cs_reco.cpp File Reference
#include <cassert>
#include <cstring>
#include "base/cs_array.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "cdo/cs_scheme_geometry.h"
#include "cdo/cs_reco.h"
+ Include dependency graph for cs_reco.cpp:
Macros
#define _dp3   cs_math_3_dot_product
static double _scalar_ebyc2c (cs_lnum_t c_id, const cs_adjacency_t *c2e, const cs_cdo_quantities_t *cdoq, const double *array)
 Reconstruct the value at cell center from an array of values defined for each couple (e, c) --> array which can be scanned by the c2e adjacency). Case of scalar-valued array. More...
static double _scalar_vbyc2c (cs_lnum_t c_id, const cs_adjacency_t *c2v, const cs_cdo_quantities_t *cdoq, const double *array)
 Reconstruct the value at cell center from an array of values defined for each couple (v, c) --> array which can be scanned by the c2v adjacency). Case of scalar-valued array. More...
static double _scalar_v2c (cs_lnum_t c_id, const cs_adjacency_t *c2v, const cs_cdo_quantities_t *cdoq, const double *array)
 Reconstruct the value at a cell center from an array of values defined on primal vertices. Case of scalar-valued arrays. More...
static double _scalar_v2f (cs_lnum_t f_id, const cs_adjacency_t *f2e, const cs_adjacency_t *e2v, const cs_cdo_quantities_t *cdoq, const double *array)
 Reconstruct the value at a face center from an array of values defined on primal vertices. Case of scalar-valued arrays. More...
static void _vector_v2c (cs_lnum_t c_id, const cs_adjacency_t *c2v, const cs_cdo_quantities_t *cdoq, const double *array, cs_real_t reco[3])
 Reconstruct the value at a cell center from an array of values defined on primal vertices. Case of vector-valued arrays. More...
void cs_reco_dual_vol_weight_reduction (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, int stride, bool interlace, cs_real_t *array)
 Apply 1/|dual_vol| to a synchronized array of DoF vertices Parallel synchronization is done inside this function: 1) A parallel sum reduction is done on the vtx_values 2) Apply 1/|dual_vol| to each entry. More...
void cs_reco_cell_vectors_by_ib_face_dofs (const cs_adjacency_t *c2f, const cs_cdo_quantities_t *cdoq, const cs_real_t i_face_vals[], const cs_real_t b_face_vals[], cs_real_t *cell_reco)
 Reconstruct the vector-valued quantity inside each cell from the face DoFs (interior and boundary). Scalar-valued face DoFs are related to the normal flux across faces. More...
void cs_reco_cell_vector_by_face_dofs (cs_lnum_t c_id, const cs_adjacency_t *c2f, const cs_cdo_quantities_t *cdoq, const cs_real_t face_dofs[], bool local_input, cs_real_t *cell_reco)
 Reconstruct the vector-valued quantity inside a cell from the face DoFs (interior and boundary). Scalar-valued face DoFs are related to the normal flux across faces. More...
void cs_reco_cell_vectors_by_face_dofs (const cs_adjacency_t *c2f, const cs_cdo_quantities_t *cdoq, const cs_real_t face_dofs[], cs_real_t *cell_reco)
void cs_reco_scalar_v2c (cs_lnum_t n_cells, const cs_lnum_t *cell_ids, const cs_adjacency_t *c2v, const cs_cdo_quantities_t *cdoq, const double *array, bool dense_ouput, cs_real_t *reco)
 Reconstruct the value at cell center from an array of values defined at primal vertices. Case of scalar-valued array. More...
void cs_reco_scalar_vbyc2c (cs_lnum_t n_cells, const cs_lnum_t *cell_ids, const cs_adjacency_t *c2v, const cs_cdo_quantities_t *cdoq, const double *array, bool dense_ouput, cs_real_t *reco)
void cs_reco_scalar_ebyc2c (cs_lnum_t n_cells, const cs_lnum_t *cell_ids, const cs_adjacency_t *c2e, const cs_cdo_quantities_t *cdoq, const double *array, bool dense_ouput, cs_real_t *reco)
void cs_reco_vector_v2c (cs_lnum_t n_cells, const cs_lnum_t *cell_ids, const cs_adjacency_t *c2v, const cs_cdo_quantities_t *cdoq, const double *array, bool dense_ouput, cs_real_t *reco)
 Reconstruct the value at all cell centers from an array of values defined on primal vertices. Case of vector-valued fields. More...
