cs_gwf_tpf_t Struct Reference
Structure to handle the modelling of miscible or immiscible two-phase flows in a porous media. More...
#include <cs_gwf_hydraulic_model.h>
+ Collaboration diagram for cs_gwf_tpf_t:
Public Attributes
Equations and system of equations
cs_equation_t * w_eq
cs_equation_t * h_eq
cs_equation_param_t * b01_w_eqp
cs_equation_param_t * b10_h_eqp
cs_equation_system_t * system
Darcy (advection) fields
cs_gwf_darcy_flux_t * l_darcy
cs_gwf_darcy_flux_t * g_darcy
Properties related to the model
cs_property_t * krl_pty
cs_property_t * krg_pty
cs_property_t * lsat_pty
cs_property_t * lcap_pty
cs_property_t * time_wc_pty
cs_property_t * diff_wl_pty
cs_property_t * time_hc_pty
cs_property_t * diff_hc_pty
cs_property_t * time_hl_pty
cs_property_t * diff_hl_pty
cs_property_t * diff_g_pty
Additional fields
cs_field_t * c_pressure
cs_field_t * l_pressure
cs_field_t * g_pressure
cs_field_t * l_saturation
cs_field_t * l_rho_h
cs_field_t * g_rho_h
Additional arrays
cs_real_t * srct_w_array
cs_real_t * srct_h_array
cs_real_t * lsat_pre_array
Physical model parameters
bool is_miscible
cs_real_t l_mass_density
cs_real_t l_viscosity
cs_real_t g_viscosity
cs_real_t l_diffusivity_h
cs_real_t h_molar_mass
cs_real_t ref_temperature
cs_real_t henry_constant
Numerical parameters
cs_gwf_tpf_solver_type_t solver_type
 Type of solver considered to solve the system of equations (choice of main unknowns and strategy of resolution (coupled/segregated)) More...
bool enforce_pg_positivity
 Apply a rescaling on the gas pressure to avoid a negative value. More...
cs_gwf_tpf_approx_type_t approx_type
 type of approximation used for the computation of diffusion, unsteady coefficients More...
double cell_weight
 weight associated to the cell value w.r.t. to the values at vertices when a CS_GWF_TPF_APPROX_PC_CELL_VERTEX_AVERAGE choice is set for 'approx_type'. If the value is < 0 or > 1, then the default settings is kept. More...
double upwind_weight
 weight associated to the upwind value w.r.t. to the centered value There is no effect when CS_GWF_TPF_APPROX_VERTEX_SUBCELL is chosen to approximate coefficients. If the value is < 0 or > 1, then the default settings is kept. More...
cs_param_nl_algo_t nl_algo_type
int nl_algo_verbosity
cs_param_convergence_t nl_cvg_param
cs_iter_algo_param_aac_t anderson_param
cs_iter_algo_t * nl_algo
The model follows what is depicted in "Finite volume approximation of a diffusion-dissolution model and application to nuclear waste storage" O. Angelini, C. Chavant, E. Chénier, R. Eymard and S. Granet in Mathematics and Computers in Simulation (2011), 81 (10), pp. 2001–2017
Main assumptions are:
  • No water in the gaseous phase
  • Incompressibility of the liquid phase
  • Hydrogen pressure is given by the "perfect gas" law in the gas phase and the Henry's law in the liquid phase (when a miscible model is used) The two primitive variables are the capillarity and liquid pressures with a specific treatment in the saturated case (cf. the cited article or Angelini's PhD thesis)
Notations are the following :
  • Two phases: Liquid phase denoted by "l" and gaseous phase denoted by "g"
  • indice "c" refers to the capillarity pressure
  • Two components: water denoted by "w" and a gaseous component (let's say hydrogen) denoted by "h". The gaseous component is present in the two phases whereas water is only considered in the liquid phase.
Member Data Documentation
◆ anderson_param
anderson_param
Set of parameters to drive the Anderson acceleration (useful if the type of non-linear algorithm is set to the Anderson acceleration).
◆ approx_type
approx_type
◆ b01_w_eqp
b01_w_eqp
Parameters associated to the (0,1) block in the system of equations. Water conservation w.r.t. the capillarity pressure.
◆ b10_h_eqp
b10_h_eqp
Parameters associated to the (1,0) block in the system of equations. Conservation of the hydrogen w.r.t. the capillarity pressure.
