cs_cdofb_navsto.h File Reference
#include "base/cs_base.h"
#include "cdo/cs_cdo_quantities.h"
#include "base/cs_field.h"
#include "cdo/cs_iter_algo.h"
#include "base/cs_math.h"
#include "alge/cs_matrix.h"
#include "mesh/cs_mesh.h"
#include "cdo/cs_navsto_param.h"
#include "base/cs_time_plot.h"
#include "cdo/cs_sdm.h"
+ Include dependency graph for cs_cdofb_navsto.h:
Classes
struct  cs_cdofb_navsto_builder_t
 Structure storing additional arrays related to the building of the Navier-Stokes system. More...
Typedefs
typedef void() cs_cdofb_navsto_source_t(const cs_navsto_param_t *nsp, const cs_cell_mesh_t *cm, const cs_cdofb_navsto_builder_t *nsb, cs_cell_sys_t *csys)
 Compute and add a source term to the local RHS. This is a special treatment to enable source involving face DoFs and potentially the local discrete divergence/gradient operators. In the standard case, only the cell DoFs are involved. Examples are gravity term or Bousinesq term(s) More...
Enumerations
enum  cs_cdofb_navsto_boussinesq_type_t { CS_CDOFB_NAVSTO_BOUSSINESQ_CELL_DOF , CS_CDOFB_NAVSTO_BOUSSINESQ_FACE_DOF }
 Type of algorithm to compute the Boussinesq approximation. More...
void cs_cdofb_navsto_set_boussinesq_algo (cs_cdofb_navsto_boussinesq_type_t type)
 Set the way to compute the Boussinesq approximation. More...
cs_cdofb_navsto_builder_t cs_cdofb_navsto_create_builder (const cs_navsto_param_t *nsp, const cs_cdo_connect_t *connect)
 Create and allocate a local NavSto builder when Fb schemes are used. More...
void cs_cdofb_navsto_free_builder (cs_cdofb_navsto_builder_t *nsb)
 Destroy the given cs_cdofb_navsto_builder_t structure. More...
void cs_cdofb_navsto_define_builder (cs_real_t t_eval, const cs_navsto_param_t *nsp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, const cs_cdo_bc_face_t *pr_bc, const cs_boundary_type_t *bf_type, cs_cdofb_navsto_builder_t *nsb)
 Set the members of the cs_cdofb_navsto_builder_t structure. More...
void cs_cdofb_navsto_mass_flux (const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, const cs_real_t *face_vel, cs_real_t *mass_flux)
 Compute the mass flux playing the role of the advection field in the Navier-Stokes equations One considers the mass flux across primal faces which relies on the velocity vector defined on each face. More...
double cs_cdofb_navsto_cell_divergence (const cs_lnum_t c_id, const cs_cdo_quantities_t *quant, const cs_adjacency_t *c2f, const cs_real_t *f_vals)
 Compute the divergence in a cell of a vector-valued array defined at faces (values are defined both at interior and border faces). Variant based on the usage of cs_cdo_quantities_t structure. More...
void cs_cdofb_navsto_compute_face_pressure (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, const cs_navsto_param_t *nsp, const cs_real_t *p_cell, cs_real_t *p_face)
 Compute an estimation of the pressure at faces. More...
void cs_cdofb_navsto_add_grad_div (short int n_fc, const cs_real_t zeta, const cs_real_t div[], cs_sdm_t *mat)
 Add the grad-div part to the local matrix (i.e. for the current cell) More...
void cs_cdofb_navsto_init_pressure (const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, cs_field_t *pr)
 Initialize the pressure values. More...
void cs_cdofb_navsto_init_face_pressure (const cs_navsto_param_t *nsp, const cs_cdo_connect_t *connect, const cs_time_step_t *ts, cs_real_t *pr_f)
 Initialize the pressure values when the pressure is defined at faces. More...
