cs_gwf_tpf.h File Reference
+ Include dependency graph for cs_gwf_tpf.h:
cs_gwf_tpf_t * cs_gwf_tpf_create (cs_gwf_model_type_t model)
 Allocate and initialize the model context structure for two-phase flows in a porous media. More...
void cs_gwf_tpf_free (cs_gwf_tpf_t **p_tpf)
 Free the context structure associated to the modelling of two-phase flows in a porous media. More...
void cs_gwf_tpf_define_relax_pty_by_value (cs_gwf_tpf_t *tpf, double val)
 Define the relaxation property by value and set this value. More...
cs_xdef_t * cs_gwf_tpf_define_relax_pty_by_time_func (cs_gwf_tpf_t *tpf, cs_time_func_t *func, void *func_context)
void cs_gwf_tpf_log_setup (cs_gwf_tpf_t *tpf)
 Log the setup related to the model context of two-phase flows. Common to the different sub-models relying on two-phase flows. More...
void cs_gwf_tpf_init (cs_gwf_tpf_t *tpf, cs_property_type_t perm_type)
 Initialize the model context according to the settings done inside the function cs_user_model() Case of a two-phase flows model in porous media. More...
void cs_gwf_tpf_init_setup (cs_flag_t post_flag, cs_gwf_tpf_t *tpf)
 Initial setup stage for two-phase flows in porous media. At this stage, all soils have been defined and equation parameters are set. Case of a miscible or immiscible model. More...
void cs_gwf_tpf_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_flag_t flag, cs_gwf_tpf_t *tpf)
 Last setup stage in the case of two-phase flows in a porous media (miscible or immiscible case) More...
void cs_gwf_tpf_init_values (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_gwf_tpf_t *tpf)
void cs_gwf_tpf_compute (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step, cs_flag_t option_flag, cs_gwf_tpf_t *tpf)
 Compute the new state for the groundwater flows module. Case of two-phase flows in porous media. More...
void cs_gwf_tpf_current_to_previous (const cs_cdo_connect_t *connect, cs_gwf_tpf_t *tpf)
 Operate a "current to previous" step on fields or arrays which have at least a storage of the previous step (time t^n when computing t^{n+1}) More...
void cs_gwf_tpf_update (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, double time_eval, cs_flag_t option_flag, cs_gwf_tpf_t *tpf)
 Perform the update step in the case of a two-phase flow model in porous media (miscible or immiscible). To operate a "current to previous" step, one has to call the dedicated function cs_gwf_tpf_current_to_previous() More...
void cs_gwf_tpf_extra_op (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *ts, cs_flag_t post_flag, cs_gwf_tpf_t *tpf)
 Predefined extra-operations for the groundwater flow module in case of miscible or immiscible two-phase flows in porous media. More...
void cs_gwf_tpf_extra_post (int mesh_id, cs_lnum_t n_cells, const cs_lnum_t cell_ids[], cs_flag_t post_flag, const cs_property_t *abs_perm, const cs_gwf_tpf_t *tpf, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step)
 Predefined post-processing output for the groundwater flow module in case of saturated two-phase flows (tpf) in porous media. More...
◆ cs_gwf_tpf_compute()
void cs_gwf_tpf_compute ( const cs_mesh_t *  mesh,
const cs_cdo_quantities_t *  cdoq,
const cs_time_step_t *  time_step,
cs_gwf_tpf_t *  tpf
[in]option_flagcalculation option related to the GWF module
[in,out]tpfpointer to the model context structure
◆ cs_gwf_tpf_create()
cs_gwf_tpf_t * cs_gwf_tpf_create ( cs_gwf_model_type_t  model)
[in]modeltype of physical modelling
a pointer to a new allocated structure
◆ cs_gwf_tpf_current_to_previous()
void cs_gwf_tpf_current_to_previous ( const cs_cdo_connect_t *  connect,
cs_gwf_tpf_t *  tpf
[in,out]tpfpointer to the casted model context
◆ cs_gwf_tpf_define_relax_pty_by_time_func()
cs_xdef_t * cs_gwf_tpf_define_relax_pty_by_time_func ( cs_gwf_tpf_t *  tpf,
cs_time_func_t *  func,
void *  func_context
[in]tpfpointer to the model context structure
[in]funcfunction pointer to a time function
[in]func_contextcontext related to this function
a pointer to the created definition (cs_xdef_t structure)
◆ cs_gwf_tpf_define_relax_pty_by_value()
void cs_gwf_tpf_define_relax_pty_by_value ( cs_gwf_tpf_t *  tpf,
double  val
[in]valreference value used to set the relaxation property
◆ cs_gwf_tpf_extra_op()
void cs_gwf_tpf_extra_op ( const cs_cdo_connect_t *  connect,
const cs_time_step_t *  ts,
cs_gwf_tpf_t *  tpf
[in]tspointer to a cs_time_step_t struct.
[in]post_flagrequested quantities to be postprocessed
◆ cs_gwf_tpf_extra_post()
void cs_gwf_tpf_extra_post ( int  mesh_id,
cs_lnum_t  n_cells,
const cs_property_t *  abs_perm,
const cs_gwf_tpf_t *  tpf,
[in]mesh_idid of the output mesh for the current call
[in]n_cellslocal number of cells of post_mesh
[in]cell_idslist of cells (0 to n-1)
[in]post_flagflag gathering quantities to postprocess
[in]abs_permproperty for the absolute permeability
[in]connectpointer to additional connectivities for CDO
[in]cdoqpointer to additional mesh quantities for CDO
[in]time_steppointer to a cs_time_step_t struct.
◆ cs_gwf_tpf_finalize_setup()
void cs_gwf_tpf_finalize_setup ( const cs_cdo_connect_t *  connect,
cs_flag_t  flag,
cs_gwf_tpf_t *  tpf
[in]flagoptional settings for the module
◆ cs_gwf_tpf_free()
void cs_gwf_tpf_free ( cs_gwf_tpf_t **  p_tpf)
[in,out]p_tpfpointer of pointer to the model context structure
◆ cs_gwf_tpf_init()
void cs_gwf_tpf_init ( cs_gwf_tpf_t *  tpf,
[in,out]perm_typetype of permeability to handle
◆ cs_gwf_tpf_init_setup()
void cs_gwf_tpf_init_setup ( cs_flag_t  post_flag,
cs_gwf_tpf_t *  tpf
[in]post_flagoptional postprocessing request(s)
◆ cs_gwf_tpf_init_values()
void cs_gwf_tpf_init_values ( const cs_cdo_connect_t *  connect,
cs_gwf_tpf_t *  tpf
◆ cs_gwf_tpf_log_setup()
void cs_gwf_tpf_log_setup ( cs_gwf_tpf_t *  tpf)
◆ cs_gwf_tpf_update()
void cs_gwf_tpf_update ( const cs_mesh_t *  mesh,
double  time_eval,
cs_gwf_tpf_t *  tpf
[in]time_evaltime at which properties are evaluated if needed
[in,out]tpfpointer to a TPF model context
