cs_sles_default.h File Reference
#include "base/cs_base.h"
#include "base/cs_halo_perio.h"
#include "alge/cs_matrix.h"
#include "alge/cs_sles.h"
+ Include dependency graph for cs_sles_default.h:
void cs_sles_default_log_setup (void)
void cs_sles_default (int f_id, const char *name, const cs_matrix_t *a)
 Default definition of a sparse linear equation solver. More...
void cs_sles_default_setup (void)
 Default setup for sparse linear equation solver API. More...
int cs_sles_default_get_verbosity (int f_id, const char *name)
 Return default verbosity associated to a field id, name couple. More...
cs_matrix_t * cs_sles_default_get_matrix (int f_id, const char *name, cs_lnum_t db_size, cs_lnum_t eb_size, bool symmetric)
 Return pointer to matrix structure matching equation solve. More...
void cs_sles_default_release_matrix (cs_matrix_t **m)
void cs_sles_default_finalize (void)
 Default finalization for sparse linear equation solver API. More...
cs_sles_convergence_state_t cs_sles_solve_ccc_fv (cs_sles_t *sc, cs_matrix_t *a, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx)
 Call sparse linear equation solver for general colocated cell-centered finite volume scheme. More...
cs_sles_convergence_state_t cs_sles_solve_native (int f_id, const char *name, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx)
 Call sparse linear equation solver using native matrix arrays. More...
void cs_sles_free_native (int f_id, const char *name)
 Free sparse linear equation solver setup using native matrix arrays. More...
bool cs_sles_default_error (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t rhs[], cs_real_t vx[])
 Error handler attempting fallback to alternative solution procedure for sparse linear equation solver. More...
◆ cs_sles_default()
void cs_sles_default ( int  f_id,
const char *  name,
const cs_matrix_t *  a
[in]nameassociated name if f_id < 0, or nullptr
[in]amatrix
◆ cs_sles_default_error()
bool cs_sles_default_error ( cs_sles_t *  sles,
const cs_matrix_t *  a,
cs_real_t  vx[]
In case of divergence with an iterative solver, this error handler switches to a default preconditioner, then resets the solution vector.
The default error for the solver type handler is then set, in case the solution fails again.
Note that this error handler may rebuild solver contexts, so should not be used in conjunction with shared contexts (such as multigrid ascent/descent contexts), but only for "outer" solvers.
[in,out]slespointer to solver object
[in]stateconvergence status
[in]amatrix
[in]rhsright hand side
[in,out]vxsystem solution
true if fallback solution is possible, false otherwise
◆ cs_sles_default_finalize()
void cs_sles_default_finalize ( void  )
This includes performance data logging output.
◆ cs_sles_default_get_matrix()
cs_matrix_t * cs_sles_default_get_matrix ( int  f_id,
const char *  name,
cs_lnum_t  db_size,
cs_lnum_t  eb_size,
bool  symmetric
Some matrix properties (such as assembly options and geometric association) are set immediately, but coefficients are not assigned at this stage.
[in]db_sizeblock sizes for diagonal
[in]eb_sizeblock sizes for extra diagonal
[in]symmetricindicate if matrix is symmetric
◆ cs_sles_default_get_verbosity()
int cs_sles_default_get_verbosity ( int  f_id,
const char *  name
verbosity associated with field or name
◆ cs_sles_default_log_setup()
void cs_sles_default_log_setup ( void  )
◆ cs_sles_default_release_matrix()
void cs_sles_default_release_matrix ( cs_matrix_t **  m)
◆ cs_sles_default_setup()
void cs_sles_default_setup ( void  )
This includes setup logging.
◆ cs_sles_free_native()
void cs_sles_free_native ( int  f_id,
const char *  name
◆ cs_sles_solve_ccc_fv()
cs_sles_convergence_state_t cs_sles_solve_ccc_fv ( cs_sles_t *  sc,
cs_matrix_t *  a,
double  precision,
double  r_norm,
int *  n_iter,
double *  residual,
const cs_real_t *  rhs,
cs_real_t *  vx
The initial solution is assumed to be 0 (and does not need to be initialized before calling this function).
[in]scsolver context
[in]amatrix
[in]precisionsolver precision
[in]r_normresidual normalization
[out]residualresidual
[out]vxsystem solution
convergence state
◆ cs_sles_solve_native()
cs_sles_convergence_state_t cs_sles_solve_native ( int  f_id,
const char *  name,
bool  symmetric,
const cs_real_t *  da,
const cs_real_t *  xa,
double  precision,
double  r_norm,
int *  n_iter,
double *  residual,
cs_real_t *  vx
[in]symmetricindicates if matrix coefficients are symmetric
[in]diag_block_sizeblock sizes for diagonal
[in]extra_diag_block_sizeblock sizes for extra diagonal
[in]dadiagonal values (nullptr if zero)
[in]xaextradiagonal values (nullptr if zero)
convergence state
