cs_lagr_aux_mean_fluid_quantities.h
1#ifndef CS_LAGR_AUX_MEAN_FLUID_QUANTITIES_H
2#define CS_LAGR_AUX_MEAN_FLUID_QUANTITIES_H
5 * Functions and types for lagrangian field gradients
30#include "base/cs_defs.h"
32/*----------------------------------------------------------------------------*/
36/*=============================================================================
37 * Macro definitions
41 * Type definitions
45 * Global variables
48/*=============================================================================
49 * Public function prototypes
51
52/*----------------------------------------------------------------------------*/
71/*----------------------------------------------------------------------------*/
72
73void
75 int phase_id,
76 cs_real_3_t *anisotropic_lagr_time,
77 cs_real_3_t *anisotropic_bx,
78 cs_real_3_t *grad_lagr_time_r_et,
79 cs_real_3_t *grad_lagr_time,
80 cs_real_4_t *anisotropic_euler);
81
82/*----------------------------------------------------------------------------*/
95/*----------------------------------------------------------------------------*/
96
97void
99 cs_real_3_t *grad_cov_skp[9],
100 cs_real_3_t *grad_cov_sk[6]);
101
102/*----------------------------------------------------------------------------*/
129/*----------------------------------------------------------------------------*/
130
131void
133 int phase_id,
134 cs_field_t *lagr_time,
135 cs_real_3_t *grad_pr,
136 cs_real_33_t *grad_vel,
137 cs_real_3_t *grad_tempf,
138 cs_real_3_t *anisotropic_lagr_time,
139 cs_real_3_t *anisotropic_bx,
140 cs_real_3_t *grad_lagr_time_r_et,
141 cs_real_3_t *grad_lagr_time,
142 cs_real_4_t *anisotropic_euler);
143
144/*----------------------------------------------------------------------------*/
145
147
148#endif /* CS_LAGR_AUX_MEAN_FLUID_QUANTITIES_H */
Definition: cs_field.h:275
Definition: cs_defs.h:528
cs_real_t cs_real_4_t[4]
vector of 4 floating-point values
Definition: cs_defs.h:350
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
Definition: cs_defs.h:529
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:358
void cs_lagr_aux_mean_fluid_quantities(int iprev, int phase_id, cs_field_t *lagr_time, cs_real_3_t *grad_pr, cs_real_33_t *grad_vel, cs_real_3_t *grad_tempf, cs_real_3_t *anisotropic_lagr_time, cs_real_3_t *anisotropic_bx, cs_real_3_t *grad_lagr_time_r_et, cs_real_3_t *grad_lagr_time, cs_real_4_t *anisotropic_euler)
Compute auxilary mean fluid quantities.
Definition: cs_lagr_aux_mean_fluid_quantities.cpp:517
void compute_particle_covariance_gradient(int phase_id, cs_real_3_t *grad_cov_skp[9], cs_real_3_t *grad_cov_sk[6])
Compute gradient of particle covariance.
Definition: cs_lagr_aux_mean_fluid_quantities.cpp:143
void compute_anisotropic_prop(int iprev, int phase_id, cs_real_3_t *anisotropic_lagr_time, cs_real_3_t *anisotropic_bx, cs_real_3_t *grad_lagr_time_r_et, cs_real_3_t *grad_lagr_time, cs_real_4_t *anisotropic_euler)
Compute anisotropic fluid quantities for complete model (modpl == 1).
Definition: cs_lagr_aux_mean_fluid_quantities.cpp:261
