fvm_box_tree.h File Reference
#include "fvm/fvm_box.h"
+ Include dependency graph for fvm_box_tree.h:
Typedefs
typedef struct _fvm_box_tree_t fvm_box_tree_t
Enumerations
enum  fvm_box_tree_sync_t { FVM_BOX_TREE_ASYNC_LEVEL , FVM_BOX_TREE_SYNC_LEVEL }
fvm_box_tree_t * fvm_box_tree_create (int max_level, int threshold, float max_box_ratio)
void fvm_box_tree_destroy (fvm_box_tree_t **bt)
int fvm_box_tree_get_max_level (const fvm_box_tree_t *bt)
void fvm_box_tree_set_boxes (fvm_box_tree_t *bt, const fvm_box_set_t *boxes, fvm_box_tree_sync_t build_type)
fvm_box_distrib_t * fvm_box_tree_get_distrib (fvm_box_tree_t *bt, const fvm_box_set_t *boxes)
void fvm_box_tree_get_intersects (fvm_box_tree_t *bt, const fvm_box_set_t *boxes, cs_lnum_t *box_index[], cs_gnum_t *box_g_num[])
int fvm_box_tree_get_stats (const fvm_box_tree_t *bt, int depth[3], cs_lnum_t n_leaves[3], cs_lnum_t n_boxes[3], cs_lnum_t n_threshold_leaves[3], cs_lnum_t n_leaf_boxes[3], size_t mem_used[3], size_t mem_allocated[3])
void fvm_box_tree_dump_statistics (const fvm_box_tree_t *bt)
void fvm_box_tree_dump (fvm_box_tree_t *bt)
Typedef Documentation
◆ fvm_box_tree_t
◆ fvm_box_tree_sync_t
Enumerator
◆ fvm_box_tree_create()
fvm_box_tree_t * fvm_box_tree_create ( int  max_level,
int  threshold,
float  max_box_ratio
◆ fvm_box_tree_destroy()
void fvm_box_tree_destroy ( fvm_box_tree_t **  bt)
◆ fvm_box_tree_dump()
void fvm_box_tree_dump ( fvm_box_tree_t *  bt)
◆ fvm_box_tree_dump_statistics()
void fvm_box_tree_dump_statistics ( const fvm_box_tree_t *  bt)
◆ fvm_box_tree_get_distrib()
fvm_box_distrib_t * fvm_box_tree_get_distrib ( fvm_box_tree_t *  bt,
const fvm_box_set_t *  boxes
◆ fvm_box_tree_get_intersects()
void fvm_box_tree_get_intersects ( fvm_box_tree_t *  bt,
const fvm_box_set_t *  boxes,
cs_lnum_t *  box_index[],
cs_gnum_t *  box_g_num[]
◆ fvm_box_tree_get_max_level()
int fvm_box_tree_get_max_level ( const fvm_box_tree_t *  bt)
◆ fvm_box_tree_get_stats()
int fvm_box_tree_get_stats ( const fvm_box_tree_t *  bt,
int  depth[3],
size_t  mem_used[3],
◆ fvm_box_tree_set_boxes()
void fvm_box_tree_set_boxes ( fvm_box_tree_t *  bt,
