cs_coal.h File Reference
#include "base/cs_field.h"
+ Include dependency graph for cs_coal.h:
Classes
struct  cs_coal_model_t
Macros
#define CS_COMBUSTION_MAX_COALS   5
#define CS_COMBUSTION_COAL_MAX_OXYDANTS   3
#define CS_COMBUSTION_COAL_MAX_GLOBAL_SPECIES   25
#define CS_COMBUSTION_COAL_MAX_ATOMIC_SPECIES   5
#define CS_COMBUSTION_MAX_CLASSES_PER_COAL   20
#define CS_COMBUSTION_COAL_MAX_CLASSES
#define CS_COMBUSTION_COAL_MAX_ELEMENTARY_COMPONENTS   20
#define CS_COMBUSTION_COAL_MAX_TABULATION_POINTS   8
#define CS_COMBUSTION_COAL_MAX_SOLIDS   CS_COMBUSTION_MAX_COALS * 4
Enumerations
enum  cs_coal_model_type_t { CS_COMBUSTION_COAL_NONE = -1 , CS_COMBUSTION_COAL_STANDARD = 0 , CS_COMBUSTION_COAL_WITH_DRYING = 1 }
cs_coal_model_type_t cs_coal_model_get_type (void)
 Return coal combustion model type. More...
cs_coal_model_t * cs_coal_model_set_model (cs_coal_model_type_t type)
 Activate coal combustion model. More...
void cs_coal_setup (void)
 Specific setup operations for pulverized coal combustion model. More...
void cs_combustion_coal_log_setup (void)
 Print pulverized combustion module options to setup.log. More...
void cs_coal_add_variable_fields (void)
 Add variable fields for pulverized coal combustion model. More...
void cs_coal_add_property_fields (void)
 Add property fields for pulverized coal combustion model. More...
void cs_coal_mass_transfer (void)
 Compute mass transfer terms between the continous and dispersed phase. More...
void cs_coal_rad_transfer_st (const cs_field_t *f, cs_real_t *smbrs, cs_real_t *rovsdt)
 Take in account the radiative source terms in the particle equation of a given class for pulverized coal flame. More...
cs_coal_model_t * cs_glob_coal_model
const double cs_coal_trefth
const double cs_coal_prefth
const double cs_coal_volmol
const int cs_coal_atom_id_c
const int cs_coal_atom_id_h
const int cs_coal_atom_id_o
const int cs_coal_atom_id_n
const int cs_coal_atom_id_s
const double cs_coal_epsilon
◆ CS_COMBUSTION_COAL_MAX_ATOMIC_SPECIES
Maximum number of atomic species
◆ CS_COMBUSTION_COAL_MAX_CLASSES
Value:
Definition: cs_coal.h:62
Definition: cs_coal.h:50
Maximum total number of coal classes
◆ CS_COMBUSTION_COAL_MAX_ELEMENTARY_COMPONENTS
Maximum number of elementary gas components
◆ CS_COMBUSTION_COAL_MAX_GLOBAL_SPECIES
Maximum number of global species
◆ CS_COMBUSTION_COAL_MAX_OXYDANTS
Maximum number of oxydants
◆ CS_COMBUSTION_COAL_MAX_SOLIDS
Maximum number of solid constituants
◆ CS_COMBUSTION_COAL_MAX_TABULATION_POINTS
Maximum number of tabulation points
◆ CS_COMBUSTION_MAX_CLASSES_PER_COAL
Maximum number of coal classes per coal
◆ CS_COMBUSTION_MAX_COALS
Maximum number of coals
◆ cs_coal_model_type_t
Coal combustion model type
Enumerator
◆ cs_coal_add_property_fields()
void cs_coal_add_property_fields ( void  )
◆ cs_coal_add_variable_fields()
void cs_coal_add_variable_fields ( void  )
◆ cs_coal_mass_transfer()
void cs_coal_mass_transfer ( void  )
◆ cs_coal_model_get_type()
cs_coal_model_type_t cs_coal_model_get_type ( void  )
type of active coal combustion model (CS_COMBUSTION_COAL_NONE if model not active)
◆ cs_coal_model_set_model()
cs_coal_model_t * cs_coal_model_set_model ( cs_coal_model_type_t  type)
pointer to coal combustion model structure.
[in]typecoal combustion model type
◆ cs_coal_rad_transfer_st()
void cs_coal_rad_transfer_st ( const cs_field_t *  f,
cs_real_t *  smbrs,
cs_real_t *  rovsdt
[in]fpointer to scalar field
[in,out]smbrsright and side (explicit ST contribution)
[in,out]rovsdtsystem diagonal (implicit ST contribution)
◆ cs_coal_setup()
void cs_coal_setup ( void  )
◆ cs_combustion_coal_log_setup()
void cs_combustion_coal_log_setup ( void  )
◆ cs_coal_atom_id_c
extern
id for C in wmolat
◆ cs_coal_atom_id_h
extern
id for H in wmolat
◆ cs_coal_atom_id_n
extern
id for N in wmolat
◆ cs_coal_atom_id_o
extern
id for O in wmolat
◆ cs_coal_atom_id_s
extern
id for S in wmolat
◆ cs_coal_epsilon
extern
◆ cs_coal_prefth
extern
reference pressure for molar volume
◆ cs_coal_trefth
extern
‍ molar volume under normal pressure and temperature conditions
(1 atmosphere, 0 degres C) in m-3
reference temperature for molar volume
◆ cs_coal_volmol
extern
molar volume under normal pressure and temperature conditions (1 atmosphere, 0 $\text{\degresC}$) in $m^{-3}$
◆ cs_glob_coal_model
cs_coal_model_t* cs_glob_coal_model
extern
Combustion model parameters structure
Coal combustion model parameters structure