◆ c_pressure
c_pressure
Pointer to a cs_field_t structure named "capillarity_pressure". Capillarity pressure $ P_c = P_g - P_l $
◆ cell_weight
cell_weight
◆ diff_g_pty
cs_property_t* diff_g_pty
Property related to the relative permeability in the liquid phase
◆ diff_hc_pty
cs_property_t* diff_hc_pty
◆ diff_hl_pty
cs_property_t* diff_hl_pty
◆ diff_wl_pty
cs_property_t* diff_wl_pty
◆ enforce_pg_positivity
◆ g_darcy
g_darcy
Pointer to a cs_gwf_darcy_flux_t structure. Darcy advective flux in the gas phase
◆ g_pressure
g_pressure
Pointer to a cs_field_t structure named "gas_pressure". Pressure in the gas phase is denoted by $ P_g $.
◆ g_rho_h
g_rho_h
Pointer to a cs_field_t structure. Property related to the mass density in the gas phase of the component mainly present in the gas phase (e.g. H2). The component present in the gas phase is ruled by the perfect gas law.
◆ g_viscosity
g_viscosity
Viscosity in the gas phase (assumed to be constant) in Pa.s
◆ h_eq
h_eq
Equation of mass conservation for (di)hydrogen. Hydrogen can be present in the liquid or in the gaseous phase. This corresponds to the M_10 and M_11 blocks in the system of equations along with the b_h right-hand side
◆ h_molar_mass
h_molar_mass
Molar mass of the main component in the gas phase (e.g. hydrogen) in kg.mol^-1
◆ henry_constant
henry_constant
Value of the Henry constant used in the Henry's law. Setting a very low value for this constant enables the model to degenerate into an immiscible model.
◆ is_miscible
is_miscible
true or false. Some simplifications can be done if immiscible.
◆ krg_pty
krg_pty
Property related to the relative permeability in the gas phase
◆ krl_pty
krl_pty
◆ l_darcy
l_darcy
Pointer to a cs_gwf_darcy_flux_t structure. Darcy advective flux in the liquid phase
◆ l_diffusivity_h
l_diffusivity_h
Molecular diffusivity of the hydrogen in the liquid phase in m^2.s^-1
◆ l_mass_density
l_mass_density
Mass density in the liquid phase. With the model assumptions, this corresponds to the mass density of the main component in the liquid phase (e.g. water) in kg.m^-3
◆ l_pressure
l_pressure
Pointer to a cs_field_t structure named "liquid_pressure". Pressure in the liquid phase is denoted by $ P_l $.
◆ l_rho_h
l_rho_h
Pointer to a cs_field_t structure. Property related to the mass density in the liquid phase of the component mainly present in the gas phase (e.g. H2). The component present in the liquid comes from the dissolution process (ruled by the Henry law)
◆ l_saturation
l_saturation
Pointer to a cs_field_t structure. Liquid saturation at cells. This quantity is denoted by $ S_l $ and is defined by the soil model
◆ l_viscosity
l_viscosity
Viscosity in the liquid phase (assumed to be constant) in Pa.s
◆ lcap_pty
lcap_pty
Property related to the liquid capacity (derivative of the liquid saturation w.r.t. the capillarity pressure)
◆ lsat_pre_array
lsat_pre_array
Values of the liquid saturation at the previous time step when an approximation CS_GWF_TPF_APPROX_VERTEX_SUBCELL has been chosen Size = c2v index size
◆ lsat_pty
lsat_pty
Property related to the liquid saturation
◆ nl_algo
nl_algo
Structure used to manage the non-linearities
◆ nl_algo_type
nl_algo_type
Type of algorithm to solve the non-linearities
◆ nl_algo_verbosity
nl_algo_verbosity
Level of verbosity for the algorithm solving the non-linearities
◆ nl_cvg_param
nl_cvg_param
Set of parameters to drive the convergence of the non-linear solver
◆ ref_temperature
ref_temperature
Reference temperature used in the "perfect gas" law (this is used when no thermal equation is solved). One expects a temperature in Kelvin.
◆ solver_type
solver_type
◆ srct_h_array
srct_h_array
Values of the source terms for the hydrogen conservation equation. Size = n_vertrices
◆ srct_w_array
srct_w_array
Values of the source terms for the water conservation equation. Size = n_vertices
◆ system
system
System of equations (w_eq, h_eq and the cross-terms defined in the related cs_equation_param_t structures) used for the coupled approach
◆ time_hc_pty
cs_property_t* time_hc_pty
◆ time_hl_pty
cs_property_t* time_hl_pty
◆ time_wc_pty
cs_property_t* time_wc_pty
◆ upwind_weight
upwind_weight
◆ w_eq
w_eq
Equation of mass conservation for water. Only the liquid phase is considered. One assumes no water vapour in the gaseous phase. This corresponds to the M_00 and M_01 blocks in the system of equations and to the b_w right-hand side.
