cs_atmo_option_t Struct Reference
#include <cs_atmo.h>
+ Collaboration diagram for cs_atmo_option_t:
Public Member Functions
DISABLE_WARNING_PUSH DISABLE_WARNING (-Wdeprecated-declarations) cs_atmo_option_t()
 Default constructor with suppression of deprecated declarations, needed to hide warnings simply induced by including this header file. More...
Public Attributes
DISABLE_WARNING_POP int syear {-1}
int squant {-1}
int shour {-1}
int smin {-1}
cs_real_t ssec {-1.}
cs_real_t longitude {1e12}
cs_real_t latitude {1e12}
cs_real_t altitude {0.}
cs_real_t x_l93 {1e12}
cs_real_t y_l93 {1e12}
cs_real_t x_origin {1e12}
cs_real_t y_origin {1e12}
cs_atmo_projection_t projection_type {CS_ATMO_PROJ_UNDEF}
int utm_zone {0}
int met_1d_nlevels_d {0}
int & nbmetd {met_1d_nlevels_d}
int met_1d_nlevels_t {0}
int & nbmett {met_1d_nlevels_t}
int met_1d_ntimes {0}
int & nbmetm {met_1d_ntimes}
int met_1d_nlevels_max_t {0}
int & nbmaxt {met_1d_nlevels_max_t}
cs_real_t domain_orientation {0.}
bool compute_z_ground {false}
int open_bcs_treatment {0}
int theo_interp {0}
int sedimentation_model {0}
int deposition_model {0}
int nucleation_model {0}
int subgrid_model {0}
int distribution_model {1}
int meteo_profile {0}
char * meteo_file_name {nullptr}
cs_real_t meteo_dlmo {0.}
cs_real_t meteo_z0 {-1.}
cs_real_t meteo_zref {-1.}
cs_real_t meteo_zi {-1.}
cs_real_t meteo_zu1 {-1.}
cs_real_t meteo_zu2 {-1.}
cs_real_t meteo_zt1 {-1.}
cs_real_t meteo_zt2 {-1.}
cs_real_t meteo_uref {-1.}
cs_real_t meteo_u1 {-1.}
cs_real_t meteo_u2 {-1.}
cs_real_t meteo_ustar0 {-1.}
cs_real_t meteo_wstar0 {-1.}
cs_real_t meteo_angle {-1.}
cs_real_t meteo_t0 {284.15}
cs_real_t meteo_t1 {0.}
cs_real_t meteo_t2 {0.}
cs_real_t meteo_tstar {0.}
cs_real_t meteo_psea {101325.}
cs_real_t meteo_qw0 {0.}
cs_real_t meteo_qwstar {cs_dbl_max}
cs_real_t meteo_qw1 {cs_dbl_max}
cs_real_t meteo_qw2 {cs_dbl_max}
cs_real_t meteo_ql0 {0.}
cs_real_t meteo_evapor {cs_dbl_max}
cs_real_t meteo_sensi {cs_dbl_max}
int meteo_phim_s {0}
int meteo_phih_s {0}
int meteo_phim_u {1}
int meteo_phih_u {1}
cs_real_t * xyp_met {nullptr}
cs_real_t * u_met {nullptr}
cs_real_t * v_met {nullptr}
cs_real_t * w_met {nullptr}
cs_real_t * ek_met {nullptr}
cs_real_t * ep_met {nullptr}
cs_real_t * temp_met {nullptr}
cs_real_t * rho_met {nullptr}
cs_real_t * qw_met {nullptr}
cs_real_t * ndrop_met {nullptr}
cs_real_t * z_dyn_met {nullptr}
cs_real_t * z_temp_met {nullptr}
cs_real_t * time_met {nullptr}
cs_real_t * hyd_p_met {nullptr}
cs_real_t * pot_t_met {nullptr}
cs_real_t * dpdt_met {nullptr}
cs_real_3_t * mom_met {nullptr}
cs_real_3_t * mom_cs {nullptr}
int hydrostatic_pressure_model {0}
int qv_profile {0}
int ground_model {0}
cs_atmo_ground_cat_t ground_cat {(cs_atmo_ground_cat_t) 0}
int ground_zone_id {-1}
cs_atmo_ground_meb_model_t ground_meb_model {(cs_atmo_ground_meb_model_t) 0}
bool rain {false}
int cloud_type {0}
bool accretion {false}
bool autoconversion {false}
bool autocollection_cloud {false}
bool autocollection_rain {false}
bool precipitation {false}
bool evaporation {false}
bool rupture {false}
cs_real_t ground_surf_temp {20.0}
cs_real_t ground_temperature {20.0}
cs_real_t ground_humidity {0.0}
cs_real_t ground_w1_ini {0.0}
cs_real_t ground_w2_ini {0.0}
cs_real_t * ground_cat_thermal_inertia {nullptr}
cs_real_t * ground_cat_roughness {nullptr}
cs_real_t * ground_cat_thermal_roughness {nullptr}
cs_real_t * ground_cat_albedo {nullptr}
cs_real_t * ground_cat_emissi {nullptr}
cs_real_t * ground_cat_vegeta {nullptr}
cs_real_t * ground_cat_w1 {nullptr}
cs_real_t * ground_cat_w2 {nullptr}
cs_real_t * ground_cat_r1 {nullptr}
cs_real_t * ground_cat_r2 {nullptr}
cs_real_t sigc {0.53}
int infrared_1D_profile {-1}
int solar_1D_profile {-1}
int profiles_grid_id {-1}
cs_real_t aod_o3_tot {0.2}
