cs_redistribute.h File Reference
+ Include dependency graph for cs_redistribute.h:
Classes
struct  cs_distributor_t
template<typename T >
void cs_distribute_buffer (const cs_distributor_t *db, const int stride, T *buffer[])
 Distribute a buffer using the distributor structure. More...
void cs_distribute_buffer_allocated (const cs_distributor_t *db, const int stride, const T send_buf[], T recv_buf[])
void cs_distribute_buffer_indexed (const cs_distributor_t *db, cs_lnum_t *idx[], T *buffer[])
 Distribute an indexed array and its corresponding index array using the distributor structure. More...
void cs_distributor_destroy (cs_distributor_t **db)
 Destroy a distributor structure. More...
void cs_redistribute (const int cell_dest_rank[], cs_distributor_t **cd, cs_distributor_t **ifd, cs_distributor_t **bfd, cs_distributor_t **vd)
 Redistribute mesh and field data based on a cell destination rank map. More...
◆ cs_distribute_buffer()
void cs_distribute_buffer ( const cs_distributor_t *  db,
const int  stride,
T *  buffer[]
This function guarantees the uniqueness of the elements post-redistribution.
[in]dbpointer to the distributor
[in]stridestride of the array to distribute
[in,out]bufferpointer to the array to redistribute
◆ cs_distribute_buffer_allocated()
void cs_distribute_buffer_allocated ( const cs_distributor_t *  db,
const int  stride,
const T  send_buf[],
T  recv_buf[]
Unlike cs_distribute_buffer, the distribution is not in-place, and the recv_buf array must be allocated to the correct size by the caller.
[in]send_bufpointer to the array to redistribute
[out]recv_bufpointer to the redistributed array
◆ cs_distribute_buffer_indexed()
void cs_distribute_buffer_indexed ( const cs_distributor_t *  db,
cs_lnum_t *  idx[],
T *  buffer[]
[in,out]idxpointer to the index array to redistribute
[in,out]bufferpointer to the indexed array to redistribute
◆ cs_distributor_destroy()
void cs_distributor_destroy ( cs_distributor_t **  db)
[in,out]dbpointer of pointer to a cs_distributor_structure
◆ cs_redistribute()
void cs_redistribute ( const int  cell_dest_rank[],
cs_distributor_t **  cell_db,
cs_distributor_t **  i_face_db,
cs_distributor_t **  b_face_db,
cs_distributor_t **  vertex_db
If no cell map is given, a random one is created internally.
The different distributors are returned if any of the pointers are not null. In this case, it is up to the caller to free them whenever they are no longer needed.
[in]cell_dest_rankdestination rank for each cell
[out]cell_dbpointer of pointer to cell redistributor
[out]i_face_dbpointer of pointer to interior face redistributor
[out]b_face_dbpointer of pointer to boundary face redistributor
[out]vertex_dbpointer of pointer to vertex redistributor