void cs_reco_scalar_v2f (cs_lnum_t n_faces, const cs_lnum_t *face_ids, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const double *array, bool dense_ouput, cs_real_t *reco)
 Reconstruct the value at the face center from an array of values defined on primal vertices. Case of scalar-valued arrays. More...
void cs_reco_scalar_v2c_v2f (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const double *dof, double *p_reco_c[], double *p_reco_f[])
 Reconstruct at cell centers and face centers a vertex-based field Linear interpolation. If p_reco_c and/or p_reco_f are not allocated, this is done in this subroutine. Case of scalar-valued arrays. More...
void cs_reco_scalar_c2f (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, const double *p_c, double *p_reco_f)
 Reconstruct at face centers by a cell-based field weighted average. More...
void cs_reco_scal_pv_from_pc (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *cell_val, cs_real_t *vtx_val)
 Reconstruct a scalar-valued array at vertices from a scalar-valued array at cells. More...
void cs_reco_vect_pv_from_pc (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *cell_val, cs_real_t *vtx_val)
 Reconstruct a vector-valued array at vertices from a vector-valued array at cells. More...
void cs_reco_dfbyc_at_cell_center (cs_lnum_t c_id, const cs_adjacency_t *c2e, const cs_cdo_quantities_t *quant, const double *array, cs_real_3_t val_xc)
 Reconstruct a constant vector at the cell center from an array of values defined on dual faces lying inside each cell. This array is scanned thanks to the c2e connectivity. More...
void cs_reco_dfbyc_in_cell (const cs_cell_mesh_t *cm, const cs_real_t *array, cs_real_3_t val_c)
 Reconstruct a constant vector inside the cell c. array is scanned thanks to the c2e connectivity. Pointer is already located at the beginning of the cell sequence. Reconstruction used is based on DGA (stabilization = 1/d where d is the space dimension) More...
void cs_reco_dfbyc_in_pec (const cs_cell_mesh_t *cm, short int e, const cs_real_t *array, cs_real_3_t val_pec)
 Reconstruct a constant vector inside pec which is a volume surrounding the edge e inside the cell c. array is scanned thanks to the c2e connectivity. Pointer is already located at the beginning of the cell sequence. Reconstruction used is based on DGA (stabilization = 1/d where d is the space dimension) More...
void cs_reco_ccen_edge_dof (cs_lnum_t c_id, const cs_adjacency_t *c2e, const cs_cdo_quantities_t *quant, const double *dof, double reco[])
 Reconstruct at the cell center a field of edge-based DoFs. More...
void cs_reco_ccen_edge_dofs (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const double *dof, double *p_ccrec[])
 Reconstruct at each cell center a field of edge-based DoFs. More...
void cs_reco_cell_curl_by_edge_dofs (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *circ, cs_real_t **p_curl)
 Reconstruct a cell-wise constant curl from the knowledge of the circulation at primal edges. More...
void cs_reco_grad_cell_from_fb_dofs (cs_lnum_t c_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *p_c, const cs_real_t *p_f, cs_real_t grd_c[])
 Reconstruct the mean-value of the gradient field with DoFs arising from a face-based scheme (values at face center and cell center) The reconstruction only deals with the consistent part so that there is no distinction between Fb schemes. More...
void cs_reco_grad_33_cell_from_fb_dofs (cs_lnum_t c_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *u_c, const cs_real_t *u_f, cs_real_t grd_c[])
 Reconstruct the mean-value of the tensor gradient field with DoFs arising from a face-based scheme (vector-valued at face center and cell center) The reconstruction only deals with the consistent part so that there is no distinction between Fb schemes. More...
void cs_reco_grad_cell_from_pv (cs_lnum_t c_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *pdi, cs_real_t grdc[])
 Reconstruct the constant gradient vector in a cell (the mean value) from the value at mesh vertices. More...
void cs_reco_2grad_cell_from_pv (cs_lnum_t c_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_real_t *p1di, const cs_real_t *p2di, cs_real_t grd1c[], cs_real_t grd2c[])
 Reconstruct the constant gradient vector in a cell (the mean value) from the value at mesh vertices. Case of two scalar fields. More...
