cs_coal.cpp File Reference
Coal combustion model. More...
#include <stdarg.h>
#include "bft/bft_printf.h"
#include "cdo/cs_equation_param.h"
#include "base/cs_field.h"
#include "base/cs_parameters_check.h"
#include "base/cs_physical_properties.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_post.h"
#include "comb/cs_coal.h"
+ Include dependency graph for cs_coal.cpp:
cs_coal_model_type_t cs_coal_model_get_type (void)
 Return coal combustion model type. More...
cs_coal_model_t * cs_coal_model_set_model (cs_coal_model_type_t type)
 Activate coal combustion model. More...
void cs_coal_setup (void)
 Specific setup operations for pulverized coal combustion model. More...
void cs_combustion_coal_log_setup (void)
 Print pulverized combustion module options to setup.log. More...
void cs_coal_add_variable_fields (void)
 Add variable fields for pulverized coal combustion model. More...
void cs_coal_add_property_fields (void)
 Add property fields for pulverized coal combustion model. More...
void cs_coal_rad_transfer_st (const cs_field_t *f, cs_real_t *smbrs, cs_real_t *rovsdt)
 Take in account the radiative source terms in the particle equation of a given class for pulverized coal flame. More...
cs_coal_model_t * cs_glob_coal_model = nullptr
const double cs_coal_trefth = 25. + 273.15
const double cs_coal_prefth = 1.01325e5
const double cs_coal_volmol = 22.41e-3
const int cs_coal_atom_id_c = 0
const int cs_coal_atom_id_h = 1
const int cs_coal_atom_id_o = 2
const int cs_coal_atom_id_n = 3
const int cs_coal_atom_id_s = 4
const double cs_coal_epsilon = 1.e-8
◆ cs_coal_add_property_fields()
void cs_coal_add_property_fields ( void  )
◆ cs_coal_add_variable_fields()
void cs_coal_add_variable_fields ( void  )
◆ cs_coal_model_get_type()
cs_coal_model_type_t cs_coal_model_get_type ( void  )
type of active coal combustion model (CS_COMBUSTION_COAL_NONE if model not active)
◆ cs_coal_model_set_model()
cs_coal_model_t * cs_coal_model_set_model ( cs_coal_model_type_t  type)
pointer to coal combustion model structure.
[in]typecoal combustion model type
◆ cs_coal_rad_transfer_st()
void cs_coal_rad_transfer_st ( const cs_field_t *  f,
cs_real_t *  smbrs,
cs_real_t *  rovsdt
[in]fpointer to scalar field
[in,out]smbrsright and side (explicit ST contribution)
[in,out]rovsdtsystem diagonal (implicit ST contribution)
◆ cs_coal_setup()
void cs_coal_setup ( void  )
◆ cs_combustion_coal_log_setup()
void cs_combustion_coal_log_setup ( void  )
◆ cs_coal_atom_id_c
id for C in wmolat
◆ cs_coal_atom_id_h
id for H in wmolat
◆ cs_coal_atom_id_n
id for N in wmolat
◆ cs_coal_atom_id_o
id for O in wmolat
◆ cs_coal_atom_id_s
id for S in wmolat
◆ cs_coal_epsilon
◆ cs_coal_prefth
reference pressure for molar volume
◆ cs_coal_trefth
‍ molar volume under normal pressure and temperature conditions
(1 atmosphere, 0 degres C) in m-3
reference temperature for molar volume
◆ cs_coal_volmol
molar volume under normal pressure and temperature conditions (1 atmosphere, 0 $\text{\degresC}$) in $m^{-3}$
◆ cs_glob_coal_model
cs_coal_model_t* cs_glob_coal_model = nullptr
Coal combustion model parameters structure
