cs_gwf_darcy_flux_t Struct Reference
#include <cs_gwf_priv.h>
+ Collaboration diagram for cs_gwf_darcy_flux_t:
Public Attributes
cs_adv_field_t * adv_field
cs_flag_t flux_location
cs_real_t * flux_val
cs_real_t * boundary_flux_val
bool simplified_boundary_update
cs_gwf_darcy_update_t * update_func
void * update_input
Member Data Documentation
◆ adv_field
adv_field
Pointer to a cs_adv_field_t structure. Darcy advective flux in the liquid phase. This structure is used to define the advective term in tracer equations for instance.
◆ boundary_flux_val
boundary_flux_val
Array storing the normal Darcian flux across the boundary of the computational domain for the liquid phase. This is an optional array.
◆ flux_location
flux_location
Indicate where the arrays defining the Darcy fluxes are located
◆ flux_val
flux_val
Array storing the liquid Darcian flux in each location (for instance the dual faces associated to each cell)
◆ simplified_boundary_update
If true, a constant approximation of the gradient is computed to define the boundary flux. Otherwise, one tries to reproduce exactly the divergence of the advection field, the difference is distributed according to the area of each boundary face attached to a boundary vertex. This option is only useful for vertex-based scheme.
◆ update_func
update_func
Pointer to the function which performs the update of the advection field
◆ update_input
update_input
Context pointer for the update function or nullptr if useless
