cs_porosity_from_scan_opt_t Struct Reference
#include <cs_porosity_from_scan.h>
+ Collaboration diagram for cs_porosity_from_scan_opt_t:
Public Attributes
bool compute_porosity_from_scan
char * file_names
int n_headers
int * header_type
char ** headers
char * output_name
bool postprocess_points
cs_real_34_t transformation_matrix
cs_real_3_t direction_vector
cs_fill_type_t type_fill
int nb_sources
cs_real_3_t * sources
cs_lnum_t * source_c_ids
cs_lnum_t threshold
cs_lnum_t n_agglomeration
cs_real_t porosity_threshold
cs_real_t convection_porosity_threshold
bool use_staircase
cs_real_t eigenvalue_criteria
int use_restart
cs_ibm_cog_location_t cog_location
cs_real_33_t * mom_mat
bool has_classification
float * classification_values
bool * class_used
int n_classifications
cs_restart_t * restart
bool remove_cells_on_restart
Member Data Documentation
◆ class_used
bool* class_used
◆ classification_values
float* classification_values
◆ cog_location
◆ compute_porosity_from_scan
◆ convection_porosity_threshold
◆ direction_vector
To define the direction of fill, by default it is filled from top (z-direction).
◆ eigenvalue_criteria
◆ file_names
char* file_names
◆ has_classification
◆ header_type
int* header_type
◆ headers
char** headers
◆ mom_mat
cs_real_33_t* mom_mat
◆ n_agglomeration
◆ n_classifications
◆ n_headers
int n_headers
◆ nb_sources
int nb_sources
◆ output_name
char* output_name
◆ porosity_threshold
◆ postprocess_points
◆ remove_cells_on_restart
◆ restart
cs_restart_t* restart
◆ source_c_ids
cs_lnum_t* source_c_ids
◆ sources
cs_real_3_t* sources
◆ threshold
cs_lnum_t threshold
◆ transformation_matrix
Matrix of associated transformation (3x4 matrix, 3 first rows of a homogeneous coordinates transformation matrix, with last row = [0 0 0 1])
◆ type_fill
◆ use_restart
int use_restart
◆ use_staircase
bool use_staircase
