#include "base/cs_defs.h"#include <assert.h>#include <float.h>#include <math.h>#include <stdlib.h>#include <stdio.h>#include <string.h>#include "base/cs_mem.h"#include "bft/bft_printf.h"#include "fvm/fvm_hilbert.h"
Include dependency graph for fvm_hilbert.cpp:Functions | |
| void | fvm_hilbert_get_coord_extents (int dim, size_t n_coords, const cs_coord_t coords[], cs_coord_t g_extents[], MPI_Comm comm) |
| void | fvm_hilbert_encode_coords (int dim, const cs_coord_t extents[], cs_lnum_t n_coords, const cs_coord_t coords[], fvm_hilbert_code_t h_code[]) |
| void | fvm_hilbert_local_order (cs_lnum_t n_codes, const fvm_hilbert_code_t hilbert_codes[], cs_lnum_t order[]) |
| void | fvm_hilbert_local_order_coords (int dim, const cs_coord_t extents[], cs_lnum_t n_coords, const cs_coord_t coords[], cs_lnum_t order[]) |
| void | fvm_hilbert_s_to_code (double s, void *elt, const void *input) |
| Function pointer for conversion of a double precision value in range [0, 1] to a given Hilbert code. More... | |
| int | fvm_hilbert_compare (const void *elt1, const void *elt2, const void *input) |
| Function pointer for comparison of 2 Hilbert codes. More... | |
| int fvm_hilbert_compare | ( | const void * | elt1, |
| const void * | elt2, | ||
| const void * | input | ||
This function is the same type as that used by qsort_r.
| [in] | elt1 | coordinate between 0 and 1 |
| [in] | elt2 | pointer to optional (untyped) value or structure. |
| [in] | input | pointer to optional (untyped) value or structure. |
| void fvm_hilbert_encode_coords | ( | int | dim, |
| const cs_coord_t | extents[], | ||
| cs_lnum_t | n_coords, | ||
| const cs_coord_t | coords[], | ||
| fvm_hilbert_code_t | h_code[] | ||
| void fvm_hilbert_get_coord_extents | ( | int | dim, |
| size_t | n_coords, | ||
| cs_coord_t | g_extents[], | ||
| MPI_Comm | comm | ||
| void fvm_hilbert_local_order | ( | cs_lnum_t | n_codes, |
| const fvm_hilbert_code_t | hilbert_codes[], | ||
| cs_lnum_t | order[] | ||
| void fvm_hilbert_local_order_coords | ( | int | dim, |
| void fvm_hilbert_s_to_code | ( | double | s, |
| void * | elt, | ||
| [in] | s | coordinate between 0 and 1 |
| [out] | elt | pointer to element |
