cs_matrix_assembler_priv.h
1#ifndef CS_MATRIX_ASSEMBLER_PRIV_H
2#define CS_MATRIX_ASSEMBLER_PRIV_H
5 * Incremental or general construction of matrix.
30#include "base/cs_defs.h"
33 * Standard C library headers
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "base/cs_defs.h"
41#include "base/cs_log.h"
43#include "base/cs_timer.h"
45#include "alge/cs_matrix.h"
46
47/*----------------------------------------------------------------------------
48 * Header for the current file
49 *----------------------------------------------------------------------------*/
50
51/*----------------------------------------------------------------------------*/
52
54
57/*=============================================================================
58 * Local Macro Definitions
59 *============================================================================*/
60
61/*=============================================================================
62 * Local Structure Definitions
63 *============================================================================*/
64
65/*----------------------------------------------------------------------------
66 * Structure used to pre-build a matrix
67 *----------------------------------------------------------------------------*/
68
69struct _cs_matrix_assembler_t {
70
71 bool separate_diag; /* is diagonal handled separately ? */
72
73 int flags; /* sum (bitwise or) of option constants */
74
75 cs_gnum_t l_range[2]; /* local global row range */
76 cs_gnum_t n_g_rows; /* global number of rows */
77 cs_lnum_t n_rows; /* local number of rows */
78
79 cs_lnum_t size; /* current insertion array size */
80 cs_lnum_t max_size; /* maximum insertion array size */
81
82 const cs_lnum_t *r_idx; /* shared main row index (0 to n-1) */
83 const cs_lnum_t *c_id; /* shared main column ids (0 to n-1) */
84
85 cs_lnum_t *_r_idx; /* private main row index (0 to n-1) */
86 cs_lnum_t *_c_id; /* private main column ids (0 to n-1) */
87
88 cs_lnum_t *d_r_idx; /* distant row index (0 to n-1) */
89 cs_gnum_t *d_g_c_id; /* distant global column ids (0 to n-1) */
90
91 cs_gnum_t *g_rc_id; /* global row and column ids
92 (local and distant) */
93
94#if defined(HAVE_MPI)
95
96 /* Distant columns associated with local rows */
97
98 /* Metadata for exchange of matrix coefficient values with other ranks */
99
100 int n_coeff_ranks; /* number of MPI ranks with which
101 coefficients are exchanged */
102 int *coeff_rank; /* ranks with which coefficients are
103 exchanged */
104
105 cs_lnum_t coeff_send_size; /* number of coefficients to send */
106 cs_lnum_t coeff_recv_size; /* number of coefficients to receive */
107
108 cs_lnum_t coeff_send_n_rows; /* number of matching rows */
109 cs_lnum_t *coeff_send_index; /* index of sent coefficient rows */
110 cs_gnum_t *coeff_send_row_g_id; /* global ids matching rows (ordered) */
111 cs_gnum_t *coeff_send_col_g_id; /* global ids matching columns
112 (ordered) */
113
114 cs_lnum_t *coeff_rank_send_index; /* index of data to send */
115 cs_lnum_t *coeff_rank_recv_index; /* index of data to receive */
116
117 cs_lnum_t *coeff_recv_row_id; /* local row ids associated with
118 received data; */
119 cs_lnum_t *coeff_recv_col_idx; /* local column index associated with
120 received data; the column numbering
121 implicitely assumes local terms
122 first, distant ones second */
123 cs_gnum_t *coeff_recv_col_g_id; /* global column id couples
124 associated with received data */
125
126 /* Associated communicator */
127
128 MPI_Comm comm; /* associated MPI communicator */
129
130 /* Statistics */
131
132 int n_ranks_init[2]; /* Number of ranks for initial exchange
133 for distant rows then columns */
134#endif /* HAVE_MPI */
135
136 /* Associated vector ghost element info */
137
138 const cs_halo_t *halo; /* shared halo for associated vectors */
139 cs_halo_t *_halo; /* private halo for associated vectors */
140
141 cs_lnum_t n_e_g_ids; /* number of external global ids */
142 cs_gnum_t *e_g_id; /* global ids associated with halo
143 elements (size: n_e_g_ids */
144
145};
146
147/*----------------------------------------------------------------------------
148 * Structure managing matrix coefficient contributions.
