combustion_gas_model_type_t type)
 Activate gas combustion model. More...
void cs_combustion_gas_set_thermochemical_data_file (const char *file_name)
 Set the thermochemical data file name. More...
void cs_combustion_gas_set_radiation_data_file (const char *file_name)
 Set the radiation data file name. More...
void cs_combustion_gas_setup (void)
 Specific setup operations for gas combustion models. More...
void cs_combustion_slfm_init_library (void)
 Initialize steady flamelet library. More...
void cs_combustion_gas_log_setup (void)
 Print the gas combustion module options to setup.log. More...
void cs_combustion_gas_add_variable_fields (void)
 Add variable fields for gas combustion models. More...
void cs_combustion_gas_add_property_fields (void)
 Add property fields for gas combustion models. More...
void cs_combustion_gas_yg2xye (const cs_real_t yg[], cs_real_t ye[], cs_real_t xe[])
 Compute molar and mass fractions of elementary species Ye, Xe (fuel, O2, CO2, H2O, N2) from global species Yg (fuel, oxidant, products) More...
cs_combustion_gas_model_t * cs_glob_combustion_gas_model
◆ CS_COMBUSTION_GAS_MAX_ATOMIC_SPECIES
Maximum number of atomic species
◆ CS_COMBUSTION_GAS_MAX_DIRAC
Maximum number of Dirac peaks
◆ CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS
Maximum number of elementary gas components
◆ CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS
Maximum number of global reactions in gas phase
◆ CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES
Maximum number of global species
◆ CS_COMBUSTION_GAS_MAX_OXYDANTS
Maximum number of oxydants
◆ CS_COMBUSTION_GAS_MAX_TABULATION_POINTS
Maximum number of tabulation points
◆ cs_combustion_gas_model_type_t
Gas combustion model
Enumerator
Infinitely fast 3-point combustion model, adiabatic
Infinitely fast 3-point combustion model, permeatic
Burke-Schumann infinitely 3-point combustion model, adiabatic
Burke-Schumann infinitely 3-point combustion model, permeatic
Steady laminar flamelet model, adiabatic conditions
Steady laminar flamelet model, enthalpy transport with heat loss
Flamelet/progress variable model, adiabatic conditions
Flamelet/progress variable model, enthalpy transport with heat loss
Eddy Break Up pre-mixed flame combustion model, adiabatic conditions at constant richness
Eddy Break Up pre-mixed flame combustion model, adiabatic conditions at variable richness
Libby-Williams pre-mixed flame combustion, two peak model with adiabatic conditions
Libby-Williams pre-mixed flame combustion, two peak model with permeatic conditions
Libby-Williams pre-mixed flame combustion, three peak model with adiabatic conditions
Libby-Williams pre-mixed flame combustion, three peak model with permeatic conditions
Libby-Williams pre-mixed flame combustion, four peak model with adiabatic conditions
Libby-Williams pre-mixed flame combustion, four peak model with permeatic conditions
◆ cs_combustion_gas_add_property_fields()
void cs_combustion_gas_add_property_fields ( void  )
◆ cs_combustion_gas_add_variable_fields()
void cs_combustion_gas_add_variable_fields ( void  )
◆ cs_combustion_gas_log_setup()
void cs_combustion_gas_log_setup ( void  )
◆ cs_combustion_gas_set_model()
cs_combustion_gas_model_t * cs_combustion_gas_set_model ( cs_combustion_gas_model_type_t  type)
[in]typegas combustion model type
pointer to gas combustion model structure.
Steady flamelet model
◆ cs_combustion_gas_set_radiation_data_file()
void cs_combustion_gas_set_radiation_data_file ( const char *  file_name)
[in]file_namename of the file.
◆ cs_combustion_gas_set_thermochemical_data_file()
void cs_combustion_gas_set_thermochemical_data_file ( const char *  file_name)
◆ cs_combustion_gas_setup()
void cs_combustion_gas_setup ( void  )
◆ cs_combustion_gas_yg2xye()
void cs_combustion_gas_yg2xye ( const cs_real_t  yg[],
cs_real_t  ye[],
cs_real_t  xe[]
[in]ygglobal mass fraction
[out]yeelementary mass fraction
[out]xeelementary molar fraction
◆ cs_combustion_slfm_init_library()
void cs_combustion_slfm_init_library ( void  )
◆ cs_glob_combustion_gas_model
cs_combustion_gas_model_t* cs_glob_combustion_gas_model
extern
Combustion model parameters structure
