cs_time_moment.h File Reference
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "base/cs_restart.h"
#include "base/cs_function.h"
+ Include dependency graph for cs_time_moment.h:
Typedefs
typedef void() cs_time_moment_data_t(const void *input, cs_real_t *vals)
Enumerations
enum  cs_time_moment_type_t { CS_TIME_MOMENT_MEAN , CS_TIME_MOMENT_VARIANCE }
enum  cs_time_moment_restart_t { CS_TIME_MOMENT_RESTART_RESET , CS_TIME_MOMENT_RESTART_AUTO , CS_TIME_MOMENT_RESTART_EXACT }
void cs_time_moment_destroy_all (void)
 Destroy all moments management metadata. More...
void cs_time_moment_map_cell_dt (const cs_real_t *dt)
 Map time step values for temporal moments. More...
void cs_time_moment_update_all (void)
 Update all moment accumulators. More...
int cs_time_moment_is_active (int moment_id)
 Return 1 if moment is active, 0 if it is not active yet. More...
int cs_time_moment_define_by_field_ids (const char *name, int n_fields, const int field_id[], const int component_id[], cs_time_moment_type_t type, int nt_start, double t_start, cs_time_moment_restart_t restart_mode, const char *restart_name)
 Define a moment of a product of existing fields components. More...
int cs_time_moment_define_by_field (const char *name, const cs_field_t *f, cs_time_moment_type_t type, int nt_start, double t_start, cs_time_moment_restart_t restart_mode, const char *restart_name)
 Define a time moment of an existing field. More...
int cs_time_moment_define_by_function (const char *name, cs_function_t *f, cs_time_moment_type_t type, int nt_start, double t_start, cs_time_moment_restart_t restart_mode, const char *restart_name)
 Define a time moment based on an evaluation function. More...
int cs_time_moment_define_by_func (const char *name, int location_id, int dim, bool is_intensive, cs_time_moment_data_t *data_func, const void *data_input, cs_time_moment_data_t *w_data_func, void *w_data_input, cs_time_moment_type_t type, int nt_start, double t_start, cs_time_moment_restart_t restart_mode, const char *restart_name)
 Define a moment whose data values will be computed using a specified function. More...
int cs_time_moment_n_moments (void)
 Return the number of defined time moments. More...
int cs_time_moment_n_moments_restart (void)
 Return the number of time moments in the restart file, if any. More...
void cs_time_moment_restart_options_by_id (int restart_id, cs_time_moment_restart_t *restart_mode, const char **restart_name)
 Define a moment restart mode and name by an id. More...
const char * cs_time_moment_restart_name (int restart_id)
 Return name of a given time moments in the restart file, if any (check also cs_time_moment_n_moments_restart). More...
cs_field_t * cs_time_moment_get_field (int moment_id)
 Return pointer to field associated with a given moment. More...
void cs_time_moment_set_start_time (int moment_id, int nt_start)
 Reset selected time step for starting time step of selected moment. More...
void cs_time_moment_set_start_time (int moment_id, double t_start)
void cs_time_moment_reset (int moment_id)
 Set current iteration as starting time step of selected moment. More...
void cs_time_moment_log_setup (void)
 Log moment definition setup information. More...
void cs_time_moment_log_iteration (void)
 Log moment definition information for a given iteration. More...
void cs_time_moment_restart_use_main (int use_main)
 Indicate if restart API should use "main" instead of "auxiliary" file. More...
void cs_time_moment_restart_read (cs_restart_t *restart)
 Read restart moment data. More...
void cs_time_moment_restart_write (cs_restart_t *restart)
 Checkpoint moment data. More...
const char * cs_time_moment_type_name []
Typedef Documentation
◆ cs_time_moment_data_t
◆ cs_time_moment_restart_t
Enumerator
Moment is reset in case of a restart file: starting time step will be no older than the restart time step.
Moment uses restart information if available: if the requested time step is older than the restart time step, restart information will be used, though the starting time step is not guaranteed.
If the requested time step is older than the restart time step, restart information will be used, and if the start time step or time does not match the one available, an error is thrown.
◆ cs_time_moment_type_t
Enumerator
CS_TIME_MOMENT_MEAN
Moment is a mean
Moment is a variance
◆ cs_time_moment_define_by_field()
int cs_time_moment_define_by_field ( const char *  name,
const cs_field_t *  f,
int  nt_start,
double  t_start,
const char *  restart_name
Moments will involve the tensor products of their component fields, and only scalar, vector, or rank-2 tensors are handled (for post-processing output reasons), so a 1st-order moment (i.e. mean) may involve a scalar, vector, or tensor, while a second-order moment (i.e. variance) may only involve a scalar or vector.
