Gas 3 PTCHEM example
Initialization
The following initialization block needs to be added for the following examples:
/* If this is restarted computation, do not reinitialize values */
if (domain->time_step->nt_prev > 0)
return;
cs_real_t *cvar_fm = CS_F_(fm)->val;
const cs_real_t fs = cm->fs[0];
/* Mean Mixture Fraction */
cs_array_real_set_scalar(n_cells, fs, cvar_fm);
/* Enthalpy */
const cs_real_t hinoxy = cm->hinoxy;
const cs_real_t hinfue = cm->hinfue;
cs_real_t h_ini = hinfue*fs + hinoxy*(1.0-fs);
cs_array_real_set_scalar(n_cells, h_ini, cvar_scalt);
cs_real_t * val
Definition: cs_field.h:298
void cs_array_real_set_scalar(cs_lnum_t n_elts, cs_real_t ref_val, cs_real_t a[])
Assign a constant scalar value to an array.
Definition: cs_array.cpp:716
cs_combustion_gas_model_t * cs_glob_combustion_gas_model
Definition: cs_combustion_gas.cpp:169
Definition: cs_defs.h:332
Definition: cs_defs.h:325
@ fm
Definition: cs_field_pointer.h:126
#define CS_F_(e)
Definition: cs_field_pointer.h:47
int cs_glob_physical_model_flag[CS_N_PHYSICAL_MODEL_TYPES]
Definition: cs_physical_model.cpp:104
@ CS_COMBUSTION_3PT
Definition: cs_physical_model.h:54
cs_field_t * cs_thermal_model_field(void)
Definition: cs_thermal_model.cpp:180
Definition: cs_combustion_gas.h:181
double hinfue
Definition: cs_combustion_gas.h:239
double hinoxy
Definition: cs_combustion_gas.h:242
double fs[CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS]
Definition: cs_combustion_gas.h:266
