cs_porosity_from_scan.h File Reference
#include <ple_locator.h>
#include "fvm/fvm_nodal.h"
#include "base/cs_base.h"
#include "base/cs_halo.h"
#include "mesh/cs_mesh.h"
#include "base/cs_restart.h"
+ Include dependency graph for cs_porosity_from_scan.h:
Classes
struct  cs_porosity_from_scan_opt_t
Enumerations
enum  cs_ibm_cog_location_t { CS_COG_FROM_FLUID_FACES = 0 , CS_COG_FROM_PYRAMID = 1 , CS_COG_WITHOUT_RECONSTRUCTION_FOR_IBM_PLANE = 2 }
enum  cs_fill_type_t { CS_FILL_RADIAL = 0 , CS_FILL_DIRECTION = 1 }
void cs_porosity_from_scan_set_file_name (const char *file_name)
 Set the file name of points for the computation of the porosity from scan. More...
void cs_porosity_from_scan_set_output_name (const char *output_name)
 Set the output name for the FVM writer of scan points. More...
void cs_porosity_from_scan_add_source (const cs_real_t source[3], bool transform)
 Add a scanner source point. More...
void cs_ibm_add_sources_by_file_name (const char *file_name)
 Add the scanner sources from csv file to fill fluid space. More...
void cs_compute_porosity_from_scan (void)
 Compute the porosity which is equal to one from a source, radiating sphericaly, and is 0 when touching points of the scan. More...
void cs_porous_model_restart_write_stage_1 (void)
 Write the restart file of the ibm module. More...
void cs_porous_model_restart_write_stage_2 (void)
 Write the restart file of the ibm module for final disable_flag. More...
void cs_porous_model_restart_read_stage_1 (void)
 Read the restart file of the ibm module. More...
void cs_porous_model_restart_read_stage_2 (void)
cs_porosity_from_scan_opt_t * cs_glob_porosity_from_scan_opt
◆ cs_fill_type_t
Enumerator
CS_FILL_RADIAL
CS_FILL_DIRECTION
◆ cs_ibm_cog_location_t
Enumerator
CS_COG_FROM_PYRAMID
◆ cs_compute_porosity_from_scan()
void cs_compute_porosity_from_scan ( void  )
This function solves the following transport equation on $ \varia $:
 \dfrac{\partial \varia}{\partial t} + \divs \left( \varia \vect{e}_r \right)
     - \divs \left( \vect{e}_r \right) \varia = 0
where $ \vect{e}_r = \dfrac{\vect{x} - \vect{x}_0}{\norm{\vect{x} - \vect{x}_0}} $ is the radial direction from the source $\vect{x}_0 $.
The boundary conditions on $ \varia $ is an homogeneous Neumann, and a penalisation term is impose in the cell of center $ \vect{x}_0$.
  \dfrac{\partial \varia}{\partial n} = 0 \textrm{everywhere}
Remarks:
  • a steady state is looked for.
where $ \vect{e}_r
Remarks:
◆ cs_ibm_add_sources_by_file_name()
void cs_ibm_add_sources_by_file_name ( const char *  file_name)
[in]csvfile containing the (x,y,z) coordinates of each scanner
◆ cs_porosity_from_scan_add_source()
void cs_porosity_from_scan_add_source ( const cs_real_t  source[3],
bool  transform
[in]sourcesource vector
[in]transformflag to apply the transformation matrix to the source
◆ cs_porosity_from_scan_set_file_name()
void cs_porosity_from_scan_set_file_name ( const char *  file_name)
[in]file_namename of the file.
◆ cs_porosity_from_scan_set_output_name()
void cs_porosity_from_scan_set_output_name ( const char *  output_name)
[in]output_namename of the output (a suffix will be added)
◆ cs_porous_model_restart_read_stage_1()
void cs_porous_model_restart_read_stage_1 ( void  )
◆ cs_porous_model_restart_read_stage_2()
void cs_porous_model_restart_read_stage_2 ( void  )
◆ cs_porous_model_restart_write_stage_1()
void cs_porous_model_restart_write_stage_1 ( void  )
◆ cs_porous_model_restart_write_stage_2()
void cs_porous_model_restart_write_stage_2 ( void  )
◆ cs_glob_porosity_from_scan_opt
cs_porosity_from_scan_opt_t* cs_glob_porosity_from_scan_opt
extern