cs_real_t aod_h2o_tot {0.1}
Member Function Documentation
◆ DISABLE_WARNING()
DISABLE_WARNING_PUSH DISABLE_WARNING ( -Wdeprecated-  declarations)
inline
Member Data Documentation
◆ accretion
◆ altitude
altitude of the domain origin
◆ aod_h2o_tot
◆ aod_o3_tot
◆ autocollection_cloud
◆ autocollection_rain
◆ autoconversion
◆ cloud_type
int cloud_type {0}
◆ compute_z_ground
Option to compute ground elevation in the domain
◆ deposition_model
Deposition flag
◆ distribution_model
Option for liquid water content distribution models 1: all or nothing 2: Gaussian distribution
◆ domain_orientation
Domain orientation (angle in degree between y direction and north), 0 by default
◆ dpdt_met
cs_real_t* dpdt_met {nullptr}
Pressure drop integrated over a time step (used for automatic open boundaries) profile
◆ ek_met
cs_real_t* ek_met {nullptr}
meteo turbulent kinetic energy profile
◆ ep_met
cs_real_t* ep_met {nullptr}
meteo turbulent dissipation profile
◆ evaporation
◆ ground_cat
Ground categories:
  • CS_ATMO_GROUND_5_CAT
  • CS_ATMO_GROUND_7_CAT
  • CS_ATMO_GROUND_23_CAT
◆ ground_cat_albedo
cs_real_t* ground_cat_albedo {nullptr}
Albedo per ground category
◆ ground_cat_emissi
cs_real_t* ground_cat_emissi {nullptr}
emissivity per ground category
◆ ground_cat_r1
cs_real_t* ground_cat_r1 {nullptr}
Rij value for Rij1
◆ ground_cat_r2
cs_real_t* ground_cat_r2 {nullptr}
Rij value for Rij2
◆ ground_cat_roughness
cs_real_t* ground_cat_roughness {nullptr}
Dynamic roughness length
◆ ground_cat_thermal_inertia
cs_real_t* ground_cat_thermal_inertia {nullptr}
Thermal inertia of the ground
◆ ground_cat_thermal_roughness
cs_real_t* ground_cat_thermal_roughness {nullptr}
Thermal roughness length
◆ ground_cat_vegeta
cs_real_t* ground_cat_vegeta {nullptr}
Vegetation index per ground category
◆ ground_cat_w1
cs_real_t* ground_cat_w1 {nullptr}
maximum water capacity of shallow reservoir
◆ ground_cat_w2
cs_real_t* ground_cat_w2 {nullptr}
ratio of the maximum water capacity of the shallow reservoir to the deep reservoir [0,1]
◆ ground_humidity
initial ground specific humidity
◆ ground_meb_model
Solve supplementary heat budget equation (multi energy budget):
  • CS_ATMO_GROUND_GENUINE
  • CS_ATMO_GROUND_PHOTOVOLTAICS
  • CS_ATMO_GROUND_VEGETATION
◆ ground_model
Ground model (1: on, 0: off)
◆ ground_surf_temp
initial ground surface temperature for Sea, it is also the surface temperature
◆ ground_temperature
initial deep ground temperature
◆ ground_w1_ini
initial water content of the first reservoir
◆ ground_w2_ini
initial water content of the second reservoir
◆ ground_zone_id
Ground zone id (or -1 if inactive)
◆ hyd_p_met
cs_real_t* hyd_p_met {nullptr}
Hydrostatic pressure from Laplace integration
◆ hydrostatic_pressure_model
◆ infrared_1D_profile
1D infrared profile id
◆ latitude
latitude of the domain origin
◆ longitude
longitude of the domain origin
◆ met_1d_nlevels_d
◆ met_1d_nlevels_max_t
Number of vertical levels
◆ met_1d_nlevels_t
numbers of altitudes for the temperature and specific humidity
◆ met_1d_ntimes
numbers of time steps for the meteo profiles
◆ meteo_angle
Meteo wind direction
◆ meteo_dlmo
Meteo Monin obukhov inverse length
◆ meteo_evapor
Meteo reference evaporation
◆ meteo_file_name
char* meteo_file_name {nullptr}
Meteo file
◆ meteo_phih_s
Universal function Phi_h for stable condition
◆ meteo_phih_u
Universal function Phi_h for unstable condition
◆ meteo_phim_s
Universal function Phi_m for stable condition
◆ meteo_phim_u
Universal function Phi_m for unstable condition
◆ meteo_profile
Use meteo profile:
  • 0: not use
  • 1: use a meteo file
  • 2: directly enter values large scale values
  • 3: fill directly meteo_* fields
◆ meteo_psea
Meteo pressure at sea level
◆ meteo_ql0
Meteo reference mass fraction at 2m