void cs_cdofb_navsto_rescale_pressure_to_ref (const cs_navsto_param_t *nsp, const cs_cdo_quantities_t *quant, cs_real_t values[])
 Update the pressure field in order to get a field with a mean-value equal to the reference value. More...
void cs_cdofb_navsto_set_zero_mean_pressure (const cs_cdo_quantities_t *quant, cs_real_t values[])
 Update the pressure field in order to get a field with a zero-mean average. More...
void cs_cdofb_navsto_extra_op (const cs_navsto_param_t *nsp, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *ts, cs_time_plot_t *time_plotter, const cs_adv_field_t *adv_field, const cs_real_t *mass_flux, const cs_real_t *p_cell, const cs_real_t *u_cell, const cs_real_t *u_face)
 Perform extra-operation related to Fb schemes when solving Navier-Stokes. Computation of the following quantities according to post-processing flags beeing activated. More...
void cs_cdofb_block_dirichlet_alge (short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account a Dirichlet BCs on the three velocity components. For instance for a velocity inlet boundary or a wall Handle the velocity-block in the global algebraic system in case of an algebraic technique. This prototype matches the function pointer cs_cdo_apply_boundary_t. More...
void cs_cdofb_block_dirichlet_pena (short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account a Dirichlet BCs on the three velocity components. For instance for a velocity inlet boundary or a wall Handle the velocity-block in the global algebraic system in case of a penalization technique (with a large coefficient). One assumes that static condensation has been performed and that the velocity-block has size 3*n_fc This prototype matches the function pointer cs_cdo_apply_boundary_t. More...
void cs_cdofb_block_dirichlet_weak (short int fb, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account a Dirichlet BCs on the three velocity components. For instance for a velocity inlet boundary or a wall Handle the velocity-block in the global algebraic system in case of a weak penalization technique (Nitsche). One assumes that static condensation has not been performed yet and that the velocity-block has size 3*(n_fc + 1) This prototype matches the function pointer cs_cdo_apply_boundary_t. More...
void cs_cdofb_block_dirichlet_wsym (short int fb, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account a Dirichlet BCs on the three velocity components. For instance for a velocity inlet boundary or a wall Handle the velocity-block in the global algebraic system in case of a weak penalization technique (symmetrized Nitsche). One assumes that static condensation has not been performed yet and that the velocity-block has size 3*(n_fc + 1) This prototype matches the function pointer cs_cdo_apply_boundary_t. More...
void cs_cdofb_symmetry (short int fb, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account a boundary defined as 'symmetry' (treated as a sliding BCs on the three velocity components.) A weak penalization technique (symmetrized Nitsche) is used. One assumes that static condensation has not been performed yet and that the velocity-block has (n_fc + 1) blocks of size 3x3. This prototype matches the function pointer cs_cdo_apply_boundary_t. More...
void cs_cdofb_fixed_wall (short int fb, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account a wall BCs by a weak enforcement using Nitsche technique plus a symmetric treatment. This prototype matches the function pointer cs_cdo_apply_boundary_t. More...
void cs_cdofb_prescribed_smooth_wall (short int fb, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Take into account a wall BCs by a weak enforcement using Nitsche technique. This prototype matches the function pointer cs_cdo_apply_boundary_t. More...
cs_sles_convergence_state_t cs_cdofb_navsto_nl_algo_cvg (cs_param_nl_algo_t nl_algo_type, const cs_real_t *pre_iterate, cs_real_t *cur_iterate, cs_iter_algo_t *algo)
 Test if one has to do one more non-linear iteration. Test if performed on the relative norm on the increment between two iterations. More...
void cs_cdofb_navsto_set_gravity_func (const cs_navsto_param_t *nsp, cs_cdofb_navsto_source_t **p_func)
 Set the function pointer computing the source term in the momentum equation related to the gravity effect (hydrostatic pressure or the Boussinesq approximation) More...
