cs_soot_model.h File Reference
#include "base/cs_field.h"
+ Include dependency graph for cs_soot_model.h:
void cs_soot_production (int f_id, cs_real_t smbrs[], cs_real_t rovsdt[])
 Specific physic subroutine : soot production model. More...
◆ cs_soot_production()
void cs_soot_production ( int  f_id,
cs_real_t  smbrs[],
cs_real_t  rovsdt[]
Define the source terms for the soot mass fraction and the precursor number for soot model. The equations read: $ rovsdt \delta a = smbrs $
$ rovsdt $ et $ smbrs $ may already contain source term so must not be overwritten, but incremented.
For stability, only positive terms should be add in $ rovsdt $. There is no constraint for $ smbrs $. For a source term written $ S_{exp} + S_{imp} a $, source terms are: $ smbrs  = smbrs  + S_{exp} + S_{imp} a $ $ rovsdt = rovsdt + \max(-S_{imp},0) $
Here we set $ rovsdt $ and $ smbrs $ containing $ \rho \Omega $
  • $ smbrs $ in $ kg_a.s^{-1} $ (ex: for velocity: $ kg.m.s^{-2} $, for temperature: $ kg.C.s^{-1} $, for enthalpy: $ J.s^{-1} $)
  • $ rovsdt $ in $ kg.s^{-1} $
[in]f_idscalar field id
[out]smbrsexplicit right hand side
[out]rovsdtimplicit terms
For stability only positive terms should be add in $ rovsdt $. There is no constraint for $ smbrs $. For a source term written $ S_{exp} + S_{imp} a $, source terms are: $ smbrs  = smbrs  + S_{exp} + S_{imp} a $ $ rovsdt = rovsdt + \max(-S_{imp},0) $