void cs_reco_cw_cell_vect_from_flux (const cs_cell_mesh_t *cm, const cs_real_t *fluxes, cs_real_t *cell_reco)
 Reconstruct the vector-valued quantity inside each cell from the given flux array. This array is stored in the same order as cm->f_ids Scalar-valued face DoFs are related to the normal flux across primal faces. More...
void cs_reco_cw_cell_vect_from_face_dofs (const cs_cell_mesh_t *cm, const cs_real_t i_face_vals[], const cs_real_t b_face_vals[], cs_real_t *cell_reco)
void cs_reco_cw_cell_grad_from_scalar_pv (const cs_cell_mesh_t *cm, const cs_real_t pdi[], cs_real_t *cell_gradient)
 Reconstruct the value of a scalar potential at a point inside a cell The scalar potential has DoFs located at primal vertices. More...
cs_real_t cs_reco_cw_scalar_pv_inside_cell (const cs_cell_mesh_t *cm, const cs_real_t pdi[], const cs_real_t length_xcxp, const cs_real_t unitv_xcxp[], cs_real_t wbuf[])
void cs_reco_cw_vgrd_wbs_from_pvc (const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *vgrd)
 Compute the weighted (by volume) gradient inside a given primal cell for the related vertices. Use the WBS algo. for approximating the gradient. The computation takes into account a subdivision into tetrahedra of the current cell based on p_{ef,c}. More...
void cs_reco_cw_cgrd_wbs_from_pvc (const cs_cell_mesh_t *cm, const cs_real_t *pot, cs_cell_builder_t *cb, cs_real_t *cgrd)
 Compute the mean value of a gradient inside a given primal cell. Use the WBS algo. for approximating the gradient. The computation takes into account a subdivision into tetrahedra of the current cell based on p_{ef,c}. More...
◆ _dp3
◆ _scalar_ebyc2c()
static double _scalar_ebyc2c ( cs_lnum_t  c_id,
const cs_adjacency_t *  c2e,
const cs_cdo_quantities_t *  cdoq,
const double *  array
inlinestatic
[in]c_idcell id
[in]c2ecell -> edges connectivity
[in]cdoqpointer to the additional quantities struct.
[in]arraypointer to the array of values at (e,c)
the reconstructed values at the cell center
◆ _scalar_v2c()
static double _scalar_v2c ( cs_lnum_t  c_id,
const cs_adjacency_t *  c2v,
inlinestatic
[in]c_idcell id
[in]c2vcell -> vertices connectivity
[in]arraypointer to the array of values at vertices
◆ _scalar_v2f()
static double _scalar_v2f ( cs_lnum_t  f_id,
const cs_adjacency_t *  f2e,
const cs_adjacency_t *  e2v,
static
[in]f_idface id
[in]f2eface -> edges connectivity
[in]e2vedge -> vertices connectivity
the reconstructed values at the face center
◆ _scalar_vbyc2c()
static double _scalar_vbyc2c ( cs_lnum_t  c_id,
inlinestatic
[in]c_idcell id
[in]arraypointer to the array of values at (v,c)
◆ _vector_v2c()
static void _vector_v2c ( cs_lnum_t  c_id,
const double *  array,
cs_real_t  reco[3]
static
[in]c_idcell id
[in,out]recoreconstructed values at the cell center
◆ cs_reco_2grad_cell_from_pv()
void cs_reco_2grad_cell_from_pv ( cs_lnum_t  c_id,
const cs_real_t *  p1di,
const cs_real_t *  p2di,
cs_real_t  grd1c[],
cs_real_t  grd2c[]
[in]c_idcell id
[in]quantpointer to the additional quantities struct.
[in]p1dipointer to the array of values
[in]p2dipointer to the array of values
[in,out]grd1cvalue of the reconstructed gradient for p1
[in,out]grd2cvalue of the reconstructed gradient for p2
◆ cs_reco_ccen_edge_dof()
void cs_reco_ccen_edge_dof ( cs_lnum_t  c_id,
const double *  dof,
double  reco[]
[in]c_idcell id
[in]dofpointer to the field of edge-based DoFs
[in,out]recovalue of the reconstructed field at cell center
◆ cs_reco_ccen_edge_dofs()
void cs_reco_ccen_edge_dofs ( const cs_cdo_connect_t *  connect,
const double *  dof,
double *  p_ccrec[]
[in]connectpointer to the connectivity struct.
