L2 time residuals of a variable at a given time step are a relative measure of the unsteady term of its transport equation:
bool cved = true;
if (cved) {
Definition: bft_printf.cpp:134
Definition: cs_field.h:275
int type
Definition: cs_field.h:282
time step descriptor
Definition: cs_time_step.h:60
int nt_cur
Definition: cs_time_step.h:72
int nt_max
Definition: cs_time_step.h:73
Definition: cs_defs.h:332
int cs_field_n_fields(void)
Definition: cs_field.cpp:1505
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
const void * cs_field_get_key_struct(const cs_field_t *f, const int key_id, void *s)
Return a structure for a given key associated with a field.
Definition: cs_field.cpp:3433
Definition: cs_field.cpp:2728
cs_time_step_t * cs_get_glob_time_step(void)
Provide read/write access to cs_glob_time_step.
Definition: cs_time_step.cpp:372
#define CS_FIELD_VARIABLE
Definition: cs_field.h:66
Definition: cs_parameters.h:64
double l2residual
Definition: cs_parameters.h:70
