cs_mesh_builder.cpp File Reference
#include <limits.h>
#include "bft/bft_printf.h"
#include "fvm/fvm_io_num.h"
#include "fvm/fvm_periodicity.h"
#include "fvm/fvm_selector.h"
#include "base/cs_base.h"
#include "base/cs_interface.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh_builder.h"
+ Include dependency graph for cs_mesh_builder.cpp:
cs_mesh_builder_t * cs_mesh_builder_create (void)
 Create an empty mesh builder structure. More...
void cs_mesh_builder_destroy (cs_mesh_builder_t **mb)
 Destroy a cs_mesh_builder_t structure. More...
void cs_mesh_builder_define_block_dist (cs_mesh_builder_t *mb, int rank_id, int n_ranks, int min_rank_step, int min_block_size, cs_gnum_t n_g_cells, cs_gnum_t n_g_faces, cs_gnum_t n_g_vertices)
 Define block distribution sizes for mesh builder. More...
void cs_mesh_builder_extract_periodic_faces_g (int n_init_perio, cs_mesh_builder_t *mb, fvm_periodicity_t *periodicity, const cs_gnum_t *face_gnum, const cs_interface_set_t *face_ifs)
 Extract periodic face connectivity information from faces interface for mesh builder when running in parallel mode. More...
◆ cs_mesh_builder_create()
cs_mesh_builder_t * cs_mesh_builder_create ( void  )
pointer to a mesh builder structure
◆ cs_mesh_builder_define_block_dist()
void cs_mesh_builder_define_block_dist ( cs_mesh_builder_t *  mb,
int  rank_id,
int  n_ranks,
int  min_rank_step,
int  min_block_size,
[in,out]mbpointer to mesh builder to update
[in]rank_idid of local rank
[in]n_ranksnumber of associated ranks
[in]min_rank_stepminimum rank step between blocks
[in]min_block_sizeminimum number of entities per block
[in]n_g_cellsglobal number of cells
[in]n_g_facesglobal number of faces
[in]n_g_verticesglobal number of vertices
◆ cs_mesh_builder_destroy()
void cs_mesh_builder_destroy ( cs_mesh_builder_t **  mb)
[in,out]mbpointer to pointer of structure to destroy
◆ cs_mesh_builder_extract_periodic_faces_g()
void cs_mesh_builder_extract_periodic_faces_g ( int  n_init_perio,
fvm_periodicity_t *  periodicity,
const cs_gnum_t *  face_gnum,
const cs_interface_set_t *  face_ifs
[in]n_init_perionumber of initial periodicities
[in,out]mbpointer to mesh builder structure
[in]periodicityperiodicity information
[in]face_gnumglobal face numbers, or nullptr
[in]face_ifsparallel and periodic faces interfaces set