[in]namename of associated moment
[in]fpointer to associated field
[in]typemoment type
[in]nt_startstarting time step (or -1 to use t_start)
[in]t_startstarting time
[in]restart_modebehavior in case of restart (reset, automatic, or strict)
[in]restart_nameif non-null, previous name in case of restart
id of new moment in case of success, -1 in case of error.
◆ cs_time_moment_define_by_field_ids()
int cs_time_moment_define_by_field_ids ( const char *  name,
int  n_fields,
int  nt_start,
double  t_start,
Moments will involve the tensor products of their component fields, and only scalar, vector, or rank-2 tensors are handled (for post-processing output reasons), so a moment may not involve more than 2 vectors or 1 tensor, unless single components are specified.
[in]n_fieldsnumber of associated fields
[in]field_idids of associated fields
[in]component_idids of matching field components (-1 for all)
[in]typemoment type
◆ cs_time_moment_define_by_func()
int cs_time_moment_define_by_func ( const char *  name,
int  location_id,
int  dim,
bool  is_intensive,
cs_time_moment_data_t *  data_func,
const void *  data_input,
cs_time_moment_data_t *  w_data_func,
void *  w_data_input,
int  nt_start,
double  t_start,
[in]location_idid of associated mesh location
[in]dimdimension associated with element data
[in]is_intensiveis the time moment intensive?
[in]data_funcfunction used to define data values
[in]data_inputpointer to optional (untyped) value or structure to be used by data_func
[in]w_data_funcfunction used to define weight values
[in]w_data_inputpointer to optional (untyped) value or structure to be used by w_data_func
[in]typemoment type
◆ cs_time_moment_define_by_function()
int cs_time_moment_define_by_function ( const char *  name,
cs_function_t *  f,
int  nt_start,
double  t_start,
[in]fpointer to function object
[in]typemoment type
◆ cs_time_moment_destroy_all()
void cs_time_moment_destroy_all ( void  )
◆ cs_time_moment_get_field()
cs_field_t * cs_time_moment_get_field ( int  moment_id)
For moments defined automatically to assist computation of higher order moments, which do not have an associated field, a null pointer is returned.
[in]moment_idid of associated moment
pointer to field associated with given moment, or null
◆ cs_time_moment_is_active()
int cs_time_moment_is_active ( int  moment_id)
◆ cs_time_moment_log_iteration()
void cs_time_moment_log_iteration ( void  )
◆ cs_time_moment_log_setup()
void cs_time_moment_log_setup ( void  )
◆ cs_time_moment_map_cell_dt()
void cs_time_moment_map_cell_dt ( const cs_real_t *  dt)
If this function is not called, the value from cs_glob_time_step->dt_ref will be used instead.
[in]dtpointer to time step values array
◆ cs_time_moment_n_moments()
int cs_time_moment_n_moments ( void  )
◆ cs_time_moment_n_moments_restart()
int cs_time_moment_n_moments_restart ( void  )
number of defined moments in restart file, or 0
◆ cs_time_moment_reset()
void cs_time_moment_reset ( int  moment_id)
All other time moments sharing the same start time should also be reset.
◆ cs_time_moment_restart_name()
const char * cs_time_moment_restart_name ( int  restart_id)
[in]restart_idid of time moment in restart data
name of defined moment in restart file, or null
◆ cs_time_moment_restart_options_by_id()
void cs_time_moment_restart_options_by_id ( int  restart_id,
cs_time_moment_restart_t *  restart_mode,
const char **  restart_name
This is a utility function, to allow simplification of automatic setups. It must be called just before defining a moment to work properly if restart_id < -1 (automatic mode).
[in]restart_id-2: automatic, -1: reset, >= 0: id of matching moment in restart data
[out]restart_modematching restart mode
[out]restart_namematching restart name
◆ cs_time_moment_restart_read()
void cs_time_moment_restart_read ( cs_restart_t *  restart)
[in]restartassociated restart file pointer
◆ cs_time_moment_restart_use_main()
void cs_time_moment_restart_use_main ( int  use_main)
[in]use_mainuse "main" restart if nonzero, "auxiliary" otherwise
◆ cs_time_moment_restart_write()
void cs_time_moment_restart_write ( cs_restart_t *  restart)
◆ cs_time_moment_set_start_time() [1/2]
void cs_time_moment_set_start_time ( int  moment_id,
double  t_start
All other time moments sharing the same start time will also start at the same time step.
[in]moment_idid of associated moment, or -1 for all
[in]nt_startstarting time value
◆ cs_time_moment_set_start_time() [2/2]
int  nt_start
◆ cs_time_moment_update_all()
void cs_time_moment_update_all ( void  )
◆ cs_time_moment_type_name
const char* cs_time_moment_type_name[]
extern
