Mapping relative to ALE
const cs_lnum_t *b_face_vtx_idx = domain->mesh->b_face_vtx_idx;
const cs_lnum_t *b_face_vtx_lst = domain->mesh->b_face_vtx_lst;
const cs_lnum_t *b_face_cells = domain->mesh->b_face_cells;
const int nt_cur = domain->time_step->nt_cur;
cs_span_2d< cs_real_t > get_val_v(const int time_id=0) const
Return a 2D span view of field values. If the field is not a vector a fatal error is provoked.
Definition: cs_field.cpp:5103
Definition: cs_defs.h:325
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
@ dt
Definition: cs_field_pointer.h:61
#define CS_F_(e)
Definition: cs_field_pointer.h:47
Assign boundary conditions to boundary faces
One may use selection criteria to filter boundary case subsets.
Loop on faces from a subset.
Set the boundary condition for each face.
Calculation of displacement at current time step
Example 1
Example : For boundary faces of color 4 assign a fixed velocity
auto mesh_u_val_ext =
CS_F_(
mesh_u)->bc_coeffs->get_val_ext_v();
const cs_real_t deltaa = sin(3.141596*(nt_cur-1)/50);
const cs_real_t delta = sin(3.141596*nt_cur/50.);
const cs_lnum_t c_id = b_face_cells[face_id];
mesh_u_val_ext(face_id, 0) = 0;
mesh_u_val_ext(face_id, 1) = 0;
mesh_u_val_ext(face_id, 2) = (delta-deltaa)/
dt[c_id];
@ CS_BOUNDARY_ALE_IMPOSED_VEL
Definition: cs_boundary.h:141
Definition: cs_boundary_zone.cpp:708
Definition: cs_defs.h:332
@ mesh_u
Definition: cs_field_pointer.h:84
const cs_lnum_t * elt_ids
Definition: cs_zone.h:61
cs_lnum_t n_elts
Definition: cs_zone.h:60
Example 2
Example: For boundary face of color 5 assign a fixed displacement on nodes
ii < b_face_vtx_idx[face_id+1];
ii++) {
if (impale[vtx_id] == 0) {
disale(vtx_id, 0) = 0;
disale(vtx_id, 1) = 0;
disale(vtx_id, 2) = delta;
impale[vtx_id] = 1;
Example 3
Example : For boundary faces of color 6 assign a sliding boundary
@ CS_BOUNDARY_ALE_SLIDING
Definition: cs_boundary.h:140
Example 4
Example : Prescribe elsewhere a fixed boundary
@ CS_BOUNDARY_ALE_FIXED
Definition: cs_boundary.h:139