149 *----------------------------------------------------------------------------*/
150
151struct _cs_matrix_assembler_values_t {
152
153 const cs_matrix_assembler_t *ma; /* associated matrix assembler */
154
155 bool separate_diag; /* is diagonal handled separately ? */
156 bool final_assembly; /* are we ready for final assembly ? */
157
158 cs_lnum_t db_size; /* Diagonal blocks size */
159 cs_lnum_t eb_size; /* Extradiagonal blocks size */
160
161 cs_lnum_t *diag_idx; /* Local index of diagonal in each row
162 when conversion beween separate
163 diagonal and included diagonal is
164 required */
165
166 /* Accumulated contributions to distant rows, indexed as per
167 coeff_send_index of the matching assembler structure */
168
169#if defined(HAVE_MPI)
170
171 cs_real_t *coeff_send;
172
173#endif
174
175 /* Matching structure and function pointers; some function type may not be
176 useful for certain matrix structures or libraries. */
177
178 void *matrix; /* pointer to
179 matrix structure */
180
184 cs_matrix_assembler_values_begin_t *assembly_begin; /* optional */
185 cs_matrix_assembler_values_end_t *assembly_end; /* optional */
186
187};
188
189/*============================================================================
190 * Public inline function definitions
191 *============================================================================*/
192
193/*----------------------------------------------------------------------------*/
206/*----------------------------------------------------------------------------*/
207
208static inline cs_lnum_t
209_l_id_binary_search(cs_lnum_t l_id_array_size,
210 cs_lnum_t l_id,
211 const cs_lnum_t l_id_array[])
212{
213 if (l_id_array_size < 1)
214 return -1;
215
216 cs_lnum_t start_id = 0;
217 cs_lnum_t end_id = l_id_array_size - 1;
218 cs_lnum_t mid_id = end_id/2;
219 while (start_id < end_id) {
220 if (l_id_array[mid_id] < l_id)
221 start_id = mid_id + 1;
222 else if (l_id_array[mid_id] > l_id)
223 end_id = mid_id - 1;
224 else
225 break;
226 mid_id = start_id + (end_id - start_id)/2;
227 }
228 if (l_id_array[mid_id] != l_id)
229 mid_id = -1;
230
231 return mid_id;
232}
233
234/*----------------------------------------------------------------------------*/
247/*----------------------------------------------------------------------------*/
248
249static inline cs_lnum_t
250_g_id_binary_find(cs_lnum_t g_id_array_size,
251 cs_gnum_t g_id,
252 const cs_gnum_t g_id_array[])
253{
254 cs_lnum_t start_id = 0;
255 cs_lnum_t end_id = g_id_array_size - 1;
256 cs_lnum_t mid_id = (end_id -start_id) / 2;
257 while (start_id < end_id) {
258 if (g_id_array[mid_id] < g_id)
259 start_id = mid_id + 1;
260 else if (g_id_array[mid_id] > g_id)
261 end_id = mid_id - 1;
262 else
263 break;
264 mid_id = start_id + ((end_id -start_id) / 2);
265 }
266 assert(g_id_array[mid_id] == g_id);
267
268 return mid_id;
269}
270
273/*----------------------------------------------------------------------------*/
274
276
277#endif /* CS_MATRIX_ASSEMBLER_PRIV_H */
Definition: cs_defs.h:528
Definition: cs_defs.h:332
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
Definition: cs_defs.h:529
Definition: cs_defs.h:325
void() cs_matrix_assembler_values_end_t(void *matrix)
Function pointer to complete the final assembly of matrix coefficients.
Definition: cs_matrix_assembler.h:186
void() cs_matrix_assembler_values_add_t(void *matrix, cs_lnum_t n, cs_lnum_t stride, const cs_lnum_t row_id[], const cs_lnum_t col_idx[], const cs_real_t val[])
Function pointer for addition to matrix coefficients using local row ids and column indexes.
Definition: cs_matrix_assembler.h:116
void() cs_matrix_assembler_values_add_g_t(void *matrix, cs_lnum_t n, cs_lnum_t stride, const cs_gnum_t row_g_id[], const cs_gnum_t col_g_id[], const cs_real_t val[])
Function pointer for addition to matrix coefficients using global row ids and column indexes.
Definition: cs_matrix_assembler.h:148
void() cs_matrix_assembler_values_init_t(void *matrix, cs_lnum_t db_size, cs_lnum_t eb_size)
Function pointer for initialization of matrix coefficients using local row ids and column indexes.
Definition: cs_matrix_assembler.h:84
void() cs_matrix_assembler_values_begin_t(void *matrix)
Function pointer to start the final assembly of matrix coefficients.
Definition: cs_matrix_assembler.h:169
Definition: cs_halo.h:74
