cs_mesh_smoother.h
1#ifndef CS_MESH_SMOOTHER_H
2#define CS_MESH_SMOOTHER_H
5 * Mesh smoothing.
31 * Local headers
34#include "base/cs_base.h"
35#include "mesh/cs_mesh.h"
38/*============================================================================
39 * Macro definitions
40 *============================================================================*/
43 * Type definitions
45
46/*=============================================================================
47 * Public function prototypes
49
50/*----------------------------------------------------------------------------
51 * Set fixed vertices flag based on feature angle criterion.
52 *
53 * parameters:
54 * mesh <-- pointer to a cs_mesh_t structure
55 * feature_angle <-- feature angle (bounded between 0 and 90 degrees)
56 * vtx_is_fixed --> array to define vertices mobility (1: fixed, 0: free)
57 *----------------------------------------------------------------------------*/
58
59void
61 cs_real_t feature_angle,
62 int vtx_is_fixed[]);
63
64/*----------------------------------------------------------------------------
65 * Unwarping smoother.
66 *
67 * parameters:
68 * mesh <-- pointer to a cs_mesh_t structure
69 * vtx_is_fixed --> array to define vertices mobility (1 : fixed, 0 : free)
70 *----------------------------------------------------------------------------*/
71
72void
74 const int vtx_is_fixed[]);
75
76/*----------------------------------------------------------------------------*/
77
78#endif /* CS_MESH_SMOOTHER_H */
Definition: cs_defs.h:332
void cs_mesh_smoother_fix_by_feature(cs_mesh_t *mesh, cs_real_t feature_angle, int vtx_is_fixed[])
Definition: cs_mesh_smoother.cpp:754
void cs_mesh_smoother_unwarp(cs_mesh_t *mesh, const int vtx_is_fixed[])
Unwarping smoother.
Definition: cs_mesh_smoother.cpp:838
Definition: mesh.f90:26
Definition: cs_mesh.h:85
