cs_equation_system_param.cpp File Reference
#include <cassert>
#include "base/cs_mem.h"
#include "cdo/cs_equation_system_param.h"
+ Include dependency graph for cs_equation_system_param.cpp:
Macros
#define CS_EQUATION_SYSTEM_PARAM_DBG   0
cs_equation_system_param_t * cs_equation_system_param_create (const char *name, int block_var_dim)
 Create and initialize a new cs_equation_system_param_t structure. More...
cs_equation_system_param_t * cs_equation_system_param_free (cs_equation_system_param_t *sysp)
 Free a cs_equation_system_param_t structure. More...
void cs_equation_system_param_log (const cs_equation_system_param_t *sysp)
 Log the setup gathered in the structure cs_equation_system_param_t. More...
void cs_equation_system_param_set (cs_equation_system_param_t *sysp, cs_equation_system_key_t key, const char *keyval)
 Set a parameter related to a keyname in a cs_equation_system_param_t structure. More...
◆ CS_EQUATION_SYSTEM_PARAM_DBG
◆ cs_equation_system_param_create()
cs_equation_system_param_t * cs_equation_system_param_create ( const char *  name,
int  block_var_dim
[in]namename of system of equations
[in]block_var_dimdimension of the variable in each block
a pointer to a newly initialized cs_equation_system_param_t
◆ cs_equation_system_param_free()
cs_equation_system_param_t * cs_equation_system_param_free ( cs_equation_system_param_t *  sysp)
[in,out]sysppointer to the structure to free
a null pointer
◆ cs_equation_system_param_log()
void cs_equation_system_param_log ( const cs_equation_system_param_t *  sysp)
[in]sysppointer to a parameter structure to log
◆ cs_equation_system_param_set()
void cs_equation_system_param_set ( cs_equation_system_param_t *  sysp,
const char *  keyval
[in,out]sysppointer to a parameter structure to set
[in]keykey related to the member of eq to set
[in]keyvalaccessor to the value to set