◆ meteo_qw0
◆ meteo_qw1
Meteo reference mass fraction 1
◆ meteo_qw2
Meteo reference mass fraction 2
◆ meteo_qwstar
Meteo reference ground friction mass fraction
◆ meteo_sensi
Meteo reference sensible heat
◆ meteo_t0
Meteo reference temperature (ground temperature)
◆ meteo_t1
Meteo reference temperature 1
◆ meteo_t2
Meteo reference temperature 2
◆ meteo_tstar
Meteo reference ground friction temperature
◆ meteo_u1
Meteo reference velocity 1
◆ meteo_u2
Meteo reference velocity 2
◆ meteo_uref
◆ meteo_ustar0
Meteo reference ground friction velocity
◆ meteo_wstar0
Meteo reference convective velocity
◆ meteo_z0
Meteo reference roughness
◆ meteo_zi
Meteo Boundary layer elevation
◆ meteo_zref
Meteo reference elevation for reference velocity
◆ meteo_zt1
Meteo reference elevation for reference temperature 1
◆ meteo_zt2
Meteo reference elevation for reference temperature 2
◆ meteo_zu1
Meteo reference elevation for reference velocity 1
◆ meteo_zu2
Meteo reference elevation for reference velocity 2
◆ mom_cs
cs_real_3_t* mom_cs {nullptr}
code_saturne momentum for each level
◆ mom_met
cs_real_3_t* mom_met {nullptr}
Momentum for each level (used for automatic open boundaries)
◆ nbmaxt
int& nbmaxt {met_1d_nlevels_max_t}
◆ nbmetd
int& nbmetd {met_1d_nlevels_d}
◆ nbmetm
int& nbmetm {met_1d_ntimes}
◆ nbmett
int& nbmett {met_1d_nlevels_t}
◆ ndrop_met
cs_real_t* ndrop_met {nullptr}
meteo number of droplets profile
◆ nucleation_model
Option for nucleation 0: without nucleation 1: Pruppacher and Klett 1997 2: Cohard et al. 1998,1999 3: Abdul-Razzak et al. 1998,2000 logaritmic standard deviation of the log-normal law of the droplet spectrum
◆ open_bcs_treatment
◆ pot_t_met
cs_real_t* pot_t_met {nullptr}
potential temperature profile
◆ precipitation
◆ profiles_grid_id
id of grid formed by 1D profiles
◆ projection_type
Projection system used in computation
◆ qv_profile
int qv_profile {0}
flag for the standard atmo humidity profile qv_profile = 0 (default) qv_profile = 1 decreasing exponential
◆ qw_met
cs_real_t* qw_met {nullptr}
meteo water mass fraction profile
◆ rain
bool rain {false}
◆ rho_met
cs_real_t* rho_met {nullptr}
meteo density profile
◆ rupture
◆ sedimentation_model
Sedimentation flag
◆ shour
int shour {-1}
Starting hour
◆ sigc
adimensional : sigc=0.53 other referenced values are 0.28, 0.15
◆ smin
int smin {-1}
Starting minute
◆ solar_1D_profile
1D solar profile id
◆ squant
int squant {-1}
Starting quantile
◆ ssec
Starting second
◆ subgrid_model
Option for subgrid models 0: the simplest parameterization (for numerical verifications) 1: Bechtold et al. 1995 (Luc Musson-Genon) 2: Bouzereau et al. 2004 3: Cuijpers and Duynkerke 1993, Deardorff 1976, Sommeria and Deardorff 1977
◆ syear
Starting year
◆ temp_met
cs_real_t* temp_met {nullptr}
meteo temperature profile
◆ theo_interp
int theo_interp {0}
◆ time_met
cs_real_t* time_met {nullptr}
Time (in seconds) of the meteo profile
◆ u_met
cs_real_t* u_met {nullptr}
meteo u profiles
◆ utm_zone
int utm_zone {0}
◆ v_met
cs_real_t* v_met {nullptr}
meteo v profiles
◆ w_met
cs_real_t* w_met {nullptr}
meteo w profiles
◆ x_l93
x coordinate of the domain origin in Lambert-93
◆ x_origin
numbers of altitudes for the dynamics
XY coordinates of the domain origin in current projection system
◆ xyp_met
cs_real_t* xyp_met {nullptr}
meteo x, y, p at sea levels
◆ y_l93
y coordinate of the domain origin in Lambert-93
◆ y_origin
◆ z_dyn_met
cs_real_t* z_dyn_met {nullptr}
flag to compute the hydrostatic pressure by Laplace integration in the meteo profiles 0: based on P (sea level) value by default 1: based on P computed for the standard atmosphere
Altitudes of the dynamic profiles
◆ z_temp_met
cs_real_t* z_temp_met {nullptr}
Altitudes of the temperature profile