[in,out]p_ccrecpointer to the reconstructed values
◆ cs_reco_cell_curl_by_edge_dofs()
void cs_reco_cell_curl_by_edge_dofs ( const cs_cdo_connect_t *  connect,
const cs_real_t *  circ,
cs_real_t **  p_curl
[in]circpointer to the array of circulations at edges
[in,out]p_curlpointer to value of the reconstructed curl inside cells (allocated if set to nullptr)
◆ cs_reco_cell_vector_by_face_dofs()
void cs_reco_cell_vector_by_face_dofs ( cs_lnum_t  c_id,
const cs_adjacency_t *  c2f,
bool  local_input,
cs_real_t *  cell_reco
[in]c_idid of the cell to handle
[in]c2fcell -> faces connectivity
[in]face_dofsarray of DoF values at faces
[in]local_inputtrue means that face_dofs is of size n_cell_faces
[out]cell_recovector-valued reconstruction inside cells. This quantity should have been allocated before calling this function
◆ cs_reco_cell_vectors_by_face_dofs()
void cs_reco_cell_vectors_by_face_dofs ( const cs_adjacency_t *  c2f,
◆ cs_reco_cell_vectors_by_ib_face_dofs()
void cs_reco_cell_vectors_by_ib_face_dofs ( const cs_adjacency_t *  c2f,
[in]i_face_valsarray of DoF values for interior faces
[in]b_face_valsarray of DoF values for border faces
◆ cs_reco_cw_cell_grad_from_scalar_pv()
void cs_reco_cw_cell_grad_from_scalar_pv ( const cs_cell_mesh_t *  cm,
cs_real_t *  cell_gradient
[in]pdiarray of DoF values at vertices
[out]cell_gradientgradient inside the cell
◆ cs_reco_cw_cell_vect_from_face_dofs()
void cs_reco_cw_cell_vect_from_face_dofs ( const cs_cell_mesh_t *  cm,
[out]cell_recovector-valued reconstruction inside the cell
◆ cs_reco_cw_cell_vect_from_flux()
void cs_reco_cw_cell_vect_from_flux ( const cs_cell_mesh_t *  cm,
const cs_real_t *  fluxes,
[in]fluxesarray of normal fluxes on primal faces
◆ cs_reco_cw_cgrd_wbs_from_pvc()
void cs_reco_cw_cgrd_wbs_from_pvc ( const cs_cell_mesh_t *  cm,
const cs_real_t *  pot,
cs_cell_builder_t *  cb,
cs_real_t *  cgrd
[in]potvalues of the potential fields at vertices + cell
[in,out]cbauxiliary structure for computing the flux
[in,out]cgrdmean-value of the cell gradient
◆ cs_reco_cw_scalar_pv_inside_cell()
cs_real_t cs_reco_cw_scalar_pv_inside_cell ( const cs_cell_mesh_t *  cm,
cs_real_t  wbuf[]
[in]length_xcxplenght of the segment [x_c, x_p]
[in]unitv_xcxpunitary vector pointed from x_c to x_p
[in,out]wbufpointer to a temporary buffer
the value of the reconstructed potential at the evaluation point
◆ cs_reco_cw_vgrd_wbs_from_pvc()
void cs_reco_cw_vgrd_wbs_from_pvc ( const cs_cell_mesh_t *  cm,
cs_real_t *  vgrd
[in,out]vgrdgradient at vertices inside this cell
◆ cs_reco_dfbyc_at_cell_center()
void cs_reco_dfbyc_at_cell_center ( cs_lnum_t  c_id,
cs_real_3_t  val_xc
[in]c_idcell id
[in,out]val_xcvalue of the reconstruction at the cell center
◆ cs_reco_dfbyc_in_cell()
void cs_reco_dfbyc_in_cell ( const cs_cell_mesh_t *  cm,
const cs_real_t *  array,
cs_real_3_t  val_c
[in]arraylocal pointer to the array of values
[in,out]val_cvalue of the reconstructed vector in the cell
◆ cs_reco_dfbyc_in_pec()
void cs_reco_dfbyc_in_pec ( const cs_cell_mesh_t *  cm,
short int  e,
cs_real_3_t  val_pec
[in]elocal edge id
[in,out]val_pecvalue of the reconstruction in pec
◆ cs_reco_dual_vol_weight_reduction()
void cs_reco_dual_vol_weight_reduction ( const cs_cdo_connect_t *  connect,
int  stride,
bool  interlace,
cs_real_t *  array
[in]connectpointer to additional connectivities for CDO
[in]quantpointer to additional quantities for CDO
[in]stridenumber of entries for each vertex
[in]interlaceinterlaced array (useful if the stride > 1)
[in,out]arrayarray of DoF values
◆ cs_reco_grad_33_cell_from_fb_dofs()
void cs_reco_grad_33_cell_from_fb_dofs ( cs_lnum_t  c_id,
const cs_real_t *  u_c,
const cs_real_t *  u_f,
cs_real_t  grd_c[]
[in]c_idcell id
[in]u_cpointer to the array of values in cells
[in]u_fpointer to the array of values on faces
[in,out]grd_cvalue of the reconstructed gradient at cell center
◆ cs_reco_grad_cell_from_fb_dofs()
void cs_reco_grad_cell_from_fb_dofs ( cs_lnum_t  c_id,
const cs_real_t *  p_c,
const cs_real_t *  p_f,
cs_real_t  grd_c[]
Reconstruct the mean-value of the gradient field with DoFs arising from a face-based scheme (values at face center and cell center) The reconstruction only deals with the consistent part so that there is no distinction betwwen Fb schemes.
