152 const char *matrix_type,
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
cs_log_t
Definition: cs_log.h:44
Definition: cs_matrix.h:108
cs_sles_convergence_state_t
Definition: cs_sles.h:57
struct _cs_sles_t cs_sles_t
Definition: cs_sles.h:72
cs_sles_convergence_state_t cs_sles_petsc_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Call PETSc linear equation solver.
Definition: cs_sles_petsc.cpp:1465
void cs_sles_petsc_set_cvg_criteria(const void *context, double rtol, double atol, double dtol, int max_it)
Set the parameters driving the termination of an iterative process associated to a KSP structure.
Definition: cs_sles_petsc.cpp:1908
void cs_sles_petsc_log_setup(void *ksp)
Definition: cs_sles_petsc.cpp:1880
void cs_sles_petsc_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Setup PETSc linear equation solver.
Definition: cs_sles_petsc.cpp:1040
cs_sles_petsc_t * cs_sles_petsc_create(const char *matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context)
Create PETSc linear system solver info and context.
Definition: cs_sles_petsc.cpp:890
cs_sles_petsc_t * cs_sles_petsc_define(int f_id, const char *name, const char *matrix_type, cs_sles_petsc_setup_hook_t *setup_hook, void *context)
Define and associate a PETSc linear system solver for a given field or equation name.
Definition: cs_sles_petsc.cpp:848
void cs_user_sles_petsc_hook(void *context, void *ksp)
Definition: cs_sles_petsc.cpp:796
const char * cs_sles_petsc_get_mat_type(void *context)
Return matrix type associated with PETSc linear system solver info and context.
Definition: cs_sles_petsc.cpp:1939
void * cs_sles_petsc_copy(const void *context)
Create PETSc linear system solver info and context based on existing info and context.
Definition: cs_sles_petsc.cpp:969
bool cs_sles_petsc_error_post_and_abort(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
Error handler for PETSc solver.
Definition: cs_sles_petsc.cpp:1756
void cs_sles_petsc_destroy(void **context)
Destroy PETSc linear system solver info and context.
Definition: cs_sles_petsc.cpp:994
struct _cs_sles_petsc_t cs_sles_petsc_t
Definition: cs_sles_petsc.h:74
void cs_sles_petsc_log(const void *context, cs_log_t log_type)
Log sparse linear equation solver info.
Definition: cs_sles_petsc.cpp:1797
void() cs_sles_petsc_setup_hook_t(void *context, void *ksp)
Function pointer for user settings of a PETSc KSP solver setup.
Definition: cs_sles_petsc.h:69
void cs_sles_petsc_init(void)
Definition: cs_sles_petsc.cpp:810
void cs_sles_petsc_free(void *context)
Free PETSc linear equation solver setup context.
Definition: cs_sles_petsc.cpp:1699
void cs_sles_petsc_library_info(cs_log_t log_type)
Print information on PETSc library.
Definition: cs_sles_petsc.cpp:1958
