fvm_io_num.h File Reference
#include "fvm/fvm_defs.h"
+ Include dependency graph for fvm_io_num.h:
Typedefs
typedef struct _fvm_io_num_t fvm_io_num_t
Enumerations
enum  fvm_io_num_sfc_t { FVM_IO_NUM_SFC_MORTON_BOX , FVM_IO_NUM_SFC_MORTON_CUBE , FVM_IO_NUM_SFC_HILBERT_BOX , FVM_IO_NUM_SFC_HILBERT_CUBE }
fvm_io_num_t * fvm_io_num_create (const cs_lnum_t parent_entity_number[], const cs_gnum_t parent_global_number[], const size_t n_entities)
fvm_io_num_t * fvm_io_num_create_from_select (const cs_lnum_t parent_entity_id[], const cs_gnum_t parent_global_number[], size_t n_entities)
fvm_io_num_t * fvm_io_num_create_shared (const cs_gnum_t global_number[], cs_gnum_t global_count, size_t n_entities)
fvm_io_num_t * fvm_io_num_create_from_sub (const fvm_io_num_t *base_io_num, const cs_lnum_t n_sub_entities[])
fvm_io_num_t * fvm_io_num_create_from_adj_s (const cs_lnum_t parent_entity_id[], const cs_gnum_t adjacency[], size_t n_entities, size_t stride)
fvm_io_num_t * fvm_io_num_create_from_adj_i (const cs_lnum_t parent_entity_id[], const cs_lnum_t index[], const cs_gnum_t adjacency[], cs_lnum_t n_entities)
fvm_io_num_t * fvm_io_num_create_from_sfc (const cs_coord_t coords[], int dim, size_t n_entities, fvm_io_num_sfc_t sfc_type)
fvm_io_num_t * fvm_io_num_create_from_real (const cs_real_t val[], size_t n_entities)
fvm_io_num_t * fvm_io_num_create_from_scan (size_t n_entities)
fvm_io_num_t * fvm_io_num_destroy (fvm_io_num_t *this_io_num)
cs_gnum_t * fvm_io_num_transfer_global_num (fvm_io_num_t *this_io_num)
cs_lnum_t fvm_io_num_get_local_count (const fvm_io_num_t *const this_io_num)
cs_gnum_t fvm_io_num_get_global_count (const fvm_io_num_t *const this_io_num)
const cs_gnum_t * fvm_io_num_get_global_num (const fvm_io_num_t *const this_io_num)
cs_gnum_t fvm_io_num_global_sub_size (const fvm_io_num_t *this_io_num, const cs_lnum_t n_sub_entities[])
void fvm_io_num_dump (const fvm_io_num_t *const this_io_num)
const char * fvm_io_num_sfc_type_name []
Typedef Documentation
◆ fvm_io_num_t
◆ fvm_io_num_sfc_t
Enumerator
◆ fvm_io_num_create()
fvm_io_num_t * fvm_io_num_create ( const cs_lnum_t  parent_entity_number[],
◆ fvm_io_num_create_from_adj_i()
fvm_io_num_t * fvm_io_num_create_from_adj_i ( const cs_lnum_t  parent_entity_id[],
◆ fvm_io_num_create_from_adj_s()
fvm_io_num_t * fvm_io_num_create_from_adj_s ( const cs_lnum_t  parent_entity_id[],
size_t  n_entities,
size_t  stride
◆ fvm_io_num_create_from_real()
fvm_io_num_t * fvm_io_num_create_from_real ( const cs_real_t  val[],
size_t  n_entities
◆ fvm_io_num_create_from_scan()
fvm_io_num_t * fvm_io_num_create_from_scan ( size_t  n_entities)
◆ fvm_io_num_create_from_select()
fvm_io_num_t * fvm_io_num_create_from_select ( const cs_lnum_t  parent_entity_id[],
size_t  n_entities
◆ fvm_io_num_create_from_sfc()
fvm_io_num_t * fvm_io_num_create_from_sfc ( const cs_coord_t  coords[],
int  dim,
size_t  n_entities,
◆ fvm_io_num_create_from_sub()
fvm_io_num_t * fvm_io_num_create_from_sub ( const fvm_io_num_t *  base_io_num,
◆ fvm_io_num_create_shared()
fvm_io_num_t * fvm_io_num_create_shared ( const cs_gnum_t  global_number[],
size_t  n_entities
◆ fvm_io_num_destroy()
fvm_io_num_t * fvm_io_num_destroy ( fvm_io_num_t *  this_io_num)
◆ fvm_io_num_dump()
void fvm_io_num_dump ( const fvm_io_num_t *const  this_io_num)
◆ fvm_io_num_get_global_count()
cs_gnum_t fvm_io_num_get_global_count ( const fvm_io_num_t *const  this_io_num)
◆ fvm_io_num_get_global_num()
const cs_gnum_t * fvm_io_num_get_global_num ( const fvm_io_num_t *const  this_io_num)
◆ fvm_io_num_get_local_count()
cs_lnum_t fvm_io_num_get_local_count ( const fvm_io_num_t *const  this_io_num)
◆ fvm_io_num_global_sub_size()
cs_gnum_t fvm_io_num_global_sub_size ( const fvm_io_num_t *  this_io_num,
◆ fvm_io_num_transfer_global_num()
cs_gnum_t * fvm_io_num_transfer_global_num ( fvm_io_num_t *  this_io_num)
◆ fvm_io_num_sfc_type_name
const char* fvm_io_num_sfc_type_name[]
extern
