52#define CS_SLES_AMGX_PREFER_COMM_FROM_MAPS (1 << 0)
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
cs_log_t
Definition: cs_log.h:44
Definition: cs_matrix.h:108
cs_sles_convergence_state_t
Definition: cs_sles.h:57
void cs_sles_amgx_library_info(cs_log_t log_type)
Print information on AmgX library.
Definition: cs_sles_amgx.cpp:1494
cs_sles_convergence_state_t cs_sles_amgx_solve(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Call AmgX linear equation solver.
Definition: cs_sles_amgx.cpp:1192
void cs_sles_amgx_destroy(void **context)
Destroy AmgX linear system solver info and context.
Definition: cs_sles_amgx.cpp:713
void cs_sles_amgx_set_flags(void *context, int flags)
Define additional AmgX solver usage flags.
Definition: cs_sles_amgx.cpp:973
void cs_sles_amgx_set_config_file(void *context, const char *path)
Set the solver configuration file for an AmgX solver.
Definition: cs_sles_amgx.cpp:874
void cs_sles_amgx_setup(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Setup AmgX linear equation solver.
Definition: cs_sles_amgx.cpp:993
void * cs_sles_amgx_copy(const void *context)
Create AmgX linear system solver info and context based on existing info and context.
Definition: cs_sles_amgx.cpp:675
const char * cs_sles_amgx_get_config_file(void *context)
return the name of the solver configuration file for an AmgX solver.
Definition: cs_sles_amgx.cpp:853
void cs_sles_amgx_log(const void *context, cs_log_t log_type)
Log sparse linear equation solver info.
Definition: cs_sles_amgx.cpp:1440
cs_sles_amgx_t * cs_sles_amgx_create(void)
Create AmgX linear system solver info and context.
Definition: cs_sles_amgx.cpp:626
const char * cs_sles_amgx_get_config(void *context)
return the solver configuration for an AmgX solver.
Definition: cs_sles_amgx.cpp:769
void cs_sles_amgx_set_config(void *context, const char *config)
Define the configuration for an AmgX solver.
Definition: cs_sles_amgx.cpp:828
struct _cs_sles_amgx_t cs_sles_amgx_t
Definition: cs_sles_amgx.h:60
int cs_sles_amgx_get_flags(void *context)
Query additional AmgX solver usage flags.
Definition: cs_sles_amgx.cpp:954
void cs_sles_amgx_free(void *context)
Free AmgX linear equation solver setup context.
Definition: cs_sles_amgx.cpp:1408
void cs_sles_amgx_set_use_device(void *context, bool use_device)
Define whether an AmgX solver should use the device or host.
Definition: cs_sles_amgx.cpp:923
bool cs_sles_amgx_get_use_device(void *context)
Definition: cs_sles_amgx.cpp:897
cs_sles_amgx_t * cs_sles_amgx_define(int f_id, const char *name)
Define and associate an AmgX linear system solver for a given field or equation name.
Definition: cs_sles_amgx.cpp:592
