Time step modification
We do a computation restart with an adaptive (variable in time and constant in space) or local (variable in time and space) time step. We want to modify the time step read from the restart file (in order to overcome a too slow evolution for instance).
Initialization
The following block can be added to cs_user_initialization.cpp to do this:
return;
for (
cs_lnum_t cell_id = 0; cell_id < n_cells; cell_id++) {
Definition: cs_field.h:275
cs_real_t * val
Definition: cs_field.h:298
Definition: cs_defs.h:325
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
int cs_restart_present(void)
Check if we have a restart directory.
Definition: cs_restart.cpp:2170
