cs_meg_prototypes.h File Reference
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "base/cs_volume_zone.h"
#include "base/cs_ibm.h"
+ Include dependency graph for cs_meg_prototypes.h:
Typedefs
typedef void() cs_ibm_volume_func_t(const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, cs_real_t *retval)
typedef void() cs_ibm_fsi_func_t(cs_real_t *retval)
void cs_meg_boundary_function (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *field_name, const char *condition, cs_real_t *retvals)
 This function is used to compute user defined values for fields over a given boundary zone. The mathematical expression is defined in the GUI. More...
void cs_meg_volume_function (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *fields_names, cs_real_t *fvals[])
 This function is used to compute user defined values for fields over a given volume zone. The mathematical expression is defined in the GUI. More...
void cs_meg_initialization (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *field_name, cs_real_t *retvals)
 This function is used for the initalization of fields over a given volume zone. The mathematical expression is defined in the GUI. More...
void cs_meg_source_terms (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *name, const char *source_type, cs_real_t *retvals)
 This function is used to compute source terms over a volume zone. The mathematical expression is defined in the GUI. More...
void cs_meg_fsi_struct (const char *object_type, const char *name, const cs_real_t fluid_f[], cs_real_t val[])
 This function is used to query FSI internal coupling structure values for a given boundary and structure. More...
void cs_meg_post_activate (void)
 This function is used to activate postprocessing writers. More...
void cs_meg_post_profiles (const char *name, int n_coords, cs_real_t coords[][3])
 This function is used to define profile coordinates. More...
void cs_meg_post_calculator (const char *name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], cs_real_t *retvals)
 This function is used to compute user defined calculator formulae. The mathematical expression is defined in the GUI. More...
cs_cutcell_func_t * cs_meg_ibm_func_by_name (const char *object_name)
 This function is used to get the cs_cutcell_func_t pointer for a given object. More...
cs_ibm_volume_func_t * cs_meg_ibm_volume_func_by_name (const char *object_name, const char *gui_var_name)
 This function is used to get the cs_ibm_volume_func_t pointer for a given object. More...
cs_ibm_fsi_func_t * cs_meg_ibm_fsi_func_by_name (const char *object_name, const char *gui_var_name)
 This function is used to get the cs_ibm_fsi_func_t pointer for a given object. More...
Typedef Documentation
◆ cs_ibm_fsi_func_t
◆ cs_ibm_volume_func_t
◆ cs_meg_boundary_function()
void cs_meg_boundary_function ( const char *  zone_name,
const cs_lnum_t *  elt_ids,
const char *  field_name,
const char *  condition,
cs_real_t *  retvals
[in]zone_namename of a boundary zone
[in]n_eltsnumber of elements
[in]elt_idslist of element ids
[in]xyzlist of coordinates
[in]field_namename of the variable field
[in]conditioncondition type defined as a string
[out]retvalsarray of computed values
◆ cs_meg_fsi_struct()
void cs_meg_fsi_struct ( const char *  object_type,
const char *  name,
cs_real_t  val[]
[in]object_typename of object type
[in]namename of matching boundary
[in]fluid_farray of fluid forces on the object
[in,out]valmatrix or vector coefficients
◆ cs_meg_ibm_fsi_func_by_name()
cs_ibm_fsi_func_t * cs_meg_ibm_fsi_func_by_name ( const char *  object_name,
const char *  gui_var_name
pointer to corresponding function.
[in]object_nameName of the immersed object
[in]gui_var_nameName of the variable
◆ cs_meg_ibm_func_by_name()
cs_cutcell_func_t * cs_meg_ibm_func_by_name ( const char *  object_name)
[in]object_namename of the object
◆ cs_meg_ibm_volume_func_by_name()
cs_ibm_volume_func_t * cs_meg_ibm_volume_func_by_name ( const char *  object_name,
◆ cs_meg_initialization()
void cs_meg_initialization ( const char *  zone_name,
cs_real_t *  retvals
The caller is responsible for freeing the associated array.
[in]zone_namename of a volume zone
[in]field_nameassociated variable field name
◆ cs_meg_post_activate()
void cs_meg_post_activate ( void  )
◆ cs_meg_post_calculator()
void cs_meg_post_calculator ( const char *  name,
cs_real_t *  retvals
[in]namefunction name
[in]n_eltsnumber of elements related to the zone
[in]elt_idslist of element ids related to the zone
[in]xyzlist of coordinates related to the zone
◆ cs_meg_post_profiles()
void cs_meg_post_profiles ( const char *  name,
int  n_coords,
[in]namename of matching profile
[in]n_coordsnumber of point coordinates
[in,out]coordspoint coordinates
◆ cs_meg_source_terms()
void cs_meg_source_terms ( const char *  zone_name,
const char *  name,
const char *  source_type,
cs_real_t *  retvals
The caller is responsible for freeing the returned array.
[in]namevariable field name
[in]source_typesource term type
◆ cs_meg_volume_function()
void cs_meg_volume_function ( const char *  zone_name,
const char *  fields_names,
cs_real_t *  fvals[]
[in]fields_namesassociated variable field names
[in,out]fvalsarray of value arrays
