cs_volume_mass_injection.cpp File Reference
#include "bft/bft_error.h"
#include "base/cs_array.h"
#include "base/cs_base.h"
#include "cdo/cs_equation_param.h"
#include "base/cs_field.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_volume_mass_injection.h"
+ Include dependency graph for cs_volume_mass_injection.cpp:
void cs_volume_mass_injection_flag_zones (void)
 Flag volume zones with the appropriate CS_VOLUME_ZONE_MASS_SOURCE_TERM flag when at least one volume mass injection on that zone is present. More...
void cs_volume_mass_injection_build_lists (void)
 Build the list and zone ids of cells with volume mass injection. More...
void cs_volume_mass_injection_eval (void)
 Evaluate contributions to volume mass injection. More...
void cs_volume_mass_injection_get_arrays (const cs_field_t *f, cs_lnum_t *n_elts, const cs_lnum_t **elt_ids, int **mst_type, cs_real_t **mst_val, cs_real_t **gamma)
 Return pointers to the mass source term arrays. More...
Volume mass injection and associated source terms computation.
◆ cs_volume_mass_injection_build_lists()
void cs_volume_mass_injection_build_lists ( void  )
◆ cs_volume_mass_injection_eval()
void cs_volume_mass_injection_eval ( void  )
◆ cs_volume_mass_injection_flag_zones()
void cs_volume_mass_injection_flag_zones ( void  )
This is necessary for the reverse zone indexing required by the legacy code to function with defintions that are partially unrolled an not purely zone-based.
◆ cs_volume_mass_injection_get_arrays()
void cs_volume_mass_injection_get_arrays ( const cs_field_t *  f,
cs_lnum_t *  n_elts,
const cs_lnum_t **  elt_ids,
int **  mst_type,
cs_real_t **  mst_val,
cs_real_t **  gamma
[in]fpointer to associated field
[out]n_eltsnumber of cells with mass source terms
[out]elt_idspointer to source mass cells list (1-based numbering)//FIXME
[out]mst_typemass source types (0: ambient value, 1: s_val value)
[out]mst_valpointer to mass source values
[out]gammapointer to flow mass value