void cs_cdofb_navsto_gravity_term (const cs_navsto_param_t *nsp, const cs_cell_mesh_t *cm, const cs_cdofb_navsto_builder_t *nsb, cs_cell_sys_t *csys)
 Take into account the gravity effects. Compute and add the source term to the local RHS. This is a special treatment since of face DoFs are involved contrary to the standard case where only the cell DoFs is involved. More...
void cs_cdofb_navsto_boussinesq_at_cell (const cs_navsto_param_t *nsp, const cs_cell_mesh_t *cm, const cs_cdofb_navsto_builder_t *nsb, cs_cell_sys_t *csys)
 Take into account the buoyancy force with the Boussinesq approx. Compute and add the source term to the local RHS. This is the standard case where the face DoFs are used for the constant part rho0 . g[] and only the cell DoFs are involved for the remaining part (the Boussinesq approximation). More...
void cs_cdofb_navsto_boussinesq_at_face (const cs_navsto_param_t *nsp, const cs_cell_mesh_t *cm, const cs_cdofb_navsto_builder_t *nsb, cs_cell_sys_t *csys)
 Take into account the buoyancy force with the Boussinesq approx. Compute and add the source term to the local RHS. This way to compute the Boussinesq approximation relies only on DoFs at faces. This should enable to keep a stable (no velocity) in case of a stratified configuration. More...
void cs_cdofb_navsto_boussinesq_by_part (const cs_navsto_param_t *nsp, const cs_cell_mesh_t *cm, const cs_cdofb_navsto_builder_t *nsb, cs_cell_sys_t *csys)
void cs_cdofb_navsto_stream_source_term (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
 Get the source term for computing the stream function. This relies on the prototype associated to the generic function pointer cs_dof_func_t. More...
cs_cdo_balance_t * cs_cdofb_navsto_balance (const cs_navsto_param_t *nsp, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts, const cs_cdo_bc_face_t *pr_bc, const cs_boundary_type_t *bf_type, const cs_real_t *pr_c)
 Compute the balance for an NS system over the full computational domain between time t_cur and t_cur + dt_cur Case of Navier-Stokes system with CDO face-based scheme. More...
Typedef Documentation
◆ cs_cdofb_navsto_source_t
[in]nspset of parameters to handle the Navier-Stokes system
[in]nsbpointer to a builder structure for the NavSto system
[in,out]csyspointer to a cs_cell_sys_t structure
◆ cs_cdofb_navsto_boussinesq_type_t
Enumerator
Boussinesq approximation relyong on a cell contribution.
This algorithm uses cell DoFs for the Boussinesq part corresponding to rho0 * beta * (var[c_id] - var0) * g[] while the constant part equal to rho0 * g[] is built in order to be in balance with the pressure gradient (face DoF contributions).
Boussinesq approximation relyong on face contributions.
This algorithm uses only face DoFs for the Boussinesq approximation. For the constant part (rho0 * g[]) as well as the variable part rho0 * beta * (var[c_id] - var0) * g[] The aim is to be in balance with the pressure gradient
◆ cs_cdofb_block_dirichlet_alge()
void cs_cdofb_block_dirichlet_alge ( short int  f,
const cs_cell_mesh_t *  cm,
const cs_property_data_t *  pty,
cs_cell_builder_t *  cb,
cs_cell_sys_t *  csys
[in]fface id in the cell mesh numbering
[in]eqppointer to a cs_equation_param_t struct.
