Define user laws for physical properties with compressible module
Introduction
This page provides examples of code snippets that may be used to define physical variable laws.
Warning
It is forbidden to modify turbulent viscosity visct here (a specific subroutine is dedicated to that: usvist)
  • cs_glob_fluid_properties->icp = 1 must have been specified in cs_user_parameters if we wish to define a variable specific heat cpro_cp (otherwise: memory overwrite).
  • the field's diffusivity_id integer key must have been specified in cs_user_parameters if we wish to define a variable dynamic viscosity viscls.
Remarks
  • This function is called at the beginning of each time step Thus, AT THE FIRST TIME STEP (non-restart case), the only values initialized before this call are those defined
  • We may define here variation laws for cell properties, for:
    • density: kg/m3
    • density at boundary faces: kg/m3)
    • molecular viscosity: kg/(m s)
    • specific heat: J/(kg degrees)
    • conductivities associated with temperatures: W/(m K)
    • dynamic diffusivities associated with other scalars: kg/(m s)
Warning
: if the scalar is the temperature, its associated dynamic diffusivity actually corresponds to its conductivity (Lambda) in W/(m K)
The types of boundary faces at the previous time step are available (except at the first time step, where arrays itypfb and itrifb have not been initialized yet)
It is recommended to keep only the minimum necessary in this file (i.e. remove all unused example code)
Accessing physical properties
Base physical properties (rho, viscl, cp, ...) may be accessed as in the following snippet (see Variables and structures reference (C) for additional information).
cs_user_physical_properties and are not to be modified here.
Molecular viscosity varying with temperature
The values of the molecular viscosity are provided as a function of the temperature. All variables are evaluated at the cell centers.
/* Molecular dynamic viscosity 'cpro_viscl' */
/* User-defined coefficients for the selected law.
* The values hereafter are provided as a mere example. They
* are physically meaningless. */
cs_real_t varam = -3.4016e-9;
cs_real_t varbm = 6.2332e-7;
cs_real_t varcm = -4.5577e-5;
cs_real_t vardm = 1.6935e-3;
/* Molecular dynamic viscosity mu at the cell centers, kg/(m s)
* In this example, mu is provided as a function of the temperature T:
* mu(T) = T *( T *( am * T + bm )+ cm )+ dm
* that is:
* cpro_viscl(iel) = xvart*(xvart*(varam*xvart+varbm)+varcm)+vardm */
for (cs_lnum_t c_id = 0; c_id < n_cells; c_id++) {
const cs_real_t xvart = cvar_t[c_id];
cpro_viscl[c_id] = xvart*(xvart*(varam*xvart+varbm)+varcm)+vardm;
Definition: cs_defs.h:332
Definition: cs_defs.h:325
Molecular volumetric viscosity varying with temperature
The values of the molecular volumetric viscosity are provided as a function of the temperature. All variables are evaluated at the cell centers.
/* Stop if the volumetric viscosity has not been defined as variable */
if (cpro_viscv == nullptr)
bft_error(__FILE__, __LINE__, 0,
"%s: cpro_viscv not available.", __func__);
* The values provided hereafter are provided as a mere example.
* They are physically meaningless. */
const cs_real_t varam = -3.4016e-9;
const cs_real_t varbm = 6.2332e-7;
const cs_real_t varcm = -4.5577e-5;
const cs_real_t vardm = 1.6935e-3;
/* Molecular dynamic volumetric viscosity kappa at the cell centers, kg/(m s)
* In this example, kappa is provided as a function of the temperature T:
* kappa(T) = T *( T *( am * T + bm )+ cm )+ dm
* that is:
* cpro_viscv(iel) = xvart*(xvart*(varam*xvart+varbm)+varcm)+vardm */
for (cs_lnum_t c_id =0; c_id < n_cells; c_id++) {
cpro_viscv[c_id] = xvart*(xvart*(varam*xvart+varbm)+varcm)+vardm;
Definition: bft_error.cpp:187
Isobaric specific heat varying with temperature
The values of the isobaric specific heat values are provided as a function of the temperature. All variables are evaluated at the cell centers.
