cs_ctwr.h File Reference
+ Include dependency graph for cs_ctwr.h:
Classes
struct  cs_ctwr_zone_t
struct  cs_ctwr_option_t
Enumerations
enum  cs_ctwr_model_t { CS_CTWR_NONE = 0 , CS_CTWR_POPPE = 1 , CS_CTWR_MERKEL = 2 }
enum  cs_ctwr_zone_type_t { CS_CTWR_COUNTER_CURRENT = 1 , CS_CTWR_CROSS_CURRENT = 2 , CS_CTWR_INJECTION = 3 }
cs_ctwr_option_t * cs_get_glob_ctwr_option (void)
cs_ctwr_zone_t ** cs_get_glob_ctwr_zone (void)
int * cs_get_glob_ctwr_n_zones (void)
void cs_ctwr_define (const char zone_criteria[], int z_id, cs_ctwr_zone_type_t zone_type, cs_real_t delta_t, cs_real_t relax, cs_real_t t_l_bc, cs_real_t q_l_bc, cs_real_t xap, cs_real_t xnp, cs_real_t surface, cs_real_t xleak_fac)
 Define a cooling tower exchange zone. More...
void cs_ctwr_field_pointer_map (void)
 Map fields used by the cooling tower module to pointers. More...
void cs_ctwr_define_zones (void)
 Define zones. More...
void cs_ctwr_build_all (void)
 Define the cells belonging to the different packing zones. More...
void cs_ctwr_all_destroy (void)
 Destroy cs_ctwr_t structures. More...
void cs_ctwr_log_setup (void)
 Log Packing zone definition setup information. More...
void cs_ctwr_log_balance (void)
 Perform balances in packing zones. More...
void cs_ctwr_transport_vars (int iflag)
 Convert injected liquid scalars from and to their transported form. More...
cs_ctwr_zone_t * cs_ctwr_by_id (int ct_id)
const cs_ctwr_option_t * cs_glob_ctwr_option
◆ cs_ctwr_model_t
Type of cooling tower model
Enumerator
CS_CTWR_NONE
no cooling tower model
CS_CTWR_POPPE
Poppe's model
CS_CTWR_MERKEL
Merkel's model
◆ cs_ctwr_zone_type_t
Type of cooling tower exchange zone
Enumerator
counter-current zone
cross-current zone
CS_CTWR_INJECTION
water injection zone
◆ cs_ctwr_all_destroy()
void cs_ctwr_all_destroy ( void  )
◆ cs_ctwr_build_all()
void cs_ctwr_build_all ( void  )
◆ cs_ctwr_by_id()
cs_ctwr_zone_t * cs_ctwr_by_id ( int  ct_id)
◆ cs_ctwr_define()
void cs_ctwr_define ( const char  zone_criteria[],
int  z_id,
cs_real_t  delta_t,
cs_real_t  relax,
cs_real_t  t_l_bc,
cs_real_t  q_l_bc,
cs_real_t  xap,
cs_real_t  xnp,
cs_real_t  surface,
cs_real_t  xleak_fac
[in]zone_criteriazone selection criteria
[in]z_idz_id if zone already created (-1 otherwise)
[in]zone_typeexchange zone type
[in]delta_timposed delta temperature delta between inlet and oulet of the zone
[in]relaxrelaxation of the imposed delta temperature
[in]t_l_bcliquid water temperature at the inlet
[in]q_l_bcmass flow rate at the inlet
[in]xapbeta_x_0 of the exchange law
[in]xnpexponent n of the exchange law
[in]surfacetotal Surface of ingoing water
[in]xleak_facleakage factor (ratio of outlet/inlet flow rate)
[in]zone_criteriazone selection criteria (or nullptr)
[in]delta_timposed delta temperature delta between inlet and outlet of the zone
◆ cs_ctwr_define_zones()
void cs_ctwr_define_zones ( void  )
Define zones.
Define zones.
TODO rename this: definition (at setup stage) and build (instanciation on actual mesh are not the same).
◆ cs_ctwr_field_pointer_map()
void cs_ctwr_field_pointer_map ( void  )
◆ cs_ctwr_log_balance()
void cs_ctwr_log_balance ( void  )
◆ cs_ctwr_log_setup()
void cs_ctwr_log_setup ( void  )
◆ cs_ctwr_transport_vars()
void cs_ctwr_transport_vars ( int  iflag)
[in]iflag1: Convert transported variables to physical variables 2: Convert physical variables to transported variables
◆ cs_get_glob_ctwr_n_zones()
int * cs_get_glob_ctwr_n_zones ( void  )
◆ cs_get_glob_ctwr_option()
cs_ctwr_option_t * cs_get_glob_ctwr_option ( void  )
◆ cs_get_glob_ctwr_zone()
cs_ctwr_zone_t ** cs_get_glob_ctwr_zone ( void  )
◆ cs_glob_ctwr_option
const cs_ctwr_option_t* cs_glob_ctwr_option
extern