[in]cmpointer to a cellwise mesh structure
[in]ptypointer to a cs_property_data_t structure
[in,out]csysstructure storing the cellwise system
◆ cs_cdofb_block_dirichlet_pena()
void cs_cdofb_block_dirichlet_pena ( short int  f,
◆ cs_cdofb_block_dirichlet_weak()
void cs_cdofb_block_dirichlet_weak ( short int  fb,
[in]fbface id in the cell mesh numbering
◆ cs_cdofb_block_dirichlet_wsym()
void cs_cdofb_block_dirichlet_wsym ( short int  fb,
◆ cs_cdofb_fixed_wall()
void cs_cdofb_fixed_wall ( short int  fb,
◆ cs_cdofb_navsto_add_grad_div()
void cs_cdofb_navsto_add_grad_div ( short int  n_fc,
cs_sdm_t *  mat
[in]n_fclocal number of faces for the current cell
[in]zetascalar coefficient for the grad-div operator
[in]divdivergence
[in,out]matlocal system matrix to update
◆ cs_cdofb_navsto_balance()
cs_cdo_balance_t * cs_cdofb_navsto_balance ( const cs_navsto_param_t *  nsp,
const cs_time_step_t *  ts,
const cs_cdo_bc_face_t *  pr_bc,
const cs_boundary_type_t *  bf_type,
const cs_real_t *  pr_c
[in]quantpointer to a cs_cdo_quantities_t struct.
[in]tspointer to a cs_time_step_t struct.
[in]pr_bcset of definitions for the presuure BCs
[in]bf_typetype of boundaries for all boundary faces
[in]pr_cscalar-valued pressure in each cell
a pointer to a cs_cdo_balance_t structure
◆ cs_cdofb_navsto_boussinesq_at_cell()
void cs_cdofb_navsto_boussinesq_at_cell ( const cs_navsto_param_t *  nsp,
const cs_cdofb_navsto_builder_t *  nsb,
◆ cs_cdofb_navsto_boussinesq_at_face()
void cs_cdofb_navsto_boussinesq_at_face ( const cs_navsto_param_t *  nsp,
◆ cs_cdofb_navsto_boussinesq_by_part()
void cs_cdofb_navsto_boussinesq_by_part ( const cs_navsto_param_t *  nsp,
◆ cs_cdofb_navsto_cell_divergence()
double cs_cdofb_navsto_cell_divergence ( const cs_lnum_t  c_id,
const cs_adjacency_t *  c2f,
const cs_real_t *  f_vals
[in]c_idcell id
[in]c2fpointer to cell-to-face cs_adjacency_t
[in]f_valsvalues of the face DoFs
the divergence for the corresponding cell
◆ cs_cdofb_navsto_compute_face_pressure()
void cs_cdofb_navsto_compute_face_pressure ( const cs_mesh_t *  mesh,
const cs_real_t *  p_cell,
cs_real_t *  p_face
[in]tspointer to a cs_time_step_t structure
[in]p_cellvalue of the pressure inside each cell
[in,out]p_facevalue of the pressure at each face
◆ cs_cdofb_navsto_create_builder()
cs_cdofb_navsto_builder_t cs_cdofb_navsto_create_builder ( const cs_navsto_param_t *  nsp,
[in]nspset of parameters to define the NavSto system
a cs_cdofb_navsto_builder_t structure
◆ cs_cdofb_navsto_define_builder()
void cs_cdofb_navsto_define_builder ( cs_real_t  t_eval,
const cs_cell_sys_t *  csys,
[in]t_evaltime at which one evaluates the pressure BC
[in]cmcellwise view of the mesh
[in]csyscellwise view of the algebraic system
[in,out]nsbbuilder to update
◆ cs_cdofb_navsto_extra_op()
void cs_cdofb_navsto_extra_op ( const cs_navsto_param_t *  nsp,
cs_time_plot_t *  time_plotter,
const cs_adv_field_t *  adv_field,
const cs_real_t *  mass_flux,
const cs_real_t *  u_cell,
const cs_real_t *  u_face
  • The mass flux accross the boundaries.
  • The global mass in the computational domain
  • The norm of the velocity divergence
  • the cellwise mass flux balance
  • the kinetic energy
  • the velocity gradient
  • the pressure gradient
  • the vorticity
  • the helicity
  • the enstrophy
  • the stream function
[in]nsppointer to a cs_navsto_param_t struct.
[in,out]time_plotterpointer to a cs_time_plot_t struct.