[in]c_idcell id
[in]p_cpointer to the array of values in cells
[in]p_fpointer to the array of values on faces
◆ cs_reco_grad_cell_from_pv()
void cs_reco_grad_cell_from_pv ( cs_lnum_t  c_id,
const cs_real_t *  pdi,
cs_real_t  grdc[]
[in]c_idcell id
[in]pdipointer to the array of values
[in,out]grdcvalue of the reconstructed gradient
◆ cs_reco_scal_pv_from_pc()
void cs_reco_scal_pv_from_pc ( const cs_cdo_connect_t *  connect,
const cs_real_t *  cell_val,
cs_real_t *  vtx_val
[in]quantpointer to the additional quantities for CDO
[in]cell_valarray of scalar-valued values at cells
[in,out]vtx_valarray of scalar-valued values at vertices
◆ cs_reco_scalar_c2f()
void cs_reco_scalar_c2f ( const cs_cdo_connect_t *  connect,
const double *  p_c,
double *  p_reco_f
[in]cdoqpointer to additional quantities for CDO
[in]p_cdofs at cell centers
[in,out]p_reco_freconstructed values at face centers
◆ cs_reco_scalar_ebyc2c()
void cs_reco_scalar_ebyc2c ( cs_lnum_t  n_cells,
const cs_lnum_t *  cell_ids,
bool  dense_ouput,
cs_real_t *  reco
[in]n_cellsnumber of selected cells
[in]cell_idslist of cell ids or nullptr
[in]dense_ouputapply cell_ids on the reco array
[in,out]recoreconstructed values at the cell centers
◆ cs_reco_scalar_v2c()
void cs_reco_scalar_v2c ( cs_lnum_t  n_cells,
bool  dense_ouput,
cs_real_t *  reco
◆ cs_reco_scalar_v2c_v2f()
void cs_reco_scalar_v2c_v2f ( const cs_cdo_connect_t *  connect,
const double *  dof,
double *  p_reco_c[],
double *  p_reco_f[]
[in]dofpointer to the field of vtx-based DoFs
[in,out]p_reco_creconstructed values at cell centers
◆ cs_reco_scalar_v2f()
void cs_reco_scalar_v2f ( cs_lnum_t  n_faces,
const cs_lnum_t *  face_ids,
bool  dense_ouput,
cs_real_t *  reco
[in]n_facesnumber of faces
[in]face_idslist of face ids (interior/border faces) or nullptr
[in,out]recovalue of the reconstruction at face centers
◆ cs_reco_scalar_vbyc2c()
void cs_reco_scalar_vbyc2c ( cs_lnum_t  n_cells,
bool  dense_ouput,
cs_real_t *  reco
◆ cs_reco_vect_pv_from_pc()
void cs_reco_vect_pv_from_pc ( const cs_cdo_connect_t *  connect,
cs_real_t *  vtx_val
[in]cell_valarray of vector-valued values at cells
[in,out]vtx_valarray of vector-valued values at vertices
◆ cs_reco_vector_v2c()
void cs_reco_vector_v2c ( cs_lnum_t  n_cells,
bool  dense_ouput,
cs_real_t *  reco
