cs_wall_condensation.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "base/cs_base.h"
#include "base/cs_1d_wall_thermal.h"
#include "base/cs_field.h"
#include "base/cs_gas_mix.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_restart.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_wall_condensation_1d_thermal.h"
#include "base/cs_wall_functions.h"
#include "base/cs_wall_condensation.h"
+ Include dependency graph for cs_wall_condensation.cpp:
cs_wall_condensation_t * cs_get_glob_wall_condensation (void)
 Provide writable access to _wall_cond structure. More...
void cs_wall_condensation_set_model (cs_wall_cond_natural_conv_model_t model)
 Set the wall condensation model. More...
void cs_wall_condensation_set_onoff_state (int icondb, int icondv)
 Set the onoff state of wall condensation modeling. More...
void cs_wall_condensation_create (void)
 Create the context for wall condensation models. More...
void cs_wall_condensation_free (void)
 Free all structures related to wall condensation models. More...
void cs_wall_condensation_initialize (void)
 Initialize wall condensation models. More...
void cs_wall_condensation_volume_exchange_surf_at_cells (cs_real_t *surf)
 Return condensing volume structures surface at each cell. More...
void cs_wall_condensation_reset (cs_wall_condensation_t *wall_cond, const int n_var)
void cs_wall_condensation_compute (cs_real_t total_htc[])
 Compute the wall condensation source terms. More...
void cs_wall_condensation_log (void)
 Output statistics about wall condensation source terms (for user log) More...
void cs_wall_condensation_source_terms (const cs_field_t *f, const cs_real_t xcpp[], const cs_real_t pvara[], cs_real_t st_exp[], cs_real_t st_imp[])
 Explicit and implicit sources terms from sources condensation computation. More...
const cs_wall_condensation_t * cs_glob_wall_condensation = &_wall_cond
◆ cs_get_glob_wall_condensation()
cs_wall_condensation_t * cs_get_glob_wall_condensation ( void  )
pointer to global wall_cond structure
◆ cs_wall_condensation_compute()
void cs_wall_condensation_compute ( cs_real_t  total_htc[])
◆ cs_wall_condensation_create()
void cs_wall_condensation_create ( void  )
◆ cs_wall_condensation_free()
void cs_wall_condensation_free ( void  )
◆ cs_wall_condensation_initialize()
void cs_wall_condensation_initialize ( void  )
This includes building the associated meshes.
◆ cs_wall_condensation_log()
void cs_wall_condensation_log ( void  )
◆ cs_wall_condensation_reset()
void cs_wall_condensation_reset ( cs_wall_condensation_t *  wall_cond,
const int  n_var
◆ cs_wall_condensation_set_model()
void cs_wall_condensation_set_model ( cs_wall_cond_natural_conv_model_t  model)
[in]modelinteger corresponding to the desired model
◆ cs_wall_condensation_set_onoff_state()
void cs_wall_condensation_set_onoff_state ( int  icondb,
int  icondv
[in]icondbinteger corresponding to the onoff state (-1: off, 0: on)
[in]icondvinteger corresponding to the onoff state with metal structures (-1: off, 0: on)
◆ cs_wall_condensation_source_terms()
void cs_wall_condensation_source_terms ( const cs_field_t *  f,
cs_real_t  st_exp[],
cs_real_t  st_imp[]
[in]fpointer to field structure
[in]xcpparray of specific heat (Cp)
[in]pvaravariable value at time step beginning
[in,out]st_expexplicit source term part linear in the variable
[in,out]st_impassociated value with tsexp to be stored in the matrix
◆ cs_wall_condensation_volume_exchange_surf_at_cells()
void cs_wall_condensation_volume_exchange_surf_at_cells ( cs_real_t *  surf)
[out]surfarray of volume structure surfaces at each cell
◆ cs_glob_wall_condensation
const cs_wall_condensation_t* cs_glob_wall_condensation = &_wall_cond
