◆ cs_face_to_vertex_type_t
| Enumerator |
| CS_FACE_TO_VERTEX_UNWEIGHTED | Uniform (constant) weights
| CS_FACE_TO_VERTEX_SURFACE | weights by surface
| CS_FACE_TO_VERTEX_SHEPARD | Shepard interpolation (weights by inverse distance)
◆ cs_b_face_to_vertex()
Interpolate boundary faces values to vertex values.
- Parameters
| [in] | method | interpolation method |
| [in] | var_dim | variable dimension |
| [in] | ignore_rot_perio | if true, ignore periodicity of rotation |
| [in] | b_weight | boundary-face weight, or NULL |
| [in] | b_var | base boundary-face values, or NULL |
| [out] | v_var | vertex-based variable |
◆ cs_face_to_vertex_free()
| void cs_face_to_vertex_free |
void |
Free cell to vertex interpolation weights.
This will force subsequent calls to rebuild those weights if needed.
◆ cs_face_to_vertex_type_name
| const char* cs_face_to_vertex_type_name[] |
extern |
