cs_combustion_gas.cpp File Reference
#include <stdarg.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_assert.h"
#include "base/cs_array.h"
#include "base/cs_base.h"
#include "base/cs_parameters_check.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_physical_properties.h"
#include "base/cs_restart_default.h"
#include "gui/cs_gui_specific_physics.h"
#include "pprt/cs_combustion_model.h"
#include "rayt/cs_rad_transfer.h"
#include "cogz/cs_combustion_gas.h"
+ Include dependency graph for cs_combustion_gas.cpp:
cs_combustion_gas_model_t * cs_combustion_gas_set_model (cs_combustion_gas_model_type_t type)
 Activate gas combustion model. More...
void cs_combustion_gas_set_thermochemical_data_file (const char *file_name)
 Set the thermochemical data file name. More...
void cs_combustion_gas_set_radiation_data_file (const char *file_name)
void cs_combustion_slfm_init_library (void)
 Initialize steady flamelet library. More...
void cs_combustion_gas_setup (void)
 Specific setup operations for gas combustion models. More...
void cs_combustion_gas_log_setup (void)
 Print the gas combustion module options to setup.log. More...
void cs_combustion_gas_add_variable_fields (void)
 Add variable fields for gas combustion models. More...
void cs_combustion_gas_add_property_fields (void)
 Add property fields for gas combustion models. More...
void cs_combustion_gas_yg2xye (const cs_real_t yg[], cs_real_t ye[], cs_real_t xe[])
 Compute molar and mass fractions of elementary species Ye, Xe (fuel, O2, CO2, H2O, N2) from global species Yg (fuel, oxidant, products) More...
cs_combustion_gas_model_t * cs_glob_combustion_gas_model = nullptr
Gas combustion model.
◆ cs_combustion_gas_add_property_fields()
void cs_combustion_gas_add_property_fields ( void  )
◆ cs_combustion_gas_add_variable_fields()
void cs_combustion_gas_add_variable_fields ( void  )
◆ cs_combustion_gas_log_setup()
void cs_combustion_gas_log_setup ( void  )
◆ cs_combustion_gas_set_model()
cs_combustion_gas_model_t * cs_combustion_gas_set_model ( cs_combustion_gas_model_type_t  type)
[in]typegas combustion model type
pointer to gas combustion model structure.
Steady flamelet model
◆ cs_combustion_gas_set_radiation_data_file()
void cs_combustion_gas_set_radiation_data_file ( const char *  file_name)
Set the radiation data file name.
[in]file_namename of the file.
◆ cs_combustion_gas_set_thermochemical_data_file()
void cs_combustion_gas_set_thermochemical_data_file ( const char *  file_name)
◆ cs_combustion_gas_setup()
void cs_combustion_gas_setup ( void  )
◆ cs_combustion_gas_yg2xye()
void cs_combustion_gas_yg2xye ( const cs_real_t  yg[],
cs_real_t  ye[],
cs_real_t  xe[]
[in]ygglobal mass fraction
[out]yeelementary mass fraction
[out]xeelementary molar fraction
◆ cs_combustion_slfm_init_library()
void cs_combustion_slfm_init_library ( void  )
◆ cs_glob_combustion_gas_model
cs_combustion_gas_model_t* cs_glob_combustion_gas_model = nullptr
Combustion model parameters structure