[in]adv_fieldpointer to a cs_adv_field_t struct.
[in]mass_fluxscalar-valued mass flux for each face
[in]p_cellscalar-valued pressure in each cell
[in]u_cellvector-valued velocity in each cell
[in]u_facevector-valued velocity on each face
◆ cs_cdofb_navsto_free_builder()
void cs_cdofb_navsto_free_builder ( cs_cdofb_navsto_builder_t *  nsb)
[in,out]nsbpointer to the cs_cdofb_navsto_builder_t to free
◆ cs_cdofb_navsto_gravity_term()
void cs_cdofb_navsto_gravity_term ( const cs_navsto_param_t *  nsp,
◆ cs_cdofb_navsto_init_face_pressure()
void cs_cdofb_navsto_init_face_pressure ( const cs_navsto_param_t *  nsp,
cs_real_t *  pr_f
[in,out]pr_fpointer to the pressure values at faces
◆ cs_cdofb_navsto_init_pressure()
void cs_cdofb_navsto_init_pressure ( const cs_navsto_param_t *  nsp,
cs_field_t *  pr
[in,out]prpointer to the pressure cs_field_t structure
◆ cs_cdofb_navsto_mass_flux()
void cs_cdofb_navsto_mass_flux ( const cs_navsto_param_t *  nsp,
const cs_real_t *  face_vel,
[in]quantset of additional geometrical quantities
[in]face_velvelocity vectors for each face
[in,out]mass_fluxarray of mass flux values to update (allocated)
◆ cs_cdofb_navsto_nl_algo_cvg()
cs_sles_convergence_state_t cs_cdofb_navsto_nl_algo_cvg ( cs_param_nl_algo_t  nl_algo_type,
const cs_real_t *  pre_iterate,
cs_real_t *  cur_iterate,
cs_iter_algo_t *  algo
[in]nl_algo_typetype of non-linear algorithm
[in]pre_iterateprevious state of the mass flux iterate
[in]cur_iteratecurrent state of the mass flux iterate
[in,out]algopointer to a cs_iter_algo_t structure
the convergence state
◆ cs_cdofb_navsto_rescale_pressure_to_ref()
void cs_cdofb_navsto_rescale_pressure_to_ref ( const cs_navsto_param_t *  nsp,
cs_real_t  values[]
[in,out]valuespressure field values
◆ cs_cdofb_navsto_set_boussinesq_algo()
void cs_cdofb_navsto_set_boussinesq_algo ( cs_cdofb_navsto_boussinesq_type_t  type)
[in]typetype of algorithm to use
◆ cs_cdofb_navsto_set_gravity_func()
void cs_cdofb_navsto_set_gravity_func ( const cs_navsto_param_t *  nsp,
cs_cdofb_navsto_source_t **  p_func
[in]nspset of parameters for the Navier-Stokes system
[out]p_funcway to compute the gravity effect
◆ cs_cdofb_navsto_set_zero_mean_pressure()
void cs_cdofb_navsto_set_zero_mean_pressure ( const cs_cdo_quantities_t *  quant,
cs_real_t  values[]
◆ cs_cdofb_navsto_stream_source_term()
void cs_cdofb_navsto_stream_source_term ( cs_lnum_t  n_elts,
const cs_lnum_t *  elt_ids,
bool  dense_output,
void *  input,
cs_real_t *  retval
[in]n_eltsnumber of elements to consider
[in]elt_idslist of elements ids
[in]dense_outputperform an indirection in retval or not
[in]inputnull or pointer to a structure cast on-the-fly
[in,out]retvalresult of the function. Must be allocated.
[in]inputnullptr or pointer to a structure cast on-the-fly
◆ cs_cdofb_prescribed_smooth_wall()
void cs_cdofb_prescribed_smooth_wall ( short int  fb,
◆ cs_cdofb_symmetry()
void cs_cdofb_symmetry ( short int  fb,
