cs_param_hpddm.h File Reference
Routines and structure to handle the HPDDM setup. The structure is used as a context structure of a cs_param_sles_t structure. More...
Classes
struct  cs_param_hpddm_t
 Set of parameters to specify additional options to HPDDM Please refer to the HPDDM user guide for more details. More...
cs_param_hpddm_t * cs_param_hpddm_create (void)
 Create and initialize with the default settings a new structure storing a set of parameters used when calling HPDDM. More...
cs_param_hpddm_t * cs_param_hpddm_copy (const cs_param_hpddm_t *hpddmp)
 Copy into a new structure the given set of parameters used when calling HPDDM. More...
void cs_param_hpddm_log (const char *name, const cs_param_hpddm_t *hpddmp)
 Log the structure storing the set of parameters used with HPDDM. More...
◆ cs_param_hpddm_copy()
cs_param_hpddm_t * cs_param_hpddm_copy ( const cs_param_hpddm_t *  hpddmp)
[in]hpddmpset of hpddm parameters
a pointer to a new allocated structure
◆ cs_param_hpddm_create()
cs_param_hpddm_t * cs_param_hpddm_create ( void  )
◆ cs_param_hpddm_log()
void cs_param_hpddm_log ( const char *  name,
[in]namename related to the current SLES
