cs_ctwr_zone_t Struct Reference
#include <cs_ctwr.h>
+ Collaboration diagram for cs_ctwr_zone_t:
Public Attributes
int num
char * criteria
int z_id
char * name
char * file_name
cs_ctwr_zone_type_t type
cs_real_t hmin
cs_real_t hmax
cs_real_t delta_t
cs_real_t relax
cs_real_t t_l_bc
cs_real_t q_l_bc
cs_real_t xap
cs_real_t xnp
cs_real_t surface_in
cs_real_t surface_out
cs_real_t surface
cs_real_t xleak_fac
cs_real_t v_liq_pack
cs_lnum_t n_cells
cs_real_t vol_f
int up_ct_id
cs_lnum_t n_inlet_faces
cs_lnum_t n_outlet_faces
cs_lnum_t * inlet_faces_ids
cs_lnum_t * outlet_faces_ids
cs_lnum_t n_outlet_cells
cs_lnum_t * outlet_cells_ids
cs_real_t p_in
cs_real_t p_out
cs_real_t q_l_in
cs_real_t q_l_out
cs_real_t t_l_in
cs_real_t t_l_out
cs_real_t h_l_in
cs_real_t h_l_out
cs_real_t t_h_in
cs_real_t t_h_out
cs_real_t xair_e
cs_real_t xair_s
cs_real_t h_h_in
cs_real_t h_h_out
cs_real_t q_h_in
cs_real_t q_h_out
Member Data Documentation
◆ criteria
char* criteria
◆ delta_t
cs_real_t delta_t
◆ file_name
char* file_name
◆ h_h_in
cs_real_t h_h_in
◆ h_h_out
cs_real_t h_h_out
◆ h_l_in
cs_real_t h_l_in
◆ h_l_out
cs_real_t h_l_out
◆ hmax
cs_real_t hmax
◆ hmin
cs_real_t hmin
◆ inlet_faces_ids
cs_lnum_t* inlet_faces_ids
◆ n_cells
cs_lnum_t n_cells
◆ n_inlet_faces
◆ n_outlet_cells
◆ n_outlet_faces
◆ name
char* name
◆ num
int num
◆ outlet_cells_ids
cs_lnum_t* outlet_cells_ids
◆ outlet_faces_ids
cs_lnum_t* outlet_faces_ids
◆ p_in
cs_real_t p_in
◆ p_out
cs_real_t p_out
◆ q_h_in
cs_real_t q_h_in
◆ q_h_out
cs_real_t q_h_out
◆ q_l_bc
cs_real_t q_l_bc
◆ q_l_in
cs_real_t q_l_in
◆ q_l_out
cs_real_t q_l_out
◆ relax
cs_real_t relax
◆ surface
cs_real_t surface
◆ surface_in
◆ surface_out
◆ t_h_in
cs_real_t t_h_in
◆ t_h_out
cs_real_t t_h_out
◆ t_l_bc
cs_real_t t_l_bc
◆ t_l_in
cs_real_t t_l_in
◆ t_l_out
cs_real_t t_l_out
◆ type
◆ up_ct_id
int up_ct_id
◆ v_liq_pack
◆ vol_f
cs_real_t vol_f
◆ xair_e
cs_real_t xair_e
◆ xair_s
cs_real_t xair_s
◆ xap
cs_real_t xap
◆ xleak_fac
cs_real_t xleak_fac
◆ xnp
cs_real_t xnp
◆ z_id
int z_id