/* Stop if the isobaric or isochoric specific heat (cpro_cp or cpro_cv)
* has not been defined as variable */
if ((cpro_cp == nullptr) || (cpro_cv == nullptr))
"%s: cpro_cp or cpro_cv not available.", __func__);
* They are physically meaningless.*/
const cs_real_t varac = 0.00001;
const cs_real_t varbc = 1000.0;
/* Isobaric specific heat cpro_cp at the cell centers, J/(kg degree)
* In this example, cpro_cp is provided as a function of the temperature T:
* cpro_cp(T) = ac * T + ab
* that is:
* cpro_cp(iel) = varac*xvart+varbc */
cpro_cp[c_id] = varac*xvart + varbc;
/* The isochoric specific heat is deduced from the isobaric specific heat */
cs_cf_thermo_cv(cpro_cp, mix_mol_mas, cpro_cv, n_cells);
void cs_cf_thermo_cv(cs_real_t *cp, cs_real_t *xmasml, cs_real_t *cv, cs_lnum_t n_elts)
Compute the isochoric specific heat:
Definition: cs_cf_thermo.cpp:825
Molecular thermal conductivity varying with temperature
The values of the molecular thermal conductivity are provided as a function of the temperature. All variables are evaluated at the cell centers.
/* Stop if the molecular thermal conductivity has not
* been defined as variable */
if (cpro_vtmpk == nullptr)
"%s: cpro_vtmpk not available.", __func__);
cs_real_t varal = -3.3283e-7;
cs_real_t varbl = 3.6021e-5;
cs_real_t varcl = 1.2527e-4;
cs_real_t vardl = 0.589230;
/* Molecular thermal conductivity lambda at the cell centers, W/(m degree)
* In this example, lambda is provided as a function of the temperature T:
* lambda(T) = T *( T *( al * T + bl )+ cl )+ dl
* that is:
* cpro_vtmpk(iel) = xvart*(xvart*(varal*xvart+varbl)+varcl)+vardl */
cpro_vtmpk[c_id] = (xvart*(xvart*(varal*xvart+varbl)+varcl)+vardl);
Molecular dynamic diffusivity of user-defined scalars varying with temperature
The molecular dynamic diffusivity can be set for all the user-defined scalars except:
  • temperature and enthalpy (already dealt with above: for these variables, the 'diffusivity' is the thermal conductivity)
  • variances of the fluctuations of another scalar variable (the diffusivity is assumed to be equal to that of the associated scalar) The values of the molecular dynamic diffusivity are provided as a function of the temperature. All variables are evaluated at the cell centers.
const int n_fields = cs_field_n_fields();
const int keysca = cs_field_key_id("scalar_id");
const int kscavr = cs_field_key_id("first_moment_id");
/* Loop on the scalars fields */
cs_field_t *fld = cs_field(f_id);
/* If the scalar is the temperature, it will be skipped. */
if (fld == CS_F_(t_kelvin))
continue;
/* Here we only handle user or model scalar-type variables
which are not fluctuations */
int sc_id = -1;
if (fld->type & CS_FIELD_VARIABLE)
sc_id = fld->get_key_int(keysca) - 1;
if (sc_id < 0)
continue;
int variance_id = fld->get_key_int(kscavr);
int diffusivity_id = fld->get_key_int(kivisl);
if (variance_id > -1 || diffusivity_id < 0)
continue;
auto cpro_vscal = cs_field(diffusivity_id)->get_val_s();
const cs_real_t varal = -3.3283e-7;
const cs_real_t varbl = 3.6021e-5;
const cs_real_t varcl = 1.2527e-4;
const cs_real_t vardl = 0.5892300;
/* Molecular diffusivity lambda at the cell centers, kg/(m s)
* that is:
* cpro_vscal(iel) = xvart*(xvart*(varal*xvart+varbl)+varcl)+vardl */
cpro_vscal[c_id] = (xvart*(xvart*(varal*xvart+varbl)+varcl)+vardl);
} /* End of the loop on the scalars */
Definition: cs_field.h:275
int get_key_int(int key_id) const
Definition: cs_field.cpp:4507
cs_span< cs_real_t > get_val_s(const int time_id=0) const
Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked.
Definition: cs_field.cpp:5080
int type
Definition: cs_field.h:282
int cs_field_n_fields(void)
Definition: cs_field.cpp:1505
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
Definition: cs_field.cpp:2728
@ t_kelvin
Definition: cs_field_pointer.h:114
#define CS_F_(e)
Definition: cs_field_pointer.h:47
#define CS_FIELD_VARIABLE
Definition: cs_field.h:66
int diffusivity_id
Definition: keywords.h:168
