1#ifndef CS_EQUATION_SYSTEM_H
2#define CS_EQUATION_SYSTEM_H
time step descriptor
Definition: cs_time_step.h:60
cs_equation_system_t * cs_equation_system_by_id(int sys_id)
Retrieve the pointer to the equation system related to the given id.
Definition: cs_equation_system.cpp:284
void *() cs_equation_system_free_t(int n_eqs, cs_equation_core_t **core_array, void *sys_context)
Free an array of structures (equation parameters, equation builders or scheme context) for each equat...
Definition: cs_equation_system.h:89
void cs_equation_system_init_sharing(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Assign a set of shared pointer to the main structures.
Definition: cs_equation_system.cpp:484
void cs_equation_system_assign_param(int row_id, int col_id, cs_equation_param_t *eqp, cs_equation_system_t *eqsys)
Assign the given equation parameters to the block with ids (row_id, col_id) in the block matrix.
Definition: cs_equation_system.cpp:808
void cs_equation_system_assign_equation(int row_id, cs_equation_t *eq, cs_equation_system_t *eqsys)
Assign the given equation to the diagonal block located at position (row_id, row_id) in the matrix of...
Definition: cs_equation_system.cpp:761
void cs_equation_system_destroy_all(void)
Destroy all cs_equation_system_t structures.
Definition: cs_equation_system.cpp:354
void cs_equation_system_log_setup(void)
Log the setup for all structures managing systems of equations.
Definition: cs_equation_system.cpp:371
void cs_equation_system_solve(const cs_time_step_t *time_step, bool cur2prev, cs_equation_system_t *eqsys)
Solve of a system of coupled equations. Unsteady case.
Definition: cs_equation_system.cpp:715
void() cs_equation_system_solve_t(bool c2p, const cs_time_step_t *time_step, int n_eqs, cs_equation_system_param_t *sysp, cs_equation_core_t **blocks, void *sys_context, cs_cdo_system_helper_t *sh)
Build and solve a linear system within the CDO framework.
Definition: cs_equation_system.h:108
void cs_equation_system_define(void)
Define the builder and scheme context structures associated to all the systems of equations which hav...
Definition: cs_equation_system.cpp:656
void cs_equation_system_set_functions(void)
Assign a set of pointer functions for managing all the systems of equations.
Definition: cs_equation_system.cpp:551
cs_equation_system_param_t * cs_equation_system_param_by_id(int sys_id)
Retrieve the pointer to the set of parameters of a system of equations related to the given id.
Definition: cs_equation_system.cpp:304
void cs_equation_system_log_monitoring(void)
Print a synthesis of the monitoring information in the performance file.
Definition: cs_equation_system.cpp:454
int cs_equation_system_get_n_systems(void)
Get the number of systems of equations.
Definition: cs_equation_system.cpp:268
cs_equation_system_t * cs_equation_system_add(const char *sysname, int n_eqs, int block_var_dim)
Add a new structure to handle system of coupled equations.
Definition: cs_equation_system.cpp:325
void cs_equation_system_set_sles(void)
Set the SLES associated to each system of equations.
Definition: cs_equation_system.cpp:617
void *() cs_equation_system_define_t(int n_eqs, const cs_equation_system_param_t *sysp, cs_equation_core_t **core_array, cs_cdo_system_helper_t **p_sh)
Create and initialize equation builders and scheme context for each equation which are in the extra-d...
Definition: cs_equation_system.h:65
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_system.h:373
Main structures on which an equation structure relies.
Definition: cs_equation.h:78
Main structure storing the parameter settings.
Definition: cs_equation_system_param.h:68
Main structure to handle a set of coupled equations.
Definition: cs_equation_system.h:121
cs_equation_system_free_t * free
Definition: cs_equation_system.h:220
void * context
Definition: cs_equation_system.h:152
cs_equation_t ** equations
Definition: cs_equation_system.h:169
cs_equation_system_solve_t * solve_steady_state_system
Definition: cs_equation_system.h:223
cs_equation_system_param_t * param
Definition: cs_equation_system.h:132
int timer_id
Definition: cs_equation_system.h:135
cs_timer_counter_t timer
Definition: cs_equation_system.h:134
cs_equation_core_t ** block_factories
Definition: cs_equation_system.h:195
cs_equation_system_define_t * define
Definition: cs_equation_system.h:219
cs_cdo_system_helper_t * system_helper
Definition: cs_equation_system.h:150
cs_equation_system_solve_t * solve_system
Definition: cs_equation_system.h:222
int n_equations
Definition: cs_equation_system.h:168
Definition: cs_timer.h:51
