Compressible
+ Collaboration diagram for Compressible:
Modules
 Homogeneous two-phase compressible model options
Classes
struct  cs_cf_model_t
 Compressible model general options descriptor. More...
int ieos
int ithvar
int icfgrp
double psginf
double gammasg
\ defgroup compressible Compressible models options
◆ gammasg
gammasg
stiffened gas polytropic coefficient (dimensionless) for single phase model
◆ icfgrp
icfgrp
indicator for hydrostatic balance in boundary conditions
In the cases where gravity is predominant, taking into account the hydrostatic pressure allows to get rid of perturbations which may appear near the horizontal walls when the flow is weakly convective.
Otherwise, when icfgrp=0, the pressure condition is calculated from the solution of the unidimensional Euler equations for a perfect gas near a wall, for the variables "normal velocity", "density" and "pressure":
Case of an expansion (M <= 0):
\begin{align*}
         P_p &= 0 & \textrm{if } 1 + \displaystyle\frac{\gamma-1}{2}M<0
      \\ P_p &= P_i \left(1 + \displaystyle\frac{\gamma-1}{2}M\right)
         ^{\frac{2\gamma}{\gamma-1}} & \textrm{otherwise}
         \end{align*}
Case of a schock (M > 0):
\begin{eqnarray*}
      P_p = P_i \left(1 + \displaystyle\frac{\gamma(\gamma+1)}{4}M^2
       +\gamma M \displaystyle\sqrt{1+\displaystyle\frac{(\gamma+1)^2}{16}M^2}\right)
      \end{eqnarray*}
with $M = \displaystyle\frac{\vect{u}_i \cdot \vect{n}}{c_i}$, internal Mach number calculated with the variables taken in the cell.
◆ ieos
ieos
indicator of equation of state
  • CS_EOS_IDEAL_GAS: ideal gas with a constant adiabatic coefficient
  • CS_EOS_STIFFENED_GAS: stiffened gas
  • CS_EOS_GAS_MIX: mix of ideal gas
  • CS_EOS_HOMOGENEOUS_TWO_PHASE: two-phase homogeneous model only, each phase follows a stiffened gas law.
  • CS_EOS_MOIST_AIR: moist air equation of state with condensable (mixture of two ideal gas)
◆ ithvar
ithvar
indicator for thermodynamic variables initialization
◆ psginf
psginf
stiffened gas limit pressure (zero in perfect gas) for single phase model in Pa
