cs_gwf_tracer_t Struct Reference
#include <cs_gwf_tracer.h>
+ Collaboration diagram for cs_gwf_tracer_t:
Public Attributes
Physical modelling information for a tracer
cs_gwf_model_type_t hydraulic_model
cs_gwf_tracer_model_t model
cs_field_t * diffusivity
int reaction_id
Other members
cs_equation_t * equation
void * context
int chain_position_id
int chain_id
Function pointers associated to a tracer
cs_gwf_tracer_update_t * update_diff_pty
cs_gwf_tracer_update_t * update_precipitation
cs_gwf_tracer_update_t * update_decay_chain_st
cs_gwf_tracer_integrate_t * integrate
cs_gwf_tracer_init_setup_t * init_setup
cs_gwf_tracer_finalize_setup_t * finalize_setup
cs_gwf_tracer_free_context_t * free_context
Member Data Documentation
◆ chain_id
chain_id
id in the array of decay chains. (-1 if not associated to a decay chain; this is the default behavior)
◆ chain_position_id
chain_position_id
Position of the current tracer inside a decay chain. The default value is -1 meaning that this is not a tracer associated to a decay chain.
◆ context
context
Pointer to a context structure cast on-the-fly according to the model.
◆ diffusivity
diffusivity
Field related to the property associated to the diffusion term. null if no diffusion term is build in the tracer equation.
◆ equation
equation
Pointer to the related equation structure
◆ finalize_setup
finalize_setup
This is a function pointer to finalize the setup of a tracer equation. There is a function pointer by default but this can be overloaded by a user-defined function in the case of a user-defined tracer.
◆ free_context
free_context
Function to free quantities or structure associated to the context structure of a tracer.
◆ hydraulic_model
hydraulic_model
Type of hydraulic model to consider. This is an information shared with the main gorundwater flow structure
◆ init_setup
init_setup
This is a function pointer to initialize the setup (adding terms in an equation). At this stage, the mesh has not been loaded. There is a function pointer by default but this can be overloaded by a user-defined function in the case of a user-defined tracer.
◆ integrate
integrate
Function to compute the quantity of tracer inside a volume. The way to compute this quantity may be optimized according to the hydraulic model or the tracer modelling.
◆ model
model
Type of tracer model to consider. 0 corresponds to the default behavior.
◆ reaction_id
reaction_id
Since there can be several reaction terms associated to an equation. One stores the id related to the reaction term wich is automatically added when a radioactive tracer is considered.
◆ update_decay_chain_st
Function used to update the source term induced by the parent in a decay chain
◆ update_diff_pty
update_diff_pty
Function used to update the diffusion property which is a tensor in the most generic case (dispersion + diffusion)
◆ update_precipitation
Function used to update the quantities related to the precipitation model
